Old 11-08-2003, 05:03 PM   #6781
speedxl's Avatar
R/C Tech Charter Subscriber
irs axle stink just scrape the wall and there it goes there is no
advantage to using them and as far as the spools
i seen guys that can make the a main at a national and disentergrate a spool . these parts are just as prone to breakage then the factory parts the irs axles are diffinatly a cheaper buy!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 11-08-2003, 05:09 PM   #6782
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Any of yall have experience gearing an Orion Core Stock for the TC3? Advice would be most appreciated
trackdesigner71 is offline   Reply With Quote
Old 11-08-2003, 07:33 PM   #6783
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
td71,
When the KO GP was at SoCal in June, I raced with a 6.94 overall(a core based handout motor), which was 36/100 in 64pitch gears.
Bubblestc3 is offline   Reply With Quote
Old 11-08-2003, 07:35 PM   #6784
tc3 racer sc's Avatar
Default who got the best ceramic bearings for tc3
where can i fine the best ceramic bearings any website or hobbystore have thm please post
tc3 racer sc is offline   Reply With Quote
Old 11-08-2003, 07:49 PM   #6785
You should check out acerracing.com , they have cerimic berring kits for the TC3.
Trinity should also have some cerimic berring kits for the TC3
Old 11-08-2003, 09:50 PM   #6786
Super Steve's Avatar
Send a message via AIM to Super Steve
My friend smoked his Monster stock with stock spur (72 48pich and 26 48pitch pinion)
The manual reccomends 28 so 26 should be safe i would think?
Was it because his motor had a defect?
O well... at least I TQed and took first...
Super Steve is offline   Reply With Quote
Old 11-08-2003, 10:04 PM   #6787
That's not too high. I gear mine 75/28, which is 6.69 GR, 72/26 would be 6.92. That is just about right from what the guys around here are running.
nitromike is offline   Reply With Quote
Old 11-08-2003, 11:03 PM   #6788
some pics of the armature
Old 11-08-2003, 11:08 PM   #6789
Pic 2
Old 11-08-2003, 11:10 PM   #6790
lastpic
Old 11-08-2003, 11:51 PM   #6791
Speedie's Avatar
Default that got hot
I use an infared heat gun to tell if my gearing is ok for the motor. In my opinion ya can just gear it till it melts. A few times what felt good on the track seemed a little warm when I was done I dont like to get my motors over 150f or so. I know Ive seen on forums that others run em alot hotter but for what I do reliability is more important. thats just what my little experience has taught me.
Speedie is offline   Reply With Quote
Old 11-09-2003, 12:36 AM   #6792
lee82gx's Avatar
might be the drive train is binding.too much load will cause shorting/smoking/frying,as the current can't be converted into motion,thus it converts to heat.
i've geared my stockers(27T) up to mid 5's and 23T stockers into high 5's,no problem as long as there was sufficient cooling between packs.
lee82gx is offline   Reply With Quote
Old 11-09-2003, 12:41 AM   #6793
lem2's Avatar
Default Re: Re: QUestion
Originally posted by Flash Gordan
I know Dave Irrgang personally and know everything he makes can take one hell of a beating. His stuff is almost damn near indistructible. How did you ruin 2 spools?
Yes I agree, I use a lot of IRS products and Love them!! Call it stupidity that's why I ruined them, hehehhe I ran out of Pin Cushions, thats how. No place to buy IRS Pin Cushion here. Just order, I have around a dozen already just waiting for my cuz to come here and visit.
But I broke one when I clip a corner, when the arms broke,one of the wing on the outdrive gave way.
Incidentally I use, IRS Side Braces, Drive cups, spur gear holder, trans. holder and so many more-- all from IRS!
Peace and Happy Racing!!
lem2 is offline   Reply With Quote
Old 11-09-2003, 05:51 AM   #6794
berger's Avatar
Ive run my monster geared low and high and it seems okay, ive been going pretty fast with it so far.
berger is offline   Reply With Quote
Old 11-09-2003, 06:50 AM   #6795
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Hey lem2 you do know you can order everything straight from the IRS website. The address is:
http://www.teamirsrc.com
Probably will get your equipment faster that way.
Flash Gordan is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
