Old 10-15-2003, 11:29 PM   #6496
Send a message via AIM to Johnnytc3
nexus there is a video clip of a very free tc3, spinning for about 20-30 secs at least, i didnt count but it was insanely long. Most likely ceramic bearings, i can get about 10-12 secs on mine, and that is with metal sealed bearings with shields removed and blasted thoroughly with brake cleaner with no relubrication.
Johnnytc3 is offline   Reply With Quote
Old 10-16-2003, 06:14 AM   #6497
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Motor Gearing for a Orion Core Stock
Hi all,
What would you reccomend for a Core Stock motor with a 72 Spur gear? The track has one 100ft straight otherwise the course will have mainly med speed cornering.
rinkrat99 is offline   Reply With Quote
Old 10-16-2003, 07:19 AM   #6498
Default Re: Motor Gearing for a Orion Core Stock
Originally posted by rinkrat99
Hi all,
I have had good experiences with a 22/72 or 24/72 gearing with stock motors.
blackd0g is offline   Reply With Quote
Old 10-16-2003, 06:24 PM   #6499
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Hi all,
try using a 6.9 overall, i normally do not use that motor for racing, but for the ko propo grand prix here at socal it was the handout motor, with which i managed to get second with(that gear is a 26/72, for that race, i used a 36/100)
Bubblestc3 is offline   Reply With Quote
Old 10-17-2003, 12:51 AM   #6500
mistercrash's Avatar
R/C Tech Charter Subscriber
Default Re: 16 seconds?
Originally posted by tc3rookie
that video has got to be fake. 16 seconds is really really free. either that or they got a really nice drivetrain. damn.
What video???
mistercrash is offline   Reply With Quote
Old 10-17-2003, 06:39 AM   #6501
rinkrat99's Avatar
Hey BubblesTC3
Thanks for the ratio, I think i will start with between a 24 and 26 and see what happens.
Can you reccomend an easy fix for the hinge pins on all four block carriers? The set screw came loose and the hinge pin moved out towards the front of the car.
Old 10-17-2003, 10:44 AM   #6502
tc3rookie's Avatar
Default video
i dunno what video... somebody mentioned a video of somebody with a 16 second spin on a tc3 or something.
tc3rookie is offline   Reply With Quote
Old 10-17-2003, 10:46 AM   #6503
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I've seen it - it was about 30-40 pages back or so.
A guy colored dish wheels in quarters (black and white) so you could see the spin. He had the car securely mounted on a block so wheels could spin freely.
He got a REAL good spin on it (both rear wheels, obviously) and let it spin - it went a LONG time. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-17-2003, 10:48 AM   #6504
BBSpence's Avatar
Trader Rating: 40 (100%+)
Only 16 seconds?
BBSpence is offline   Reply With Quote
Old 10-17-2003, 10:53 AM   #6505
tc3rookie's Avatar
Default spin
16 seconds is still pretty darn good. much beter than i used to have.
Old 10-17-2003, 10:57 AM   #6506
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
I can't find the video!?
Intermision is offline   Reply With Quote
Old 10-17-2003, 11:00 AM   #6507
tc3rookie's Avatar
Default video
i can't find it either. could someone post a link or something?
Old 10-17-2003, 11:40 AM   #6508
Super Moderator
Grizzbob's Avatar
I wonder if maybe you didn't fully clear out the plastic gunk that sits inside the hub carriers after they've been molded, that would get in the way of the set screw & make it feel like you tightened them when in truth you haven't. If that's the case, just take an Exacto blade & scrape out that stiff & then try to tighten the set screws again.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-17-2003, 11:41 AM   #6509
Hey BubblesTC3
Try shoe goo that will hold them in place on both sides
teamAE is offline   Reply With Quote
Old 10-17-2003, 11:42 AM   #6510
Ah!... Ok.... You mean THAT video I can assure you that it's real and not a fake.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
