Old 10-12-2003, 09:28 PM   #6436
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
ok, ill try them tomorow at socal. i used them on the front for one run, one of them broke and i lost a $11 out-drive, but you have to buy them in pairs, so that is accually $22, and i broke a composite cvd $2.50...
but what ever works for you
Bubblestc3 is offline   Reply With Quote
Old 10-12-2003, 10:00 PM   #6437
Send a message via AIM to Genetic Send a message via Yahoo to Genetic
so what setups are you guys running?
i am running my own but i want to try a new setup, and see if the car will still work.
i and running some losi parts on it also.
Genetic is offline   Reply With Quote
Old 10-12-2003, 11:17 PM   #6438
I thought that you did not want to race anymore...
Old 10-13-2003, 12:32 AM   #6439
KinzR's Avatar
Default Composite CVDs
Use composite CVDs and save your money for Tamiya shocks!
KinzR is offline   Reply With Quote
Old 10-13-2003, 01:10 AM   #6440
Arun's Avatar
Originally posted by DaveW
Im with Mistercrash... composite CVD's are the way to go. I never liked the idea of bending a metal CVD and having to replace it ($$$)... or have it vibrate the car with an 8 turn in it (ruined bearings), so i went with the composites and have loved them ever since. Doesnt matter what diff i use them with. I think i have broke maybe two in all the years i have had this car... and both were from impacts (one was head-on) with other cars in traffic, never from one-way use. I just add the IRS pincushions to the stock AE composite bone to protect the outdrive and go with it. I have noted on high bite carpet or asphalt with modified, the response can be inconsistent when stabbing the throttle... most likely because the composite bone twists under the load. Smoothing out the power transfer (trigger finger) or going higher on the speedo frequency seems to help that alot. Dunno... just thought i would add my .02...
- Dave
I think I broke those 2 for you, Dave!
http://nexusracing.com
Arun is offline   Reply With Quote
Old 10-13-2003, 05:44 AM   #6441
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default Re: SHIMING
Originally posted by OHBRAD
HI GUYS,
JUST WANT TO HEAR HOW MANY SHIMS PEOPLE WERE USING, I AM CURRENTLY USING TWO EITHER END, ANYONE USING JUST ONE EITHER WITH STD GEARBOXES, OR WARPSPEED ONES
REGARDS BRAD P
Xray T4 16 | Sanwa MX11 | Much More Fleta | HW 3.1 | LRP Batteries | Team Argo | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 10-13-2003, 06:57 AM   #6442
DaveW's Avatar
Bubbles: Bend em back?!
Boomer: You make a good point. It isnt necessarily what is better, but what serves the purpose with reasonable ease to the pocketbook! ( I say pocketbook and not wallet... cause every married man knows he has to ask "momma" if he can spend his own cash!) LOL The composites that i had broken were at the pin near the hub too... and didnt break anything along with it.
Proficar403: ARUN! Man we definitely had some crashes out at Hurricane! Cold asphalt+ moist air/track+ modified= WHEEEE! I heard you came back here for the trophy race?! (Jesse told me you were...) Did you go back to school... or are ya here for a while? We are running TC again the 19th at HTUSA... and dirt on the 18th. Ill be there for both and wondered if you were gonna be there?!
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 10-13-2003, 08:19 AM   #6443
Arun's Avatar
- Dave
No, still at UGA now. I was home for the weekend. They are all lucky it got rained out! I have been putting up some very decent finishes at TFB. I even got to race an A-main with Barry Baker. We are going to move indoors for carpet pretty soon. You NEED to come here and race! I might end up going to the Snowbirds this year. Are you going there again?
Old 10-13-2003, 09:02 AM   #6444
Horatio's Avatar
Thumbs up
Originally posted by berger
I race on a small carpet track in the UK, its open class as the commitee wouldnt allow stock racing when i proposed it , which is stupid as the kiddies run 12 turn motors geared incorrectly and pinball around the track. Im in the A main weekly running a stock motor against the other older more mature drivers and because of the tracksize im only 1/2 a second down a lap on the majority of the A.
Berger:
I too run on tight, technical carpet tracks. I use the Aluminium CVD's even though they cost more and are heavier. Why? Because the composite bones always seem to wear out where the pins go through the joint. On larger tracks, I guess this wouldn't happen as often - but when you go from lock to lock around tight hairpins etc, it puts alot of stress on the bones and the pins pull through. I have never broken or worn out my Aluminum CVDs after 2 seasons with my TC3. In comparison, I went through a set of Composites per meeting For me, they were a false economy and didn't look as nice either ;o)
As for running Modifieds on tight indoor tracks - why? You were right to propose a stock class. Control tyres certainly sorts the men from the boys too - you can concentrate on racing and other aspects of the sport rather than just going through endless combinations of tyres and inserts. During our open practices, I frequently tried out some of my mod motors against racers that were using Stock. The only part of the track where my car was quicker was on the straight. The stock motors were able to put the power down far better and were putting in quicker times as a result. Lower wind Mod motors (including 12t) just don't get a chance to unwind. I'm a fan of the 19t spec Super Stock motors, which I believe can work very well indoors, even on very tight circuits. I've found on our track, where 30 laps is quite normal with a Reedy MVP, I can improve my times by about 4 tenths of a second per lap with an Orion Element Super Stock motor (with stand up brushes). As an added bonus, the 19 spec motor comes off the track cooler too. Keep up the pressure - they'll come to there senses - there's always next years AGM
Juniors racing 12 turn motors indoors - nasty!! I bet the local model shop is doing well though
Horatio is offline   Reply With Quote
Old 10-13-2003, 09:11 AM   #6445
berger's Avatar
R/C Tech Charter Subscriber
Hehe you bet the hobby shop does good, its trackside and i race for em so i get my tc3 spares a bit cheaper. The car i run is basically a stock kit running Jaco trued and glued blues and a trinity rev monster. This is the same as what ive run at more competitive meetings in the stock class and its performed well. Im faster through the inner field as i can get a real tight line, then just loose some time on the back straights, just have to try and block em off like Michael S did to his brother yesturday on the main straight.
berger is offline   Reply With Quote
Old 10-13-2003, 10:54 AM   #6446
Send a message via AIM to Johnnytc3
Speaking of cvds, what do you guys think of the blue tobee cvds. They are half the price of the associated ones and look a tad bit beefier, anybody here use em?
Johnnytc3 is offline   Reply With Quote
Old 10-13-2003, 10:59 AM   #6447
Horatio's Avatar
Post
Berger:
The TC3 I ran was hopped up from racer spec to factory team spec over one season. Coming from off road, I wasn't too sure if I'd get on with touring cars, thus the racer spec initial purchase! To say i was 'pleasantly surprised' would be a massive understatement!! I did a couple of little mods specifically to improve performance indoors on carpet running control tyres (Schumacher carpet dragons). These tyres last forever (keeping the cost of racing down) BUT they don't offer much traction!! We've had guys coming from other clubs visiting and wondering how the hell we manage with Dragons!! ;-D
Lets just say that running a control tyre and stock motors just eliminates those 'cheque book racers' and brings the emphasis squarely back to driver skill and set-up ability.
Our juniors crash alot too - but as the speeds are lower, breakages are fairly rare.
Old 10-13-2003, 11:04 AM   #6448
berger's Avatar
I have some carpet dragons that a ran for a while, couldnt really keep the corner speeds and therefore lost out compared to everyone else. Its a shame i dont live closer to the better tracks, we share we a lesuire center and the tracks made from wooden sections which we can slot together, the permenant tarmac and carpet tracks about 40mins away.
Old 10-13-2003, 11:27 AM   #6449
tobee?
are they light blue?(lighter than the ae blue aluminium ones)(almost purple)
Old 10-13-2003, 11:29 AM   #6450
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
This probably sounds ignorant but does it matter in what order your electronics go in the TC3? I was test fitting a few things and I dont know if I should put the receiver in front of the ESC or behind it. also, what is a good start for shock oil. this thing is gonna get a few shakedown runs outside but my first racde will probably be indoors so suggestions would be appreciated
trackdesigner71 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
