Old 11-04-2003, 05:35 PM   #6736
Default tc3 chassis
heres a nice looking and great handling chassis go to speedlinehobbies.com look for the bmi chassis
Darrell is offline   Reply With Quote
Old 11-04-2003, 06:04 PM   #6737
Super Steve's Avatar
Send a message via AIM to Super Steve
I used parts from my truck to quickfix the hub problem...
So i don't need those parts anymore bubble! thanks for helping though
Super Steve is offline   Reply With Quote
Old 11-04-2003, 06:59 PM   #6738
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Ok Steve, glad that you fixed it.
Bubblestc3 is offline   Reply With Quote
Old 11-05-2003, 02:33 AM   #6739
sars125's Avatar
Default tc3 starter
Hello everybody,
I'm have a qeustion about setup the car.
Last year I drive the corally c10 and it went very well, but this year i will try to drive the tc3 but now i have to learn al lot about what to do when your car has no steering. Or when it is too much.
But also wat happens when you put a harder spring or a softer.
And a lot of that kind of stuff, so is there a site where they give a good lessons for touring cars. I.m going to drive a tc3 Factory team.
Greetz lars from holland
sars125 is offline   Reply With Quote
Old 11-05-2003, 07:47 AM   #6740
hyperformance's Avatar
Default setup info
http://www.mpowered-racing.com/mpowchassetg.html
http://home.tiscali.be/be067749/58/
there are others
hyperformance is offline   Reply With Quote
Old 11-05-2003, 09:31 AM   #6741
tc3rookie's Avatar
Default shaft
i'm running the woven shaft again and am wondering what shaft the yokomo is, pt. #? is it a direct fit? thanx
tc3rookie is offline   Reply With Quote
Old 11-05-2003, 09:45 AM   #6742
Send a message via AIM to vere513
how is graphit shaft suppose to be better than the alum one? i would think alum would be lighter its what im runing sence i got my car never broke one
vere513 is offline   Reply With Quote
Old 11-05-2003, 10:05 AM   #6743
tc3rookie's Avatar
Default shaft
vere513:
the Alum. shaft is 3 grams heavier, frobably because of more material being used. also, the graphite shaft is better because of it's rigidity, it cannot bend like aluminum, and a bent alum shaft is also sometimes hard to notice but it vibrates the car, which is bad. and the alum. shaft bends really easily. it also has less rotating mass so the car gets better acceleration.
Old 11-05-2003, 10:32 AM   #6744
sars125's Avatar
Default shaft drive
What about the titanium shaft on the speed tech site.
Titanium Racing Light Weight center shaft for NTC3. This titanium main shaft is lighter and stronger than the stock one.
This is a part of schumacher.
http://www.sslorder.com/speedtechrc/192.html
Old 11-05-2003, 10:36 AM   #6745
tc3rookie's Avatar
Default titanium
the titanium shaft is probably stronger, but titanium is more dense than aluminum, and therefore heavier, which means it would still have more rotating mass than the hollow woven shaft and probably costs more. however if streingth is more important to you than mass it's the perfect choice. also one titanium shaft i'v seen was thicker than the alluminum. i'd still say woven is the way to go.
Old 11-05-2003, 11:05 AM   #6746
tc3rookie's Avatar
Default servo
Raymond (mistercrash),
on your website, you have a servo placement mod section. i'm probably wrong, but couldn't that be done by putting the servo mounts on the front side? if not, what is the differance? btw, nice chassis brace mod.
Old 11-05-2003, 01:20 PM   #6747
Default servo mount
i moved my servo back by placing the mounts to the front of the servo. it make steering adjustments and servo horn replacement much easier.
Old 11-05-2003, 04:10 PM   #6748
mistercrash's Avatar
R/C Tech Charter Subscriber
Default Re: servo
You're absolutely right, the servo mounts can be mounted in front of the servo and that was my first idea at that time, but it placed the servo too far back and it took away to much room in the back of the servo to put my ESC (Cyclone) and neatly tuck away the wires. I decided to drill two new holes 3/16 of an inch back from the original holes on my TC3 to give me a couple of millimeters more in the back of the servo for my ESC. I could've used the servo mounts in front by placing my ESC perpendicular to the chassis but I like it longitudinal and close to the center because I like to complicate things for myself
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 11-05-2003, 04:21 PM   #6749
tc3rookie's Avatar
well that makes sense. ok i'm satisfied. also, when you made that brace for the center, what thickness of CF would be good?
Old 11-05-2003, 04:23 PM   #6750
tc3rookie's Avatar
i traced a huge amount of slop in the steering back to the servo arm. the arm is alluminum and i have a ko propo fet powerservo with all metal gears, so i think the slop is electronic. it seems to allow the arm to move a bit in both directions before applying power. what could be the problem? also i have an XS3
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
