Old 11-30-2003, 01:31 AM   #7021
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by GTO2
Is it a coincidence or ?
I just notice that my TC3 front block carriers are exactly identical. Being so the left one is leaning towards backside of the arm,
and the right one is leaning towards frontside of the arm.
I can see the steering throw is not symetrical between left and right because of this.
Thinking it is wrong and need correction, I get myself a new pair of Front Block Carriers p/n 3869 0 Graphite.
To my surprise, they are identical as well....is this normal?
Else I have to sand them.
This is normal, and you do not NEED to sand anything, you just need to use dual rate on your transmitter, and make the car turn right identical to it turning left. Personally, I use steering knuckles with the "stopper" dremeled off, so the steering rack can slide from bushing to bushing.
Bubblestc3 is offline   Reply With Quote
Old 11-30-2003, 07:33 AM   #7022
gee-dub's Avatar
it sounds more like you're talking about the caster than toe, is this correct? if this is the case, you are correct that is not normal. i'd be looking at the inner pivot blocks, or possibly a bent inner hinge pin. there are also some previous posts which might explain the problem (defective mold, wrong parts in bag, etc).
gee-dub is offline   Reply With Quote
Old 11-30-2003, 08:31 AM   #7023
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Well after all these years I'm finally going to get a FT TC3. I have tried everything else but I decided to run all Associated stuff from now on and no more odd ball stuff for me anymore. I have ben running non main stream stuff for 17 years and have done great but now it is time to get a TC3. The car speaks for itself.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 11-30-2003, 02:38 PM   #7024
Default The New wheel adaptors?
I am looking for a place to buy the new aluminum Blue clamp style hex wheel adaptors for my electric TC3.What company is making them or who is carring the part.Part number whould be great.
rcmotorhead is offline   Reply With Quote
Old 11-30-2003, 04:05 PM   #7025
Default TC3 Carpet Setup
ANyone have a good carpet setup: shocks, tires(compounf and 26mm or 30mm), stabilizers, etc. Also heard that some people are running losi rear blocks???
Any help woulds be appreciated. Thanks.
savio7 is offline   Reply With Quote
Old 11-30-2003, 04:49 PM   #7026
Super Moderator
Grizzbob's Avatar
Default Re: The New wheel adaptors?
I'm not totally sure they're still selling them, but I know that Yokomo has made some of those for the TC3(in fact, I have a set of them on mine right now). But I don't remember what the art number for them was, so it might be best to have a look at Yok's website & see if you can find them....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-30-2003, 05:22 PM   #7027
gee-dub's Avatar
associated is selling some under the 'factory team' label. do not recall availability.
Old 11-30-2003, 06:00 PM   #7028
Yokomo has them (Assoc ones might be these rebranded, dunno). The yok part # is SP-3950C. Speedtech carries them, but they're out right now.
spyderx is offline   Reply With Quote
Old 11-30-2003, 06:19 PM   #7029
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
I will be ordering some things from them tomorrow, clamping hexes is one of those things, I will tell you guys the availability tomorrow
=MisFitz= NuKe is offline   Reply With Quote
Old 11-30-2003, 06:42 PM   #7030
GTO2's Avatar
R/C Tech Charter Subscriber
Originally posted by Nexus
GTO2
you don't need to sand them...it's fine and the car works fine with it. that has been discussed tons of times on this and other TC3 threads. that is how they are designed.
besides you don't need full 100% steering throw at race speeds. i run a bone stock FT TC3 with no milling, sanding, shimming, ect. and have won and placed consistantly in the A Main at my track.
OK, thanks.
Still think it's a bit awkward on why AE don't do mirror image.
GTO2 is offline   Reply With Quote
Old 11-30-2003, 06:47 PM   #7031
GTO2's Avatar
dremmeling it out, won't it make the steering arm lose some of its strength? I dun mind trying it out tho as long as it is ok reliability wise.
I assume you cutoff the 'stopper' straight as the rest of the arm?
Old 11-30-2003, 06:51 PM   #7032
tc3rookie's Avatar
Default A main!
i just finished the last race of the season.
i just qualified 2nd and got 1st place in the a main!
next season (January) i'll bump up a class. i'm running a tc3 rtr with every upgrade except alluminum shocks, a TiR Titainum screw kit and stock motor. i'd post a picture if my digital camera worked.
Happy Holadays !
tc3rookie is offline   Reply With Quote
Old 11-30-2003, 07:00 PM   #7033
GTO2's Avatar
Nope, caster remains the same, it's just one of the block (C hub) is more forward than the other.
So if I measure the wheelbase, it won't be the same left side and the right side.
Anyway, if it is the way they designed it...they should be a reason.
Thanks for the insight, tho.
Old 11-30-2003, 07:22 PM   #7034
Trader Rating: 37 (100%+)
something sounds weird...i think you are talking about something different then most of us. can you take a digital pic of your car?
if you measure front axle to rear axle the distand should be the same on both sides.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 11-30-2003, 08:20 PM   #7035
GTO2's Avatar
nexus:
I don't have a digi cam currently.
That was an assumption I made, the LF & RF arm is symetrical left to right but the C hubs aren't. Thats why I think they are different L to R wheelbase.
I will have a closer look and probably measure up axle to axle later when I go back frm work.
It could well be different stopping position for the steering arm but same symetrical LF & LR axles...thanks for pointing that out.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
