Old 11-17-2003, 06:58 PM   #6901
Smile Move Battery To Center
Can somebody please tell me how much to cut the chassis to move the
battery to the center
flbugboy is offline   Reply With Quote
Old 11-17-2003, 07:08 PM   #6902
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
well, i forgot exactly how much i took off, keep going till your batts almost touch the shaft
=MisFitz= NuKe is offline   Reply With Quote
Old 11-17-2003, 07:09 PM   #6903
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I cut half out of the mid brace and move it over. The batteries will rub the shaft without any battery bars on the batteries..With Battery Bars the shaft is about 1.5-2mm from the shaft
mike_Webb is offline   Reply With Quote
Old 11-17-2003, 08:02 PM   #6904
protc3's Avatar
my batteries are about 1/8 of an inch away from the driveshaft in front position and about .030 of an inch away from outdrive in the rear position.this is the way my chassis comes cut.the battery slots are also moved a little bit forward so under certain track condition,the rear can be utilized.i personaly run them in front position.rear felt good i just like having a little extra front bite
protc3 is offline   Reply With Quote
Old 11-17-2003, 08:05 PM   #6905
protc3's Avatar
you can go to bmiracing.com for some pics at different angles
Old 11-17-2003, 09:25 PM   #6906
tc3rookie's Avatar
Default tir screws
TiR titanium screw kit! pretty expensive, but all use 2.5 mm (or something.) lighter than stainless, stronger than alluminum.
tc3rookie is offline   Reply With Quote
Old 11-17-2003, 09:39 PM   #6907
Speedie's Avatar
Originally posted by SpeediePHATT
Mister crash
This is the place ya want to look this guy took all the guess work out of doing alot of the mods ppl do the tc3. He put alot of work into his site.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-17-2003, 10:52 PM   #6908
Arun's Avatar
Has anyone else tried the tobee craft hardened steel cvd bones from speedtechrc? I have had great experiences with them so far; they seemingly have no wear and are very light considering they are steel. Not to mention they are only 11 bucks.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 11-18-2003, 02:26 AM   #6909
ae4ever's Avatar
what is the part # for the steel cvd
ae4ever is offline   Reply With Quote
Old 11-18-2003, 08:26 AM   #6910
Arun's Avatar
42200, heres a link, just scroll down:
http://64.70.208.72/speedtechrc/185.html
Old 11-18-2003, 12:52 PM   #6911
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: Need help to measure toe in/out!!!
Originally posted by TAC3
I have a eagle racing gauge to measure the front toe in/out , but i am just wondering, do u guys measure the front toe in/out while the radio is on or the radio has to be off when measuring the toe?
because one of my friends told me that I should turn the radio on when measuring my toe, but everytime I move the steering the degree changes (cause me a headache), any tips for me?
Thanks guys, apreciate ur help
To horatio , thanks for the essay
Trust me, you're not insane. What you're seeing is Ackerman. Ackerman is designed into every car and turns the inside tire slightly MORE than the outside tire because it actually turns a tighter circle than the outside tire does. An exceptional article to demonstrate this principle can be found here: RCTek.com
So - you want your steering centered to measure toe-in. I don't turn on my radio (bad habit at the track and it's not always centered. . .). With my TC3, I look underneath - there's a little hole that is centered underneath and just slightly behind the steering rack - if you look through it, you can see the screwhead that goes through the cam portion of the rack. When you can stick a 1/16th (I think) driver into that screwhead via that hole, you're centered! No radio, centered. . .
Now, for a shortcut to that - take an Xacto knife and scrape the top edges of your steering rack on either side of the driveshaft (once you've gotten it centered) - now you have a view from above. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-18-2003, 02:47 PM   #6912
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: Move Battery To Center
I normally cut right down the center of the "X" truss. If that is too close(or if you get too close to the shaft), then just add some strips of lexan, or foam to move the battery away from the shaft. When the chassis is cut, I like to leave the battery in the "front" position, because of more clearence for the drive cups.
Bubblestc3 is offline   Reply With Quote
Old 11-18-2003, 03:19 PM   #6913
JasonC's Avatar
Trader Rating: 120 (100%+)
great tip boomer
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 11-18-2003, 03:52 PM   #6914
Mikey Hudson's Avatar
TC3 Alfa Romeo
Mikey Hudson is offline   Reply With Quote
Old 11-18-2003, 05:43 PM   #6915
RL Junior's Avatar
Default Heat Sink
Hi,
This may or may not have been asked before, but here goes.
Ok, I understand that the radial heat sink (that clips directly on the motor) would actually increase heat because it blocks the vents, so I dont plan to use that. I have the Team kit, and it has the standard small black heatsink attached on the motor mount, would the FT motor mount (the larger blue one) provide better cooling, or is it even noticeable ?
RL Junior is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
