Old 10-22-2003, 09:48 PM   #6586
tc3rookie's Avatar
Default big esc
there might not be room if there's a big esc. there's a lot of space on the chassis, but a big esc a big reciever and a big servo might be a bit too big. the reciever could go on it's side or on the servo and than there's enough room for a whole bunch of stuff...
tc3rookie is offline   Reply With Quote
Old 10-23-2003, 12:16 PM   #6587
hyperformance's Avatar
Default servo trick
i run the JR digital (8450 i think) but mount it further back on the chassis. put the servo mounts on the servo backward from the instructions (servo mounts at the frount of the servo) then but the ball end on the servo horn backwards (ball facing forward) this leaves room for a XXL stood on it's side behind the servo and a Cyclone in front of the motor, use the space beside the motor for your caps! the servo moved back helps many clearance issues and makes adjusting the steering turnbuckles much easier, depending on which servo you use you may need to file on the servo mounts a bit.
hyperformance is offline   Reply With Quote
Old 10-23-2003, 03:56 PM   #6588
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: big esc
I have been using the Novak GT7 in my car with no space problems. I use an Airtronics reciver, but the XXL from Novak is smaller. I also have the capiciter sitting right beside the GT7 with no problems, so I see no reason why there will be a problem with fitting the GT7 in the car. Yes, a larger speed control will provide less room for the other electronics, but DaveW was comenting about the GT7.(from my understanding)
Bubblestc3 is offline   Reply With Quote
Old 10-23-2003, 05:04 PM   #6589
Trader Rating: 28 (100%+)
Default Question?
Does anyone have a Good starting point for Carpet/rubber tires?I would appreciate any help.thanks!
racenut123 is offline   Reply With Quote
Old 10-23-2003, 05:08 PM   #6590
Try ae's website, there are usually good starting setups for carpet there...
just my opinion...
I hear that the cs-27 goes on front, and the cs-22 goes on the rear is what the fast guys are running at stockton...
Old 10-23-2003, 05:56 PM   #6591
Which fast guys?I know everyone there and the cs tires are alright.Pits are definately better.I tried Baker trackside setup.Pretty close.Just thought I would ask if anyone has a setup that they feel is absolutely dialed.
Old 10-23-2003, 07:19 PM   #6592
John,
Did you get the setup I PM'ed you? Aaron young was running almost the same thing last night. He was running #2 pistons instead of the #3 pistons. He was also using a rear R-2-0 block and added a front F2 block. If I remember correctly from the printouts he ran a few 11.3 laps.
James Nguyen is offline   Reply With Quote
Old 10-23-2003, 07:23 PM   #6593
Trader Rating: 17 (100%+)
John,
Have your BOUY Roger send you Walter's set up.
Art
Advil is offline   Reply With Quote
Old 10-23-2003, 08:21 PM   #6594
tc3rookie's Avatar
Default weight
i weighed my tc3 minus motor, esc, batteries, servo and foam bumper and it came in at 1.5 pounds. is that heavy? i have nothing to compare it to. abt how much is good?
Old 10-23-2003, 08:23 PM   #6595
mike_Webb's Avatar
Send a message via AIM to mike_Webb
52oz with everything in it is the minimum weight you can run
mike_Webb is offline   Reply With Quote
Old 10-23-2003, 08:28 PM   #6596
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Default Asphalt Set-Up
Alright figured I might as well post my set-up on here.
=MisFitz= NuKe is offline   Reply With Quote
Old 10-23-2003, 08:38 PM   #6597
Walter...
Old 10-23-2003, 08:51 PM   #6598
tc3rookie's Avatar
Default setup
on the setup sheet under chassis what chassis does 'carbon fiber' refwer to, the factory team one?
also when i spinmy tires it seems the diff gears are adding lots of drag, is that fixable? i've got the lightweight kit in the back and a new gear up front. the center shaft ones haven't been replaced. is the old gears the problem?
Old 10-23-2003, 09:00 PM   #6599
Yes, it means the Factory Team version.
It should not matter what gears are in there(as long they are from the TC3), just the ammount of lube that is in there(the gear boxes). The more lube, the less free the spin, and the longer the gears will last, and they usually are more quiet. The less lube, the more free the spin will be, and the gears will wear out quicker, and they can be louder than with more lube.
Old 10-23-2003, 09:43 PM   #6600
Default Bubbles.
Walter doesnt live here anymore,should be running @ Socal with you.I wish I had his email because he was fast here.The carpet track where walter was hard to beat at was not Stockton.It was Hobbyworld Gilroy.the Carpet @ both Places where completely different hence you run a different tire at both places.If you see him,tell him I need his setup.tell him John Hicks was asking.
Advil,I will call Roger.
James,No didnt get it.Will check my Pm's though.Your car looked good last night.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
