Old 09-27-2003, 06:54 PM   #6226
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default HUGE TC3 PROBLEM
Hi Guys,
I have a big problem with where the small ball screws, screw into the front knuckles, they just keep ripping out all the time. Has anyone experienced this, and is there a way of solving this poroblem. I have heard that the losi xxx knuckles fit and they are a better fit, it seems every time i race even with out smashing in the slightest, after the race it is almost fallen out.
PLEASE HELP
Regards Brad p
Xray T4 16 | Sanwa MX11 | Much More Fleta | HW 3.1 | LRP Batteries | Team Argo | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 09-27-2003, 08:46 PM   #6227
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Default Re: HUGE TC3 PROBLEM
Originally posted by OHBRAD
Hi Guys,
PLEASE HELP
Regards Brad p
I don't know about the Losi part, but it sounds like your knuckles are stripped. Buy a new pair, and this time be careful not to overtighten them. You could use super glue or epoxy as a temporary fix to re-thread your current knuckles, but it is just that, a temporary fix and will not last long.
Speedo is offline   Reply With Quote
Old 09-27-2003, 09:15 PM   #6228
lee82gx's Avatar
Default Re: Re: HUGE TC3 PROBLEM
epoxy is great...until u realise u cant really apply JUST ENOUGH!!!
i've had the ball stud,c-hub AND spindle stuck in FOREVER it's bcos the stud was epoxied to the collar.
as i had no spare ball stud,i actually had to incinerate the whole bunch to get the stud out lol.
it was great to watch the graphite burn..u guys should try it.
so my advise is,dont overtighten,in fact it can be a little loose.
next advice:forget graphite,use plastic(they dont bcome powdery after a while)
or try gentler stuff like threadlock.
lee82gx is offline   Reply With Quote
Old 09-28-2003, 08:54 AM   #6229
lem2's Avatar
Default Good news!!!!
http://www.rctech.net/forum/showthre...threadid=25039
now we have lots to choose from!!!
Peace and happy racing!!
Lem
lem2 is offline   Reply With Quote
Old 09-28-2003, 02:13 PM   #6230
bubbles's Avatar
i think that you can use the helicoil, hilicoil(however you spell it)
but it is the metal threads that you can thread into the steering knuckles
the losi ones arnt much better, so far the ae ones have a better feel(after you cut off the stoper that contacts the c carrier)
overtightning is the usual for striping out the knuckles, but that just means tighten till it stops, no more
bubbles is offline   Reply With Quote
Old 09-28-2003, 03:51 PM   #6231
Default Re: Good news!!!!
Lem
elnitro is offline   Reply With Quote
Old 09-28-2003, 04:03 PM   #6232
Threadlock doesnt work too well on plastic parts....try a little elmers white glue and dont over tighten they should stay in much better.
patcollins is offline   Reply With Quote
Old 09-28-2003, 04:12 PM   #6233
Send a message via AIM to Johnnytc3
Are there replacement ring gears for the irs solid axle? i chipped a few teeth on mine and found out the diff ring gears dont fit.
Johnnytc3 is offline   Reply With Quote
Old 09-28-2003, 04:24 PM   #6234
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
It also destroys plastic. You could also use CA glue.
Intermision is offline   Reply With Quote
Old 09-28-2003, 06:16 PM   #6235
Super Moderator
Grizzbob's Avatar
I'm not sure, but you might have a look at replacement ring gears for the front one-way, maybe that'll fit....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-28-2003, 07:17 PM   #6236
I just use a little bit of CA glue in stripped holes. But you have to make sure it fully cures before you put the screw back in.
racerdx6 is offline   Reply With Quote
Old 09-28-2003, 07:18 PM   #6237
bubbles's Avatar
are you using the white gears?
suposedley the white gears are made of a less friction material, and they have a tendancy to strip easier
and yes, the ring gear for the one-way should work on the spool
Old 09-28-2003, 07:19 PM   #6238
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I do the same for a temporary fix, ca it and make sure u get enough to make a new hole to be tapped.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-28-2003, 11:46 PM   #6239
The regular diff ring gears wont fit, you have to use the AE one way ring gears.
James Nguyen is offline   Reply With Quote
Old 09-29-2003, 04:46 AM   #6240
Coxy's Avatar
Hi Guys,
PLEASE HELP
Regards Brad p
the Losi ones are a little better and more throw give em a try, and you get a pair of castor block thrown in, but your right they do strip very easy.
Coxy.
Coxy is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
