Old 10-14-2003, 06:21 AM   #6466
NR
NR's Avatar
Trader Rating: 52 (100%+)
Guys i need a little bit of help here.
I have broken 3 thats right 3 RW one ways for the tc 3 i cant believe it and all have been broken on the 1st run there is seriously something wrong with these.
Anybody know which is a better/Stronger one to try. I dont know between the yokomo and genuine associated one.
Any ideas ?
NR is offline   Reply With Quote
Old 10-14-2003, 08:32 AM   #6467
Shayd's Avatar
R/C Tech Charter Subscriber
Default flat dogbone pins?>
Anyone run the niftech flat dogbone axles? Good? Bad? Indifferent? Seems like a good idea, but then there are more parts to break or have problems with.
Scott
Shayd is offline   Reply With Quote
Old 10-14-2003, 11:56 AM   #6468
Default Diff coming loose all the time
No matter what adjustment I use (looser or tighter), they just keep coming loose! I ebuilt them they they still come loose after one pack.
I am running a D5 8T single.
Any tips?
blackd0g is offline   Reply With Quote
Old 10-14-2003, 01:15 PM   #6469
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Yep - the little ny-lock nut needs to be replaced.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-14-2003, 03:05 PM   #6470
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
Default Re: Diff coming loose all the time
Any tips?
with mod, you should always run a tight diff. not too often looser(accually, i don't think that you ever have a loose diff in the car when you are running mod), but also as boomer said, try a new nylon nut in the diff(diff nut). Another thing, if the car is brand new then you need to break in the diffs(so each part gets situated and smothes out), for this you should run the diffs almost locked, after one run or so you should check their tightness and if they slip then tighten them once again but feel for "notcheyness"(grinding). If the diff is grindy then you should take it apart and rebuild it again(try more diff lube).
More often than not, many people that have this problem(when the diff nut is ok) they forget things such as all of the balls in the diff, as well as all of the thrust balls, and the diff will not turn, but it still slips. So just go through the car and make sure that all the parts are in there and you should be set!
Chris
Bubblestc3 is offline   Reply With Quote
Old 10-14-2003, 03:51 PM   #6471
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Any ideas ?
Use the Heavy Duty (HD) One-Way from AE.
When the NTC3 came out the beefed up their previous one-way with this one, you will be very impressed.
=MisFitz= NuKe is offline   Reply With Quote
Old 10-14-2003, 03:56 PM   #6472
Alright all you TC3ers out there, for a school preject/club fun raiser (yes, I am a junior), I will be designing and machining TC3 parts, and then selling them as fund raisers for our Tech. Club at school. and yes we do have a CNC Lath/Mill with CAD.
So, I would like to get suggestions on what parts you guys would like to see made in aluminum. I will take my dad's polishing bits and make the parts all nice and shiny so dont worry about that. So any suggestions are welcome.
What I have come up with:
Wider Battery brace (better heat conductor),
the cups that the center shaft mounts into,
the four chassis stiffeners, but only with one arm(like cutting the graphite ones in half, to get a visual),
anything else is welcome,
thanks,
Old 10-14-2003, 04:28 PM   #6473
just as a technicality, the hd one-way is accually from yokomo, but it still is an ae part number
Old 10-14-2003, 04:31 PM   #6474
yes thanks, for that, you do get it from AE though.
Old 10-14-2003, 04:36 PM   #6475
thanks,
how bout a spur gear mount...?(with another piece that will make the mount stronger)
drive shaft...?
shock tower mounts...?(so you can mount a flat piece of carbon to, to make your own shock tower)
wheel hexes...?
i am at a brain block, so in a little bit, i will hopefully have more...
hey, i'm a junior too. i wish my school had the machinery to do that (we proabally do, i just have never seen it)
Old 10-14-2003, 04:43 PM   #6476
Yeah, forgot the spur gear mount, but what extra piece that will make it stronger?
Old 10-14-2003, 04:48 PM   #6477
lets see...
how do i explain in words...
ok, two pieces of aluminum holding the spur in a sandwich, and the top piece would just be to keep the spur true, and spinning straight
Old 10-14-2003, 04:55 PM   #6478
ok sweet, that is what i was thinking of, like the tamiya, evo 3 where the spur is between the aluminum and graphite, yeah, that is one thing the TC3 needs, is freakin straight spurs.
Old 10-14-2003, 05:09 PM   #6479
ok cool, uhh what about some kind of new motor clamp, with just the clamp, no heat sink...?(so you don't have to dremel it off, you can just buy one)
Old 10-14-2003, 05:14 PM   #6480
are threaded components hard to make using the machinery?(ie. shocks, screws, servo mounts, etc.)
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
