Old 10-17-2003, 11:46 AM   #6511
rtypec's Avatar
That drivetrain looks about right for stock racing. I bet it would go a lot longer if there were lead weights inside the wheels hehe.
rtypec is offline   Reply With Quote
Old 10-17-2003, 11:55 AM   #6512
mistercrash's Avatar
R/C Tech Charter Subscriber
Probably Anyway! I've done a lot of things on my TC3. Like I mentionned before, and others as well, the amount of time and effort it took me to get a free drivetrain would've been better spent on the track practicing.
My .02
mistercrash is offline   Reply With Quote
Old 10-17-2003, 11:59 AM   #6513
Me+RC=$$$'s Avatar
Send a message via AIM to Me+RC=$$$ Send a message via Yahoo to Me+RC=$$$
That is crazy! Thats all I have to say
Me+RC=$$$ is offline   Reply With Quote
Old 10-17-2003, 12:54 PM   #6514
tc3rookie's Avatar
Default mod
i race stock class currently and am looking into getting a mod motor for fun between race weekends. the objestive is speed. does anyone have any ideas on the best one reedy Kr? what gearing works well.
tc3rookie is offline   Reply With Quote
Old 10-17-2003, 02:50 PM   #6515
Trader Rating: 28 (100%+)
Rear shock tower on the front.I cant get anything above 2mm ride height.Is there any special trick to get it to ride height other then lengthen the ball ends?
racenut123 is offline   Reply With Quote
Old 10-17-2003, 02:53 PM   #6516
What front arms are you using? How long are your shocks?
James Nguyen is offline   Reply With Quote
Old 10-17-2003, 02:55 PM   #6517
v2 arms...what should my shocks be at as far as length goes.Both front and rear.I am rebuilding this car for someone.
Old 10-17-2003, 02:58 PM   #6518
I just have my shock ends screwed in to where it comes up to the end of the threads. Then I just make my shocks all the same length. i forget what the exact length is.
Old 10-17-2003, 03:00 PM   #6519
Hey james,is there any spacers that belong under the tower?Also,I just bought a Demon1 and need a setup.Your car in Lemons hands was good.I will check my shock lengths first.
Old 10-17-2003, 03:04 PM   #6520
If you are running the v2 arms in the outer hole then you won't need to run any spacers underneath the rear tower on the front. I run a Baker reedy race setup. Only a few changes. I'll PM you some of the changes to the setup.
Old 10-17-2003, 04:26 PM   #6521
linger's Avatar
Racenut,
Something's not right. Did you make sure that there are no spacers inside the shock?
linger is offline   Reply With Quote
Old 10-17-2003, 06:44 PM   #6522
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Now this may seem kind of stupid, but make sure that the droop screws are not too screwed in, that would cause a lack of ride height as well.
Bubblestc3 is offline   Reply With Quote
Old 10-17-2003, 08:17 PM   #6523
I checked and your right ling.I took out the oring that was limiting travel.Man has everybody noticed that the car turns in like crazy with the rear shock tower?I set my car up with barry's reedy setup but with a oneway. Its a bit on the twitchy side,though I can see it being fast.
Anyone have a good aphalt parking lot setup?
Old 10-17-2003, 09:14 PM   #6524
2 more things guys.How do you check if the front carrier is either a 2 or a 4 degree hub and where are you guys checking for droop at on the arms themselves.
Thanks!
Old 10-17-2003, 09:43 PM   #6525
On the "C" carrior there should be either a 4R, or a 4L(in silver sharpie). Now it should be the same for the 2degree's, just in a 2R, or a 2L.
Where to check the droop, is where the arm curves, right where the hingepin goes through, measure from there, I am pretty sure that is where you measure from in the manual...
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
