Like Tree4Likes
Old 12-31-2001, 07:04 AM   #616
Buda's Avatar
Yea just looking at new manual so I will compare part numbers up and order my stuff next weeks, as I need to walk in to town and pay my rent. Then out to check out a LHS where I just moved to. Wish I could run today but there is snow on the ground besides winter is usually wet over here anyway
Buda is offline   Reply With Quote
Old 12-31-2001, 01:04 PM   #617
Stogie's Avatar
I'm curious as to the different effects of droop on my chassis. I've fiddled with it a bit and don't seem to notice a huge difference. Most of the time I alter it I've made some other change on the car as well, so it's hard to isolate the changes. Does anyone have a good "nutshell" explanation? It would seem it can limit traction in one way or another. Does less droop = less traction on that end of the car??
Stogie is offline   Reply With Quote
Old 12-31-2001, 01:19 PM   #618
What the droop screws do is allow you to control chassis roll. The further you turn down the screw the less arm that is on the outside in a turn can extend keeping the chassis flatter. Roll can give you more traction up to the point that you exceede the traction limits of the tire, then you loose all traction.
Extreeme RC magazine unlike the other mags is full of suspension tuning articles and the like. Ill look in my issues and list the article by month, I know there is one on droop.
patcollins is offline   Reply With Quote
Old 12-31-2001, 01:31 PM   #619
Stogie's Avatar
Cool! Thanks... that's what I figured. I race on relatively low-bite ozite on a very cold concrete floor... I've found that overall increasing the droop has helped corner traction, but perhaps I've hit that point where I'm exceeding the max traction of the tire, so any more droop really won't help. Now I'll just limit the droop on the end of the car that has "too much" bite for a given situation, and that should help settle down the chassis.
Old 12-31-2001, 02:28 PM   #620
tc3screamin's Avatar
Send a message via AIM to tc3screamin
ok im trying to find out what length the cvd bone for a rally tc3 is im trying to fit some blue bones onto a rs4 so if ne one has a rally tc3 could u measure the bone not including the spindal and if its possible in mm thanks
tc3screamin is offline   Reply With Quote
Old 12-31-2001, 02:34 PM   #621
Buda's Avatar
total length 55mm from center to center of pins 51.5
Old 01-01-2002, 02:18 AM   #622
johnbull's Avatar
Hi guys. Greetings from Malta.
DROOP.
The explanations given are correct, more droop = more body roll = more grip....but only up to a certain point. You can overdo it.
We run my son's TC3 without any droop spacers (limiters) in the shocks. It still has the old chassis and arms so that is the only droop adjustment.
I run my MR4 SP with plenty of droop both front and rear. It seems to handle OK.
But the best proof came recently with my real race car. When we bought it about a year ago we just coudln't figure out why our results were so bad. I did 3 or 4 events and could never improve on around 20th overall - with a car that should have been in the top 10. I blamed my driving, thinking it was just a case of old age catching up.
Then my brother who, at 52 is three years my junior drove it for a couple of events, and the results were just the same. In fact on a couple of events where we both drove it we finished 20th and 21st overall, with almost identical times.
A couple of months ago I took all the suspension apart and rebuilt it softer on both springing and damping, and put lots more travel (and droop) into it. Result - 7th overall, after a load of single seaters.
Great to see us take RC technology to the real thing. It's usually the opposite.
Happy new year.
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 01-01-2002, 07:50 AM   #623
Buda's Avatar
Default IRS chassie
I know its not needed and really is just eye candy but it does look cool. Does anyone run this? How does it compare to the stock TC3 chassie for weight stiffness and most importantly durability/strength. I would hate to pay 150 for it have a board hit and bye bye. I probably wont get it but just currious. I try to spend money on "good" stuff. First new part this year will be the BRP front bumper and nerf wings
Old 01-01-2002, 08:56 AM   #624
Plate graphite typically isnt as durable as the molded stuff, it can de-laminate. I have heard quite a few people say the IRS chassis twists easier.
Old 01-01-2002, 09:25 AM   #625
Send a message via AIM to Type S
hey john bull what type of race car is it? an old v8 supercar racer?
Type S is offline   Reply With Quote
Old 01-01-2002, 11:11 AM   #626
Default Re: IRS chassie
Buda - I run the IRS chassis on both of my tc3s. Really, they are just eye candy. When i compared the weight of the IRS chassis (with the aluminum standoffs and the center brace installed) to the weight of the graphite chassis, it felt exactly the same. Although, I do feel that it helped my car handle better. When ever I tell it to do something, the car does exactly what I want and never never ever loses traction. When I added the grahite stiffining kit the handling was even better. I use futaba stardard servos with 41 oz. of torque and a .22 trasit time. When my friend drove it we could have swore that I had a high torque high speed servo in it because the handling was so great. Really it depends on your drviing style if you need it or not. I am a pretty erratic driver and crank they whell all the way to the left and all the way to the right and barely let of the trottle the gas it in the turn. It just the way I drive and the IRS chassis helped lots. If you do it get it I would locktight the standoffs to the chassi, because when you use a mod motor, the screws will back out and you will lose them. I use everysingle IRS part on my tc3 and the car weight 50.1 oz. Not bad with all the aluminum. IRS customer servcie is the best out there too. Let me know if you have anymore questions.
Modena AL is offline   Reply With Quote
Old 01-01-2002, 11:25 AM   #627
hey buda thanks for the length on the cvd
Old 01-01-2002, 11:37 AM   #628
Buda's Avatar
Default to Modena Al
Tx I probably should/will get some other stuff first like the brp stuff and ti turnbuckles as well as threaded shocks for easier adjustability. And I need to really stock up on tires and rims to. But I may have an insurance check comming soon so after I pay my wifes delinquint bills (long divorce story) you never know I dont know it really does look cool with the stiffining kit. BTW I drive like crap and will be racing on old astro turf and med-high grip asphalt (where they held the ready inntl in england). BTW do you have a picture of it to post?
Old 01-01-2002, 01:39 PM   #629
Corse-R's Avatar
Default Re: to Modena Al
The 2001 Reedy International was held in the SMMCC track, located on Snetterton, Norwich┐?.
I went to that race and boy, those mad 'Top Guns' fly very, very low...
This year we'll await them at 'our track', located in Alcobendas (Madrid). the best of Alcobendas track is the >210Ft straight. Is pretty scaring to see those 'little' cars exceed 80Km/h and need to brake to get the hairpin (some had slammed their cars to the concrete wall and say goodbye to the car, and this really hurts).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-01-2002, 02:46 PM   #630
Buda - I will get a pic for you to marvel at tonight. One of my racing buddies said it looks like something out of starwars
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
