Old 11-03-2003, 05:44 PM   #6706
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Originally posted by Super Steve
MY freind's TC3 arrived to my house this morning.
The frontright is trashed. Wheel hex pin is BROKEN and the metal bushings are gone and the top kingping/ball stud is bent.
Can anyone be SUPER SUPER nice and maybe send the spare metal bushings to my house?
Do you mean the berrings?
Bubblestc3 is offline   Reply With Quote
Old 11-03-2003, 05:57 PM   #6707
Super Steve's Avatar
Send a message via AIM to Super Steve
I meant the bushing that the kingpin/ball spins on.
The black bushings.
Just put it in a zip lock bag, then envelop then put like a 70 cent or so stamp and that's it!
Super Steve is offline   Reply With Quote
Old 11-03-2003, 06:03 PM   #6708
Originally posted by Intermision
I will be gettinf a FT TC3 for christmas, and everybody at my track uses a one-way, but I can't find one for the tc3.
I use the HD one-way from ae, which is part number 1728, and should be about $60...
Old 11-03-2003, 06:06 PM   #6709
The black bushings.
Now I get it, I was thinking the berring, but the bushing for the C carrier. I need to go and look for them, I bought some but I do not know where they are....
Only one?
Old 11-03-2003, 06:42 PM   #6710
tc3rookie's Avatar
Default chassis
i want to cut the chassis center brace in order to put the batts farther in is there any tips on how to better do it without a mill or anything ( i read the tip on Mistercrash's website.)? btw, where can i get woven graphite or similar for the upper deck idea on the site? is there another car's option part that i could cut it out of etc.?
tc3rookie is offline   Reply With Quote
Old 11-03-2003, 06:46 PM   #6711
Send a message via AIM to vere513
Default duratrax teflon bearings
are the duratrax teflon bearings good the racer kit bearings cost like 100 dollars and durtrax is 30 for the same amount are they good and worth the money?
vere513 is offline   Reply With Quote
Old 11-03-2003, 06:56 PM   #6712
Default Re: duratrax teflon bearings
ae part number 3975 is the complete berring set for the TC3 Racer kit/RTR kit, and is only $50...
Now for the Duratrax berrings, you say teflon, personally I have never used them, just good old ae berrings in my ae cars(although I have heard many good results with acer).
Old 11-03-2003, 06:57 PM   #6713
mistercrash's Avatar
R/C Tech Charter Subscriber
Default Re: chassis
You can get carbon graphite sheets from Art's Hobby or Penguin R/C
Art's Hobby sells plates in four colors (black, blue, silver, gold) which are very nice but I suggest Penguin R/C plates as they seem stiffer and of better quality.
mistercrash is offline   Reply With Quote
Old 11-03-2003, 06:57 PM   #6714
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
is this it
Intermision is offline   Reply With Quote
Old 11-03-2003, 07:00 PM   #6715
Default Re: chassis
I cut my chassis with a Dremel, as for upper decks try looking at IRS's website, or warpspeed's, they should have what you are looking for to stiffen the chassis after the cutting.
Old 11-03-2003, 07:08 PM   #6716
Dude, Intermission, I gave you the wrong part number, here this is the real part number...
3978
The other one is for the NTC3
sorry
Old 11-03-2003, 07:11 PM   #6717
I need two...
both top and bottom bushing are missing...
Thank you so much for your help!
Old 11-03-2003, 11:04 PM   #6718
xxxtracer32's Avatar
bubbles- anyone at socal run the ntc3 steering rack? or any other mods. i want to get my tc3 running again and never realy liked the stock steering rack.
xxxtracer32 is offline   Reply With Quote
Old 11-03-2003, 11:11 PM   #6719
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
tc3rookie, bubbles- checkout the thread i made called xtreme chassis. There is a pic of my car that shows how close the batts sit to the drive shaft, this car is extremely well balanced. And besides, it is awesome looking as well. I really don't think you would be dissapointed.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 11-04-2003, 02:25 AM   #6720
sars125's Avatar
Default Re: Re: my new tc3 ft
There is not much you need to do to the car, you are getting a Factory Team TC3. Some like to put the rear shock tower in place of the front shock tower(to make the car more responsive entering the corner), you might like a one way for the car(depending on what surface you are going to race on). With the new diff cases(that fit the NTC3 as well), you will want to close the hole(with a screw/setscrew) that is left open(I guess the best discription of it would be, the hole on top closest to the center of the chassis. The other hole does not go all the way through to the gears, but the "center" one does). Make sure that you do not rush through the build, there are a few spots in the manual that are a little unclear, but overall, the build should take you a few hours. If you take your time building the car PERFECT, it should take you about two days to complete.
Happy building!
Chris
Thanks for your answer.
Greetz lars from holland
sars125 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
