Old 11-18-2003, 05:49 PM   #6916
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I have actually been told the black one does a better job. And seeing that most of the AE Guys down at snowbirds ran the black one must mean that it is good
mike_Webb is offline   Reply With Quote
Old 11-18-2003, 06:13 PM   #6917
fathead's Avatar
I have drilled holes in my blue clipon heatsink in line with the vents in the can and it definitely runs cooler with the heatsink
Slavich Design
fathead is offline   Reply With Quote
Old 11-18-2003, 07:43 PM   #6918
protc3's Avatar
check out my new bumper brace
protc3 is offline   Reply With Quote
Old 11-18-2003, 07:57 PM   #6919
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
protc3, that looks awesome!!!
One thing that I wished AE did was used the same positioning for the body posts that are on the electric as the nitro car. This way everything would have lined up and you could have had a more secure system. I do like protc3 setup though!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-18-2003, 08:46 PM   #6920
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Now that is one thing I may need to order from you guys... , I am going to be emailing you.
=MisFitz= NuKe is offline   Reply With Quote
Old 11-18-2003, 08:53 PM   #6921
tnstantheman's Avatar
Send a message via AIM to tnstantheman
Default mazda 6
its that not a awsome body
tnstantheman is offline   Reply With Quote
Old 11-18-2003, 08:57 PM   #6922
Default another pic
Wow I have to have one
Old 11-18-2003, 09:12 PM   #6923
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: Heat Sink
Originally posted by RL Junior
Hi,
This may or may not have been asked before, but here goes.
Ok, I understand that the radial heat sink (that clips directly on the motor) would actually increase heat because it blocks the vents, so I dont plan to use that. I have the Team kit, and it has the standard small black heatsink attached on the motor mount, would the FT motor mount (the larger blue one) provide better cooling, or is it even noticeable ?
I took a black one, and cut off all the "fins", and left a light weight alumimium motor clamp...
Bubblestc3 is offline   Reply With Quote
Old 11-18-2003, 09:16 PM   #6924
I hope that the new Mazda 6 body will handle better than the "other" Alfa body that is soooooooo great here at SoCal...
Old 11-19-2003, 08:34 AM   #6925
DaveW's Avatar
Proficar403: You have a PM! Im plannin a trip your way for practice... talk to ya soon!
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 11-19-2003, 08:56 AM   #6926
lee82gx's Avatar
I have the IRS spur adapter and it wobbles a lot.
it does straighten(or flatten) out after the motor spins faster.
is that normal?
lee82gx is offline   Reply With Quote
Old 11-19-2003, 09:57 AM   #6927
raffaelli's Avatar
Who makes aluminum hex nuts?
raffaelli is offline   Reply With Quote
Old 11-19-2003, 10:23 AM   #6928
tc3rookie's Avatar
Default hex hubs
i think AE makes the alluminum hexes. i've got a set and they are hex on the wheel side and taper to round, probably to lower rotating mass. anyhow, they do make the drivetrain less slopfull. the're not expensive. i'm 95% sure they're assosiated, but i don't see them on the tc3 parts list. my LHS had them once. maybe ask assosiated.
tc3rookie is offline   Reply With Quote
Old 11-19-2003, 04:47 PM   #6929
is that normal?
IRS aluminium spur adapter?
If that is the case, then slight wobble is ok, but when it wobbles so much that the spur strips/slips then that is not good. The same goes for the plastic one. Another thing to add, make sure that the berring cap(in front of the spur gear) is tightened, so that the spur will have less wobble. And depending on what spur gear you are using, it might have wobble itself.
Old 11-19-2003, 05:00 PM   #6930
Here is the part number for the aluminium hex's...
3972 TC3/NTC3 Blue Aluminum Wheel Hex Adapters
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
