Old 10-09-2003, 03:32 PM   #6376
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
i did not ever use the losi c hubs, just the knuckles and that would give more throw than the stock knuckles, but when you use the c hubs that takes away throw, then you should just be running the stock components
Bubblestc3 is offline   Reply With Quote
Old 10-09-2003, 11:35 PM   #6377
Send a message via AIM to Genetic Send a message via Yahoo to Genetic
Yeah i dont think you should run the losi c hubs, they made my car push a little but id go for the ae c hubs and losi knuckles.
Genetic is offline   Reply With Quote
Old 10-09-2003, 11:45 PM   #6378
Default New guy...
Hi guys
I new here.
What kind of special mods did you do on your tc3??? Any improvments???
Are you racing carpet or asphalt?
Check out my website as well. There are some pictures of Jonas Kaerups Tc3, from the euros and a more up to date, shot from this weekend. I'll also post some of his setups soon, if your interessed.
Take care
SSL
Thought you might as well see my car sooner or later, so here it is ----> Attachment.
SpineX-SSL is offline   Reply With Quote
Old 10-10-2003, 09:28 AM   #6379
hyperformance's Avatar
Default steering parts
i've used the losi steering knuckles & uprights, i ditched the steering knuckles and kept the losi front uprights, i like how the whole assembly fits with the losi part better the the fit compared to the ae upright.
using the losi rear uprights can give unlimited rear toe options, i've used them to take the rear toe on the TC3 down to 1/2 degree!
hyperformance is offline   Reply With Quote
Old 10-10-2003, 09:36 AM   #6380
Default ae customer service
wanted to give an update on the defective alm shock caps i had received (if anyone remembers or cares) to make a long story short, i ended up with two sets of blua alm shock caps (8 caps total) and only 2 caps would fit well enough to seal the shocks (threaded bodies with fresh o-rings) talked to ae and customer service asked me to send the parts in for inspection.
in the end they called me up, said something was wrong with the parts & were kind enough to send a FT Body Reamer for my troubles
thanks ae for great costomer service!
Old 10-10-2003, 10:03 AM   #6381
Default Defective Shock Caps
I've had the same experience with the blue aluminum shock caps. The threads weren't deep enough to shoulder out when threaded on. If you tried to force them it would damage the threads (gall) on the shock body. I know exactly what you are talking about. From now on I only use the Yokomo bladder caps. Better quality and easier to get your shock uniformly setup. IMHO
jcrouse is offline   Reply With Quote
Old 10-10-2003, 10:50 AM   #6382
sands's Avatar
Default Re: New guy...
Just don't hit the boards with those aluminum a-arms. You'll end up breaking or tweeking a $40 chassis instead of a $4 arm.
Sands
Originally posted by SpineX-SSL
Hi guys
I new here.
Take care
SSL
sands is offline   Reply With Quote
Old 10-10-2003, 01:24 PM   #6383
Default Re: Re: New guy...
Sands
Yes, I know. The trick is not to hit the boards
I always keep the stock ones in my box, so that I can always change them if it fells to insecure at the track.
So I was well aware of the fact, but thanks anyway.
Take care
SSL
Old 10-10-2003, 01:27 PM   #6384
Default Re: Defective Shock Caps
I got mine from CML, they fit fine. Were yours crooked, or was it the inner thread? And where did you get them?
Regards
SSL
Old 10-10-2003, 02:12 PM   #6385
speedxl's Avatar
R/C Tech Charter Subscriber
are any of you guys using the composite cvd,s>
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 10-10-2003, 03:31 PM   #6386
stormperson's Avatar
Send a message via AIM to stormperson
speedxl- I would not run them in mod, since they do twist and thus create an odd handling condition (as well as breaking), however in stock they should be fine. I run IRS big dawg bones (they also have four holes drilled out for the pin that connects the axle to the bone instead of two like the AE ones, so you dont have to replace them as often when you wear the holes, which in stock isnt bad, but in mod you have to replace them every month or two, espically with the insane motors everyone runs today, lol).
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 10-10-2003, 03:36 PM   #6387
speedxl i try to run full composite cvds but then i broke my front ones and then i just put alluminum ones in front and left my plastic cvds in the back. for mod i would run anything other than plastic cvds though, i guess for stock it is just fine.
Old 10-10-2003, 03:44 PM   #6388
Default alm shock caps
spine:
i was the inner threads, not tapped right or machined right or something. i got the first set from tower, called ae to tell them there was a problem, the guy in warranty though i was stupid but sent out another set . they were bad as well, just not as bad as the first set. i'll stick with the plastic ones, they have lasted 3 years and are still sealing well
Old 10-10-2003, 03:57 PM   #6389
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
speedxl- I run the composites in the rear and alu's up front. The composites break easily if they are up front.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-10-2003, 04:40 PM   #6390
Super Moderator
Grizzbob's Avatar
Actually, when running a one-way, I've broken just as many aluminum CVD's as I have composite ones, so I pretty much stick to the composites(can't beat them for the price)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
