Old 10-01-2003, 09:48 AM   #6286
speedxl's Avatar
R/C Tech Charter Subscriber
thanks bommer and horatio it just that some of us are very passionate about what we do and after 14 years i still get exicited about playing, or racing my r/c cars. this is our way of releasing everyday stress! from work!
boomer its not hotair its that some of us just get into it deeper then others! i dont mean ca ca either
thank you for noting that we all have a valued point!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 10-01-2003, 09:49 AM   #6287
tc3rookie's Avatar
Default Steering slop?
back to the steering issue...
i don't know much of anything about exponentional or rates, but i DO have a bit of a problem with my tc3...
i set the trim even for a straight tack, but after a fetw turns to the right, the whole car seems to track to the right, as if the trim were off, until a few more laps, and it corrects itself...
i have a good KO propo FET power servo, an aluminum arm, titanium ft turnbuckles, rpm heavy duty ball ends, and a new rack with ball bearings. i just don't get it .. help please...
tc3rookie is offline   Reply With Quote
Old 10-01-2003, 09:53 AM   #6288
lee82gx's Avatar
well i'm gonna get my latest batch of batteries tomorrow and hopefully i can get some laps soon on my Fac.TTC3..
It's been very long since i've driven electric!besides the
dodge and alfa
what other bodies have u guys run , with success for technical tracks?
lee82gx is offline   Reply With Quote
Old 10-01-2003, 09:54 AM   #6289
speedxl's Avatar
rookie simple check the steering rack you may have some binding going on or a bearing thats seising or something is loose! try looking around the steering hubs the screws can come loose and make the car wonder around if stripped or the screw is missing.
Old 10-01-2003, 09:55 AM   #6290
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I know, speedxl, and THAT's why I come to this board instead of to any of the others. . .deep, intense, intelligent discussion.
I love you guys!
Anyway, rookie, to look at the simplest answer first, how clean is your steering rack? That thing can gather dirt, gunk, and crap quicker than I can eat a PB&J sandwich. . . if it gets greasy dirt crap in there, it can stick a bit. . .pushing you one way or another. . .
That would be the first thing I would check (and do check) - take a Q-Tip and some isopropyl or motor spray and swab out the inside of the rack, then blow it out with a compressor.
If you're using bushings in there (and I do - tired of cleaning the bearings and I don't really notice much difference) then don't oil them - it will only gather more crap.
If you're using bearings in there, LIGHTLY oil them - only enough to get INSIDE the bearing. You don't want any oil on the outside area - it will attract and create greasy dirt crap.
btw, crap is a technical term meaning, well, umm, crap. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-01-2003, 10:09 AM   #6291
speedxl's Avatar
lee pretty much thats it for bodies for touring car any of the other bodies work if you want less steering those two bodies have alot of steering i used to use the vauhaul vectra then did like the romans and started using the stratus.
if you can run anything other than touring car bodies then try the ferrari modena or the acura nsx (in your country maybe the honda NSX) THIS BODIES STICK!
Old 10-01-2003, 10:20 AM   #6292
berger's Avatar
Just out of curiosity, i was rebuilding my car the other week and ive seen that quite a few of the sponsored drivers run anouther rear shock tower but on the front, decided to give it a try out, ill run the car this week and see how i like it. Just wanted to know if anyone else runs the car this way and what they have noticed.
berger is offline   Reply With Quote
Old 10-01-2003, 10:23 AM   #6293
rayhuang's Avatar
Default Re: Steering slop?
Seized wheel bearings and dirt in the steering rack are the biggest issues with funny or I'll handling Tc3 in my opnion-and as expressed by others.
OH-yeah and one other thing-I had a flat spot on a bushing in the rack on my last TC3 and that caused notchiness and car wouldnt steer consistently.
Old 10-01-2003, 11:28 AM   #6294
speedxl's Avatar
berger it helps the car attain a more aggresive feel when running a diff or spool but you will also need to use their version two front arm which have an xtra shock mounting hole twords the outside!
Old 10-01-2003, 11:32 AM   #6295
Horatio's Avatar
Post
tc3 rookie:
There could be a small stone hidden in under the rack - they get trapped in there really easy - but following the advice that all these guys have just given you should get your car steering just right.
The TC3 is a great car!
Horatio is offline   Reply With Quote
Old 10-01-2003, 11:32 AM   #6296
I just set my exponential at -20 or so. On my 3PJS radio system.
I know its not my servo because when I use the servo in other cars it has worked great (I've used it in my x-ray, and my buddies t3). I'll take a look at my servo saver and report back .
racerdx6 is offline   Reply With Quote
Old 10-01-2003, 11:39 AM   #6297
berger's Avatar
yeah i am, broke a version 1 arm as my kits a good 2 years old now so ive got a pair of version 2's and ive not broken any since i got my RPM bumper
Old 10-01-2003, 11:44 AM   #6298
speedxl's Avatar
then your set try it you wont be dissapointed.
Old 10-01-2003, 12:15 PM   #6299
Me+RC=$$$'s Avatar
Send a message via AIM to Me+RC=$$$ Send a message via Yahoo to Me+RC=$$$
Rookie, I am having the SAME problem as you. I just got the car ready for the races and took it out to test. I nailed it and it went straight, I came back, went straight, turned around, and it started to go to the left, so I adjusted the throttle trim (left) and it came back to me going off to the left, so now I have to take the front end apart and check everything before this weekend. I have a lot of stuff to do in so little time Dremel my buddies TC3, rebuild the front end of my car, build some battery packs, cut the comms on some motors and do the usualy maintence.....I love this hobby
Me+RC=$$$ is offline   Reply With Quote
Old 10-01-2003, 12:27 PM   #6300
Horatio's Avatar
Version 2 arms also have droop screw holes too. If you have the old chassis, I'm not sure if they have the lips you need to use them though. Might be a good good excuse to get a nice new chassis though
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
