Old 01-04-2002, 09:43 AM   #661
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
TP > Thanks for the info!!! As I get one, I'll let you know. Do you work every day there or just occasionaly?
Ultimate this Sunday if you can go.
wolfeman09 is offline   Reply With Quote
Old 01-04-2002, 10:12 AM   #662
TPhalen's Avatar
R/C Tech Charter Subscriber
Mon-Wed, and every other sunday
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 01-04-2002, 11:10 AM   #663
johnbull's Avatar
Hi guys. Greetings from Malta.
Buda, Being in England you shouldn't find any difficulty getting stuff for TC3s.
I have most items in stock in my store but I'm miles away. I've sold quite a few TC3s so I keep a good stock of bits, especially since son Josh runs one too.
If you're still stuck, ket me know.
Regards
Joe from sunny.....but cold Malta.
johnbull is offline   Reply With Quote
Old 01-04-2002, 11:12 AM   #664
Greg Amendola's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to Greg Amendola
Default Shaft
As Tony will agree, the car requires no upgrades beyond the addition of a front one-way for ruber tire racing. In comparison testing, no aftermarket shaft was as light as the stock shaft. The Niftech Ti was the closest we could find. This means that any shaft you put in will increase rotating mass and thus reduce acceleration.
Greg Amendola is offline   Reply With Quote
Old 01-04-2002, 12:57 PM   #665
Buda's Avatar
yea thats my thoughts too If I am going to loose weight it will be from rotating mass and if I need to add it will be to structeral components
Buda is offline   Reply With Quote
Old 01-04-2002, 11:22 PM   #666
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Question...i have started running my tc3 on Ozite w/rubber tires, and it is hooking coming into sharp corners...i have been running on high traction asphault w/ no problems...so i didnt make many changes...settings...droop 6fr./4rr.......r.h.-5mm......(sw iwc shocks)40wt.fr./30rr........copper fr./red rr......batt. back......links-up and in......shocks in on top....sway bar on front.....any suggestions thanks
Dragon Slayer is offline   Reply With Quote
Old 01-05-2002, 06:27 AM   #667
Well using the losi shocks really changes the damping because the pistons are 3 hole, so that makes it really hard to judge. But I think you need to try some heavier oil. Red and Copper springs are in the ball park too.
patcollins is offline   Reply With Quote
Old 01-05-2002, 07:00 AM   #668
Dragonslayer,
For your setup on carpet, change your springs to Gold up front, and Blue in the back. Run your battery forward, with the foam spacer in the back slot, and put the swaybar on the rear while removing the swaybar from the front. Your tires will make a considerable difference on carpet. I suggest you run Sorex 24 at all four corners, or even 20 on the back. Why are you running the SW IWC shocks on your car? Your oil is right on, but I wouldn't have any clue what piston you are running. If you were running the TC3 shocks, just run the #2 pistons.
This should help considerably!
Greg
Greg Anderson is offline   Reply With Quote
Old 01-05-2002, 07:09 AM   #669
Buda's Avatar
Default first race
well dudes Sun will be my first race and here is what I will use for my set ups approximately..
It is on Astro turf they run the Scumacher mini pins at the track. I will start with the stock set ups but will drop ride hight to 5mm I only have the 40 wt. oil so I will have to go with that since the track is smooth I may try going up 1 spring on fnt and rear I will also be running a 17x3 which is about normal for the track unless you are really good since it is a bit small and usually twisty If anyonbe has raced astro tuf b4 do you have any set up ideas or am i on the right track? I also have the roll bars to help dial out/in front or rear traction as needed. or do you tgink I should run them both ends people also tend to traction roll there sometimes.
Old 01-05-2002, 09:35 AM   #670
The reason for the SW shocks is i got the tc3 team kit, therefore i didnt have the threaded shock bodies, since i already had the sw-iwc so i just swapped shocks...i noticed the losi pistons have larger holes,i'm guessing to get the same dampning i would have to go to thicker oil.
Greg... the manual says batt forward=more front traction and sway bar on rear= more front traction....i need rear end traction.
I've had the sw shocks on the tc3 for awhile and have had no problem with traction on other surfaces with 40 fr./30 rr.(oil).... on the Ozite it just acted like a different car?????
Thanks for the help
Old 01-05-2002, 10:36 AM   #671
Usually with carpet you run thicker oil than on asphalt.
Old 01-05-2002, 08:27 PM   #672
wolfeman09's Avatar
Dragon > I think you set up is to soft. When i was racing on carpet i had the AE White Springs in front and Golds in the Rear. Thicker Oil is needed as well. Get rid of the Losi stuff as well
Also check out this website, www.competitionx.com, TP has a basic carpet set-up that should get you going. Also, i am sure AE site has a carpet set-up as well.
Old 01-05-2002, 08:51 PM   #673
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Wolfman hit an extra comma in his link. Here it is again- Competition X
BigDogRacing is offline   Reply With Quote
Old 01-05-2002, 09:05 PM   #674
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Moving the battery forward will often keep the rear end from swinging around......like pendelum effect.
If the rear end is too soft, adding a swaybar will keep it from 'dumping over' and breaking loose.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 01-06-2002, 05:51 PM   #675
wolfeman09's Avatar
Doh!!! thanks big dog, i wonder how that got there.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
