Old 11-05-2003, 05:37 PM   #6751
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: shaft
Originally posted by tc3rookie
i'm running the woven shaft again and am wondering what shaft the yokomo is, pt. #? is it a direct fit? thanx
tc3rookie,
The Yokomo shaft is a direct replacement. I myself was amazed!!!! As for part number, I do not know it at the time, but I will try to find it for you.
Bubblestc3 is offline   Reply With Quote
Old 11-05-2003, 05:44 PM   #6752
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
What would the Yokomo shaft do different?
Intermision is offline   Reply With Quote
Old 11-05-2003, 05:47 PM   #6753
The slop in your servo is somewhat similar to your gear mesh with the motor. Too tight, and the servo will bind, too loose, and the servo will strip gears. As metal gears in a servo wear, there becomes more and more slop.
Another thing to consider is what servo horn you are using, which you are using an aluminium horn, and check the slop in that. The servo mounts are another thing to consider with slop that apperently comes from the servo, and how tight they are on the servo.
Old 11-05-2003, 05:49 PM   #6754
The bones of the shaft are aluminum(that connect into the drive cups), and the accual shaft is carbon.
Old 11-05-2003, 05:52 PM   #6755
mistercrash's Avatar
R/C Tech Charter Subscriber
when you made that brace for the center, what thickness of CF would be good?
2 mm
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 11-06-2003, 12:16 AM   #6756
tc3 racer sc's Avatar
Default thxs mike d
hey thxs for setup mike d i race with u at durham i cya in clevland
tc3 racer sc is offline   Reply With Quote
Old 11-06-2003, 01:19 AM   #6757
sars125's Avatar
Default Re: setup info
Originally posted by hyperformance
http://www.mpowered-racing.com/mpowchassetg.html
http://home.tiscali.be/be067749/58/
there are others
Tanhx it's this a site wich can help me a lot
Greetz lars from holland
sars125 is offline   Reply With Quote
Old 11-06-2003, 12:58 PM   #6758
tc3rookie's Avatar
Default slop
the servo arm is not very old and i had this same problem with another arm. i'll check the slop in the gears. if there is, would a new gear set fix it?
tc3rookie is offline   Reply With Quote
Old 11-06-2003, 05:03 PM   #6759
It depends on the ammount of slop that it has right now. If there is a little, then new gears will not help it(it should be the same), but if there is a bunch of slop, then new gears will fix most of the slop.
Old 11-06-2003, 08:06 PM   #6760
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
I know I should search this out on my own but does anybody have a list of modifications that have been discussed in all the pages of this thread?
Flash Gordan is offline   Reply With Quote
Old 11-06-2003, 10:21 PM   #6761
Default Re: slop
just remember to replace the ball caps and ball studs too ,, this should help alot .. even with a worn servo,, you may still have alittle slop but you cant just change one thing ,, sometimes its ok. but its better to change it all then youll have a better out come.. my 2cents...goood luck ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 11-07-2003, 12:10 PM   #6762
tc3rookie's Avatar
Default servo arm
it turns out the ridges in the arm and on the servo didn't match very well, so i replaced the alluminum one with a plastic and it works really well now, almost no slop. the rack isn't as free as i'd like but i fixed it a little and now it's a lot more free than be4.
Old 11-07-2003, 04:35 PM   #6763
The major things that have been discused in the past have been:
Rear shock tower up front, chassis refinements, Nitro steering system, drivetrain, spool's, and one-ways.
But then again, I have only been on rctech for two or three months...
Old 11-07-2003, 05:16 PM   #6764
berger's Avatar
I have my own mod, for my rpm bumper, the middle two holes which the diff sits through i cut slits in so that i can just undo the two screws holding the front arm mount on and pull the bumper off, saving undoing the diff, this way if you break a front wishbone its really easy to change it fast. Also i just sand my hinge pins down a little bit until they are steel coloured and not black, allows the wishbones to drop freely.
berger is offline   Reply With Quote
Old 11-07-2003, 05:17 PM   #6765
berger's Avatar
If i can be bothered ill take a picture of my bumper tomorrow.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
