Old 10-07-2003, 06:35 PM   #6361
JoshR 85's Avatar
HeY!!!
melvin al you have to do is just get the graphite battery strap or it depends how you make the pack. just don't have the battery bar hang over the strap if you use straight sodder. good luck w/ car, i love both of mine.
JoshR 85 is offline   Reply With Quote
Old 10-07-2003, 06:53 PM   #6362
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I use a piece of electrical tape to insulate the sides of the chassis from the batteries.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-07-2003, 07:52 PM   #6363
JoshR 85's Avatar
HeY!!!
steve i thought you used the graphite brace, or is that the bar that you and your dad balenced out w/ the change??? lol
Old 10-07-2003, 07:54 PM   #6364
Moderator
we do use the graphite brace, but im talking about the sides of the chassis where the bars touch. that are a conductor of elec, so we use elec tape on it to prevent a short from occuring.
SMC Racing
Old 10-07-2003, 08:07 PM   #6365
JoshR 85's Avatar
HeY!!!
I see i see. i also do that i actually just started to do that last weekend but my elec. tape came off so i just gotta put more on sun. when i wait for pack to charge.
Old 10-07-2003, 08:11 PM   #6366
RAP66's Avatar
how much shorter is the wheel base between the 2 different models
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 10-07-2003, 08:30 PM   #6367
Send a message via ICQ to melvin
Default batt terminal
Hi,
Could you kindly elaborate more on how your battery terminals are mounted? Could you post a pic?
Fellow TC3 racers: Could you all knidly possibly post your pics as well so that we could compare and discuss on the various options?
As for insulating, I am thinking of using the leftover polycarbonate of the body shell by cutting a along strip and sticking on the chassis. I think it will be stronger that tape which tends to come off over time due to moist and dust. Furthermore, polycarbonate are really strong ..
Thank you
Originally posted by JoshR 85
HeY!!!
melvin is offline   Reply With Quote
Old 10-07-2003, 08:45 PM   #6368
lee82gx's Avatar
polycarb is good.
check out my layout.
lee82gx is offline   Reply With Quote
Old 10-07-2003, 09:26 PM   #6369
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
here is an older pic, of my car, have done some changes, anyways, I will post new ones tomorrow
from that angle you can see that white stuff along the side of the chassis, because I brought the batts. in closer to the center, I put two layers of that stuff, single-sided, stiff-foam, along that one side, then some very thing servo tape on the other side(which you cant see)
=MisFitz= NuKe is offline   Reply With Quote
Old 10-07-2003, 11:00 PM   #6370
Default insulation
Hi there,
Perhaps you could pose pics with battery pack installed as well?
GUys: I just thoght of something that can be used as insulation as well. I believe it is easy to use the racket tape ( The tape that you stick on the head of your tennis racket to prevent scratches) on the chassis as well. They are strong and dun come off easily, and easy to apply as well.
Thank you
Old 10-08-2003, 12:02 PM   #6371
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
wow, for a few days now i have had all the original ae parts on my car, and have been doing very well with the car! Rather than running the losi hubs and steering knuckles on the car, i decided to run what ever comes in the kit, and the car feels GREAT!!!!! The only think that is "mod" is the motor clamp, and running the rear shocktower on the front, but other than that the car is stock!!! The past two races that i have had the car like this i have been able to win and tq my races!!! That is fast!!!!, also my times would make it into the A-main of pro stock at socal!!!!
Bubblestc3 is offline   Reply With Quote
Old 10-08-2003, 06:27 PM   #6372
JoshR 85's Avatar
HeY!!!
Bubbles why would you have to put on other companies parts on your car i don't really beleave in that unless it will totally improve my driving???
Old 10-08-2003, 06:40 PM   #6373
HeY!!!
Not that I have tried it yet but on our tight carpet track contact is made more often then wanted in a ten man race. The Losi knuckles have a bit thicker meat where the ball studs screw in and many at the track run them as a safety precaution. I have both the Losi and TC3 but have yet to swap the parts but have considered trying it. The Losi parts supposedly give more lock to lock steering over the stock ASE parts, not sure as again I have not tried it nor does my car need any more steering as most say my car is too twitchy as it is
Fasttrak is offline   Reply With Quote
Old 10-08-2003, 08:07 PM   #6374
HeY!!!
I used to run the losi steering knuckles, and the rear hubs on my car, which in turn gave the car less roll in the rear, and more agressive entering the corner, eventually i started to like more steering and i decided to go back to all ae hubs and knuckles, thus giving more steering
Old 10-08-2003, 09:20 PM   #6375
I run Losi steering knuckles and c-hubs on my tc3. They are much stronger. I broke 3 Associated steering knuckles and have yet to break a losi. But I have to say when I installed them I didn't notice very much more steering. And I did adjust my end points on my radio.
racerdx6 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
