Old 10-24-2003, 03:02 PM   #6631
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I guess it is a matter of how well you have your gears shimmed. last year my TC3 did not have any of the gears lubed and it lasted the whole indoor season.... Cleveland..Snowbirds and a couple of other races along with club racing every weekend. Never had a stripped gear or gears that were worn out.
mike_Webb is offline   Reply With Quote
Old 10-24-2003, 03:09 PM   #6632
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
What do you mean by indoor season?
All year round I race indoors...?
Was the tranny loud?
Bubblestc3 is offline   Reply With Quote
Old 10-24-2003, 03:10 PM   #6633
Send a message via AIM to vere513
thanx alot now my car is 90 percent done on my rebuild and its really smooth
vere513 is offline   Reply With Quote
Old 10-24-2003, 04:24 PM   #6634
mike_Webb's Avatar
Hope that helps.
Out here on the east coast we race outdoors in the summer and then we go indoors for Carpet racing in the winter.
Old 10-24-2003, 05:04 PM   #6635
Ok, I get it now.
Here at SoCal every saturday and every tuesday is open to race onroad, and there is usually always racing on parking lot tracks like at oc circut, and titus, and empire raceway.
It is a shame there are no carpet tracks here in Southern California
Old 10-25-2003, 10:22 AM   #6636
Shayd's Avatar
R/C Tech Charter Subscriber
Hey Bubbles,
This is Scott from SoCal. You probably know me by sight, but not name.
This was at SoCal on Tuesday, and running stock intermediate. Gearing was same as I have been running which is 33-35/100, and this was happening the first 2 laps of the race with a cold motor.
Scott
Shayd is offline   Reply With Quote
Old 10-25-2003, 11:09 PM   #6637
Default Newcomer to TC3
Ok guys.. absolute ROOKIE here with a TC3.. so don't slam me yet... I'm learning and working with what I got.
Factory Team TC3
Novak Rooster (yeah.. its big.. but I gotta deal with it)
Monster of Touring Pro Motor
Novak XXL Receiver
HardCore Servo Mount/Transpondor mount
Take Off CS-27 Tires (pre-mounted)
Rear Shock Tower on Front
Don't slam me on my battery, its just a practice battery..
But what do you guys think about this setup?
Body Off Right Side
KansasCajun is offline   Reply With Quote
Old 10-25-2003, 11:19 PM   #6638
What is that BIG black thing over the esc, and motor(it looks like a fan, but why so big. If it is supose to blow more air, then that would suck more juice from the battery)?
And this is in no way a "slam", just wondering/curiosity/ ...
Old 10-25-2003, 11:23 PM   #6639
Bubblestc3 What is that BIG black thing over the esc, and motor(it looks like a fan, but why so big. If it is supose to blow more air, then that would suck more juice from the battery)?
Its a fan and cover from a Pentium II processor. I've got it strapped around the motor in the rear. The rest is just a "hood" or cover around the heat sinks. The wires will eventually be run to the 6 volt BEC on the receiver, I just don't have a plug that I can solder that guy up with.. so for now the wires are just "tucked" under.
Old 10-25-2003, 11:29 PM   #6640
Originally posted by Shayd
Hey Bubbles,
Scott
Hey Scott, did you race today?
And how the spurs were striping is weird!, hahahahaha. But the problem is fixed now right?
Old 10-25-2003, 11:41 PM   #6641
Now, I would assume that there is more power being lost when running this fan, than being saved by keeping the motor cool. I do not know the weather in kansas(assuming that is where you are driving this car), but I would rather have some air scoops force feeding the motor with air. It would be lighter, and use less power from the battery(which the motor looks like a Monster, so in stock you want the most voltage as possible!)...
Just a thought...
Old 10-25-2003, 11:53 PM   #6642
After taking another look at the picture, there is also a heatsink over the motor, with the longer FT blue motor clamp(in short, there is no air flowing through the motor, or to the motor). I have found that this will accually make the motor more warm, than cooling it. And that fan is really running off of 6v?(personally, the best fan for this use is a 5v computer fan and solder it directley to the esc leads...)
Old 10-26-2003, 01:27 AM   #6643
ditch both the fan and heatsink, and as long as the motor isn't overgeared, it will stay cool (or get slightly warm, but either way it won't blow up )
Rory is offline   Reply With Quote
Old 10-26-2003, 05:11 AM   #6644
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Don't ditch the heatsink. Even if you overgear the car a little and the motor gets hot the heatsink will at least draw the heat away from the motor. Do dump the fan. It's not really worth the power loss. Would rather have the power running to the motor for longer runtime.
Flash Gordan is offline   Reply With Quote
Old 10-26-2003, 06:35 AM   #6645
Send a message via AIM to lilshortyc3
I have a TC3 with this set-up:
Front:4 castor
0 kickup
1.5 camber
1 toe in
Piston #2
40 wt. blue springs
Shock mount all the way in(lowest one down)
camber link-stock
Rear:
short wheelbase
2 camber
Losi hubs 1 degree hubs reversed with F, R-3-0
Piston #2
40 wt wit red springs
everything else stock no sway bars front and rear
Batteries back, orange/purple fronts
purple rears...
and I wuz wondering if you guys have any advice to improve this set-up...turns seem to be wide
oh yeah...track is very tight and small wit no straight away
lilshortyc3 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
