Old 11-09-2003, 07:07 AM   #6796
lem2's Avatar
Default Flash
Originally posted by Flash Gordan
Hey lem2 you do know you can order everything straight from the IRS website. The address is:
http://www.teamirsrc.com
Probably will get your equipment faster that way.
Yep, thanks for the info! You would not believe what we have to go through to send stuff here, corrupt customs, red tape and so on. Like anything from the U.S. mailed in via the Postal system will surely be tagged, to be taxed stupendously! hehehehehe
UPS and FedEx is a lot better. But expensive.
How come KThobbies IRS parts are cheaper than the IRS website?
Hey, any news on the new IRS Chassis? I heard they were developing it?
Peace and Happy Racing!
lem2 is offline   Reply With Quote
Old 11-09-2003, 07:19 AM   #6797
lem2's Avatar
Default Spool
what will happen if I use a spool on the rear?
has any body done this? why and why not?
Old 11-09-2003, 08:09 AM   #6798
lee82gx's Avatar
if i'm not mistaken,a rear spool will induce oversteering.
lee82gx is offline   Reply With Quote
Old 11-09-2003, 11:44 AM   #6799
Super Steve's Avatar
Send a message via AIM to Super Steve
Default Re: that got hot
Originally posted by SpeediePHATT
I use an infared heat gun to tell if my gearing is ok for the motor. In my opinion ya can just gear it till it melts. A few times what felt good on the track seemed a little warm when I was done I dont like to get my motors over 150f or so. I know Ive seen on forums that others run em alot hotter but for what I do reliability is more important. thats just what my little experience has taught me.
The motor was smoking real bad
Super Steve is offline   Reply With Quote
Old 11-09-2003, 05:08 PM   #6800
Michal101's Avatar
Default YOK shaft
A buddy of mine has both the Yok SD and the TC3 and he just told me that the Yok shaft is 152mm pin to pin and the TC3 170mm pin to pin. That's a pretty big difference.
Please let me know otherwise.
Mike
Michal101 is offline   Reply With Quote
Old 11-09-2003, 11:10 PM   #6801
Super Moderator
Grizzbob's Avatar
I don't know the exact difference, but in essense I've been told the same thing by the local guys who have the Yok(some of which also had a TC3), so they wouldn't be interchangable....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-10-2003, 01:04 AM   #6802
KillerHurtz's Avatar
You could pop the pins put of the Yok and get a longer piece of graphite if your looking for weight savings.
KillerHurtz is offline   Reply With Quote
Old 11-10-2003, 01:16 AM   #6803
tnstantheman's Avatar
Send a message via AIM to tnstantheman
Default TC3 mods
Hello does anyone have a template and instructions for the nitro tc3 upgrade I would like to try it what does it do o the car
I have ran irs spool if i used the stock cvds it would chip the outdries making it look like a 10 year old outdrive in one weekend
but if you use the pin cushions (irs 147 ) they last alot longer
Wow i raced this weekend and the TC3 was working great
its been in storage for to long Snowbirds if that gives you any idea . I put Electrics in it and took it to the track didnt have time to noch all the dust off of it LOL , Man I was so rusty in the 2nd heat i tried to hit a turn marshall so could say i hit everything.I cant believe i TQ . I had only one decent run with 4 mistakes
I guess i was less rusty than everyone else . The main was wild i was gone lead the whole race with the dust buster in tow it was nice to beat all the yok sds and barracudas the tc3 is still a great car if it ant broke dont fix it all i replaced the whole night was one ball cup that had some play the yoks had a bad night broke alot of them i felt sorry for the guys I dont think there is a ft spindle left in TN that is not on a car I ran my foams from last yr 57mm yeah there small but man the car ran good at 5mm ride hieght its was fast through the corners I could carry a ton of speed I had to dial out alot of steering the car had 47% it took alot of room to turn it aroung in low speeds but on the trottle it was on a rail
Does anyone else have that problem if it is one
Thanks all if anyone needs my setup for carpet email me i have a easy to drive rolling throttle setup that works well for me on foams thanks Stan
tnstantheman is offline   Reply With Quote
Old 11-10-2003, 12:07 PM   #6804
acyrier's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
Default Diff Rebuild...
I'm getting ready to rebuild my diff in my TC3 for the 1st time. Anybody have any thoughts on Cermic bearings, and outdrives. I'd like to replace the workings inside both front and rear.
Right now, I'm thinking about getting the FT blue alum. outdrives w/ceramic balls. and using the standard diff rings.
Any thoughts/opinions would be great.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 11-10-2003, 01:21 PM   #6805
Speedie's Avatar
What kind of hubs are you running now? I would just run a lightweight hub if your building it strictly for racing, if your worried about wearing out parts then go with the aluminum. the difference between the old steel diffs and the lightweight is 28 grams for steel compared to 12 grams for the light style. Im not sure what an aluminum one would weigh. Maybe someone can weigh one for ya.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 11-10-2003, 02:09 PM   #6806
tc3rookie's Avatar
Default rear bumper
the rear bumper that sticks out the back of the car seems pretty pointless in racing w/o reverse, couldn't i just dremel off the bumper part and leave the bit that supports the diff case and rear thing that the hinge pins go into with no ill effects?
tc3rookie is offline   Reply With Quote
Old 11-10-2003, 02:17 PM   #6807
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It's useless if you're hitting things, but it's useful for when you're getting nerfed (hit from behind).
The NTC3 does not have a bumper that extends rearward and, in some cases, I wish it did. I've been taken out by getting nerfed (some numbnuts who didn't think he had to brake for a hairpin) and getting the rear toe-link bent.
In any case, it doesn't weigh much, doesn't interfere with anything. I'd leave it in.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-10-2003, 03:57 PM   #6808
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: YOK shaft
Mike
This is like comparing Apples to Oranges. Yes, the Yokomo SD drive shaft is shorter than the TC3's drive shaft. But the Yokomo drive shaft FOR the TC3 is the correct length.
Bubblestc3 is offline   Reply With Quote
Old 11-10-2003, 05:05 PM   #6809
acyrier's Avatar
Speedy:
I'm currently running the old "steel" diffs. I just installed new IRS "Big dawg" bones taht have the pin-coushings. I'm not the greatest driver and do skim a wall once in a while. Will the lightweight Durlin otudrives stand-up to that? (I don't SLAM the wall..just once in a while...graze it) Also wondering if the ceramic diff balls are with the extra cash.
Old 11-10-2003, 07:47 PM   #6810
Michal101's Avatar
Default Re: Re: YOK shaft
Bubblestc3,
Are you referring to Yok part # SD-644G?
Mike
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
