Old 11-13-2003, 01:17 PM   #6841
Horatio's Avatar
Speedxl:
Yes, you can, but they are assymetrical - one edge has more material along it than the other, thus the steering to the left is impaired. And impaired is the right word to say, as 'assymetrical static steering' is just a theoretical opinion as far as I'm concerned - I really doubt this was 'designed-in' to the parts as the 'theory' suggests. I just don't buy it!
I might be hugely out-numbered, but at least I'm not alone and I'm certainly not going to be a sucker and just follow the crowd on this!!
Also, why are people using the losi arms and carriers? Hmmmmm!! I wonder!! (BTW, I only just found out about this!!)
Horatio is offline   Reply With Quote
Old 11-13-2003, 01:55 PM   #6842
speedxl's Avatar
R/C Tech Charter Subscriber
horatio i didnt say it was design into it for handling or turning reasons i said it was a part of the manfacturing cost to do it this way because they didnt want to make an extra mold for two c hubs. mind you this is my theoritical guess on this because i do know that these molds are expensive to make and they do wear out with time.
thats what i was trying to let you know ealier .
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 11-13-2003, 04:24 PM   #6843
Horatio's Avatar
Thumbs up
I understand what you are saying.
It's just that had they designed the 0 degree carrier to be symmetrical, it COULD STILL be used both sides with just one moulding tool, but without the existing 'less steering to the left' problem.
I also agree that AE decided it would make more economic sense to just live with the inadequacies with the shared left/right 0 degree c carrier, rather than go back to the CAD system and make another moulding tool.
Hope that makes sense!
Old 11-14-2003, 07:09 AM   #6844
Default To everyone
Hey thanks for the reply guys, I really appreciate it
To Horatio
dude u look very pro, any tips for me, so that I can win with my TC3, how is the race over there (whereever u are)?
TAC3 is offline   Reply With Quote
Old 11-14-2003, 08:15 AM   #6845
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Well, it makes complete sense to me, but then you and I've been saying the same thing on this subject for aeons!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-14-2003, 12:26 PM   #6846
tc3rookie's Avatar
Default toe in
is there an easy way to approximate front toe in without a gauge? i mostly try to eyeball it and hope it's pretty equal. i have the rack centered and the wheels look pretty equal, about 2 degrees. i'm thinking of investing in a gauge, but i'm still debating rthe purchase and need my car race ready by Sunday's race.
tc3rookie is offline   Reply With Quote
Old 11-14-2003, 12:39 PM   #6847
acyrier's Avatar
Send a message via AIM to acyrier
Default toe-in
Prabably the only way I can think of is to measure tire to tire in front quadrant of tire...then the same on the "back" quadrant of tire. If they are the same, you have 0 toe. Prabably not very easy to do. RPM makes a toe gage that helps do this, but I don't think doing it that way is very accurate. (if you can, measure from the rim and not the rubber tire.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 11-14-2003, 01:11 PM   #6848
Boomer's Avatar
Take a sharpie
place the car on a stand so all four tires are off the ground and can freewheel
turn on the controller and car
run the wheels at a slow speed - apply the sharpie to each tire so that it makes a solid single line down the center of each.
Shut the car down
Take a ruler and measure the distance between the lines at the front of the tire and at the rear of the tire
Each 1/16th of an inch is about 1 degree.
Old 11-14-2003, 02:44 PM   #6849
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Sometimes you just can't win, can you...
LOL
jk
Bubblestc3 is offline   Reply With Quote
Old 11-14-2003, 04:15 PM   #6850
Arun's Avatar
Default Re: toe in
A hudy or similar system is just something you have to buy eventually, I believe. I actually bought an rpm gauge way back, but it is actually pretty stupid and as accurate as my eyeball. It ends up being great having a hudy system, especially when setting all the trims and steering throw equal.
As I always say, go ahead and buy the best stuff, because you will end up with it sometime later anyway, only costing yourself money and agony. Ex: I bought 4 chargers before I finally bought a turbo 35.
The easiest way to measure toe w/o a gauge is to use calipers or a ruler as Boomer stated.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 11-14-2003, 04:17 PM   #6851
Arun's Avatar
Originally posted by Horatio
Proficar:
Do the losi arms allow for greater lock without having to file the carrier? I'd be interested to know.
I could set my throw with the losi blocks to the point where the cvds will bind,still not hitting a carrier, but I have it set nowhere near that close.
Old 11-14-2003, 06:43 PM   #6852
tc3rookie's Avatar
Default hudy
i have been looking into the hudy thing, and i'm probably going to have to wait till christmas so i'll make due with a calipers/ruler until then. i just hope i'm not way off.
Old 11-14-2003, 07:52 PM   #6853
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
or, if your do not have a hudy system, what you can do is put the car up vertically resting on its rear bumper, and use a camber guage., you use a small level to make sure the car is straight up and down...
=MisFitz= NuKe is offline   Reply With Quote
Old 11-14-2003, 07:52 PM   #6854
Default Measuring toe in/out
I have a eagle racing gauge to measure the front toe in/out , but i am just wondering, do u guys measure the front toe in/out while the radio is on or the radio has to be off when measuring the toe?
because one of my friends told me that I should turn the radio on when measuring my toe, but everytime I move the steering the degree changes (cause me a headache), any tips for me?
Thanks guys
Old 11-14-2003, 10:20 PM   #6855
Mikey Hudson's Avatar
this is one of my new bodies painted by skipgear, paint scheme designed by me a few years ago, but he took it to a new level with all my bodies he paints. he does an excellent job.
Alfa Romeo Body
Mikey Hudson is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
