Old 11-25-2003, 08:24 PM   #6991
mike_Webb's Avatar
Send a message via AIM to mike_Webb
The IRS units are nice. You will need to buy the Bearings for them and not use the Bushings.
I had to use them last year at the Snowbirds.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 11-25-2003, 09:32 PM   #6992
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Are you melting these diff outdrives in mod or stock racing?
The IRS out drives should do just fine, but personally in stock racing I preffer to use the plastic outdrives...
Bubblestc3 is offline   Reply With Quote
Old 11-25-2003, 10:24 PM   #6993
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Default the C-Hubs
Hey guys, alright about the C-hub problems that everyone is having. I have the CAD drawings finished, and I am not in the process of getting the plastic prototype pieces cut-out. If everything goes right, they will be an exact replica of the AE ones, but without the things that limit the travel. I am going to polish them so they look nice. I should, SHOULD, be able to sell them for about 18 bucks for a set. I will have to see on pricing, and If you want them polished or not, cause that takes forever.
With the aluminum you will be able to crank down on them, and not strip down, plus since this is a school fundraiser thing, I wont be selling them for out-rageous amounts, like some companies.
=MisFitz= NuKe is offline   Reply With Quote
Old 11-25-2003, 11:13 PM   #6994
posted by jdwca
BTW, my TC3 runs great except for one additional thing. I race in a very competetive class so I run some very hot motors. The problem is that even with my diff fairly tight the plastic outdrives can at times melt from the temp of the diff rings. I've ordered IRS aluminum outdrives and I think they'll work fine. Anyone have any experience with these or other solutions they've used?
I do like the aluminum outdrives over the plastic ones, had the same trouble with the diff rings in the plastic drives melting the retention notches so the rings would slip around. I use the Niftech units but either ones will require the use of either the IRS pin drives or the Niftech pillow drives. If you do not use either of those the round steel pin in your cvd will gauge the aluminum in the outdrive fairly quickly creating a lot of slop.
Fasttrak is offline   Reply With Quote
Old 11-26-2003, 05:24 AM   #6995
Jon Williams's Avatar
Thanks to all who responded. I'll look into the bearings as well.
Anyone have the info on the helicoil thingy yet?
Jon Williams is offline   Reply With Quote
Old 11-26-2003, 05:44 AM   #6996
Default Manhattan Supply Link
Here is the insert:
http://www.mscdirect.com/IWCatSectio...82&View.x.y=11
And here is the tool to put them in:
http://www.mscdirect.com/IWCatProduc...5792&Keyword=Y
jcrouse is offline   Reply With Quote
Old 11-26-2003, 07:01 AM   #6997
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I recently gave up on the plastic pieces. The reason being is that whenever I would go to take the bearing off the hubs it got difficult to remove because the plastic on the end had started to deform from the stress. The bad thing is that I only ran stock with this setup.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-26-2003, 09:02 AM   #6998
BendingCornerz's Avatar
Happy Thanksgiving my TC3 family
BendingCornerz is offline   Reply With Quote
Old 11-26-2003, 11:04 AM   #6999
The tap and drill bit that come with a helicoil kit aren't standard. They're slightly larger to accomodate the coil. You really need to order the kit to get the right tap and bit.
As far as the diff goes...it sounds to me that you're just not tightening the diff enough and getting to much slip. I'd revisit the diff adjustment section of your manual.
DOTMAN is offline   Reply With Quote
Old 11-26-2003, 01:41 PM   #7000
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Default Sway-bar brace
I've seen several cars with a carbon fibre brace over the swaybar mount. Do you know who makes these braces?
Thanks,
Arvid
Airwide is offline   Reply With Quote
Old 11-26-2003, 11:51 PM   #7001
fatbear's Avatar
Send a message via Yahoo to fatbear
Hi I am new to the forum, I hope someone can help me out.
I have been racing TC3's ever since they come out in the modified class. I am just in the process of putting a new chassis on one of my cars and have noticed that there is a spot that binds badly when you rotate the diffs in the front and rear housing. It is only when bothe diffsa nd the drive shaft are installed. I have always noticed a small amount of binding in the gearboxes but never this bad. Has anyone got any ideas or maybe solved this problem. I am running Factory team cars with the plastic diffs and the aluminium drive shaft. Also I have noticed that it is even worse with the one way in.
Fatbear
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 11-27-2003, 12:35 AM   #7002
OleC's Avatar
Default Re: Sway-bar brace
Thanks,
Arvid
I saw one on Victor Wilck's (sp?) car at the Procar Open last weekend. He said he got it from Joel Myrberg who bought it in Japan.
He didn't know who made it though...
I have been looking for one as well.
Please post it here if you find it.
Regards
JQ The Car Black Edition - O.S. - BUKU - AKA - Byron - Sanwa - Sav÷x
No sponsors. I drive what I like, and so should you
OleC is offline   Reply With Quote
Old 11-27-2003, 12:51 AM   #7003
lee82gx's Avatar
Fatbear
it could be ur bevel/diff gears are stripped.otherwise check the bearings.
BTW , welcome.
lee82gx is offline   Reply With Quote
Old 11-27-2003, 01:04 AM   #7004
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
hey, lets all post our pictures of our TC3's or any other cars for the holiday season
I'll try to get some taken
tc3stocker is offline   Reply With Quote
Old 11-27-2003, 04:19 PM   #7005
fatbear's Avatar
No it is not stripped gears or bad bearings. I have run these cars at a very high level for along time now and I know the TC3 inside out but I haven't been able to sought out this problem.
Any other ideas.
Fatbear
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
