Like Tree4Likes
Old 09-25-2003, 11:02 AM   #6211
lem2's Avatar
Default Re: help!
Originally posted by babytoy101
lem2!
if i will use a hand held metal saw, and do the same thing! will it be possible??
i got no dremel!
that could do it if the piece of screw is protruding outside the servo mount, if not you will damage/scratch your mount. go to your LHS, or tracks, I'm sure somebody will lend you a hand.
lem2 is offline   Reply With Quote
Old 09-25-2003, 11:08 AM   #6212
babytoy101's Avatar
Default lem2 thanks!
lem2
what other web sites may i find some hop-up parts or option parts for tc3 besides rc10.com??
just bought it 2nd hand from pitshop master!
babytoy101 is offline   Reply With Quote
Old 09-25-2003, 11:26 AM   #6213
lem2's Avatar
Default babytoy101
starting with the shops here at RCtech: KtHobbies.com and SpeedtechRc.com
my cousin got stuffs for me at KT for my TC3
You can also try other Asian sites, here are my favorites
http://www.rc-square.com/parts24.htm
teamirsrc.com
wait till you see my TC3!! hehehhe
if you have any questions just send sms (917-6271266)
Old 09-25-2003, 06:31 PM   #6214
Default Rear Toe Help
Have a problem I wonder if anybody else has run into. While helping a buddy get his car handling better, came across a problem with the rear toe. He bought the car used and the previous owner had a "R" instead of "R+2+3" in the rear position. Replaced it with "R" in the front, "R+2+3" in the rear. Check toe with Integy alignment gauge, now right wheel has 1.5 deg toe, left has 4.5, for a total of 6 deg toe on the rear. Thought maybe a bent hinge pin, replaced, no change. Replaced left control arm, no change. Tried another set of arm mounts, same thing. Only thing haven't tried is new hub carrier. Anybody have any thoughts? Thanks
nitromike is offline   Reply With Quote
Old 09-25-2003, 08:16 PM   #6215
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Nitromike,
This can happen pretty easily when you are putting the hinge pins and arms back in their place while re-assembling, be very careful when doing this be sure not to squeeze and get a bad fit otherwise it will mess up the toe, take the car apart put the pins into the outer block and slide the arms on then evening slide the hinge pins into the back bracket being aware to do it evenly, sometimes takes a couple of times to get it right...
HPH,
TigeRyan
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 09-26-2003, 08:54 AM   #6216
hyperformance's Avatar
Default older rear upright
about 2 years ago there was a large run of rear uprights produced that screwed up toe adjustments. i think it was the right side upright & it would add like an extra 1.5 degrees on that side. also check the hinge pin carriers ("R" and the other one), the holes that the hinge pins fit into become streched out after time and the toe will become inconsistant. i run the "f" block in place of rear (it subtracts 1 degree on both sides) then the "R-2+2". this make the rear a little loose with rubber tires but cuts down scrub with foams
hyperformance is offline   Reply With Quote
Old 09-26-2003, 09:24 AM   #6217
Send a message via AIM to DualBL
when I run my car w/ b50 on 16 cells, I can't even get it up to 5mph w/ out it spinning
and I'm REALLY smooth
I even set the throttle to only give it enough power to reach 20mph max
w/ all the cells, I added WHITE springs (40lb)
think those are too strong?
any other setup tips? (toe/camber) ?
DualBL is offline   Reply With Quote
Old 09-26-2003, 03:32 PM   #6218
Default springs for tc3
I wanted to try out some different springs for my tc3 - I just have the stock ones. But the full spring set from associated seems kind of expensive ($35) - especially when you only get one pair of each, so you'd have to get two sets if you wanted the same springs all around. Maybe I'm just cheap. But I was wondering what other brands might fit?
Also, there is no real performance difference between the plastic and the aluminum shocks, right? I can't think why there would be, just asking.
zgeist is offline   Reply With Quote
Old 09-26-2003, 04:06 PM   #6219
DualBL ---- in a TC3 with a 6-cell C40 7S, I had the spinning problem when my pack was up front (foam spacer at rear). The car spun as soon as I hit the throttle. When I moved it back, the spinning just disappeared. Must have needed the weight at the rear. I have gold springs up front and silver at the rear. Front toe-in is about 2 deg, neg camber is 0-1 deg. Rear toe-in is 3 deg, 0-1 deg neg camber.
I don't know how this applies to a car with 16 cells.
blackd0g is offline   Reply With Quote
Old 09-26-2003, 04:14 PM   #6220
speedxl's Avatar
zgiest with all respect racing aint cheep. if your having fun cool but if your racing quit now because if you are diliberating on wether or not to get a spring kit then you shouldnt be racing, do youre self a favor and get the spring there is rarley a time that you will use the same spring front and rear, usually the differences can be worked out between supension adjustments!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 09-26-2003, 04:18 PM   #6221
Default springs
Well, I'm going to get a spring set - I was just wondering if I should get the Associated one, or if there was some other brand that people thought was a better value for their money.
Old 09-26-2003, 04:33 PM   #6222
zgeist - keep in mind you can also buy them by the pair. If you run asphalt or just run carpet, there are gonna be springs in the spring set you'll never use. I find that red, gold, blue and silver are the ones I use regularly (on asphalt) and I almost never run the same color springs front and rear
DOTMAN is offline   Reply With Quote
Old 09-26-2003, 09:23 PM   #6223
Cool new guy
Hi... I race a Factory Team TC3 here in Toledo on Saturdays in the summer... I only had the chance to race 4 times because I just got started... Managed to take a trophy ifor third place (beginners class) n the last race of the year... Here is a pix of my car...
Carterbike
carterbike is offline   Reply With Quote
Old 09-26-2003, 09:31 PM   #6224
Send a message via AIM to Johnnytc3
Good Job Carter! and Nice body!
Johnnytc3 is offline   Reply With Quote
Old 09-26-2003, 09:37 PM   #6225
Wink thanks
I am planning on getting a Gallardo body and using some of the inside decals by Jackal... Have you tried them???
Carterbike
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
NANKERVIS08
