Old 09-12-2003, 05:04 PM   #6121
Well you could but first you would have to have gears custom made and then probably new gear cases. Why would you want to anyway?
patcollins is offline   Reply With Quote
Old 09-12-2003, 06:36 PM   #6122
bubbles's Avatar
Default Re: lowering the internal gear ratio
Originally posted by OHBRAD
Hi,
does anyone know if you can lower the internal gear ratio of the TC3, just curious
regards brad.p
uhhhh, yes, but why?
the 2.5:1 is fine, why would you want to change it?
you can put some r2 gears in the boxes, but you would have to re shim it a lot
it is not like a tl01, you cant just drop in some integy speed gears and have the car go faster or have better acceleration
bubbles is offline   Reply With Quote
Old 09-13-2003, 12:12 AM   #6123
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
alright everyone, since this thread hears it first,
I just got the 19 turn quadmag in the mail today from AE, I will post pics and how it performs at the track, sometime tomorrow evening, it looks SWEEt though
=MisFitz= NuKe is offline   Reply With Quote
Old 09-13-2003, 06:21 PM   #6124
BUbbles or you could just by a YOK. See ya at the track with ym new batts.
teamAE is offline   Reply With Quote
Old 09-13-2003, 06:36 PM   #6125
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Transmission cases
Hi all,
I am in the process of building the kit and the Diff does not fit into the xmission case easily. When I snap it into the xmission, it seems that the bearing is putting pressure in the outdrive hub. Therefore there is too much friction. Any hints or has anyone seen this before?
rinkrat99 is offline   Reply With Quote
Old 09-13-2003, 06:39 PM   #6126
Send a message via AIM to ZER01
Do you have the right amount of shims on the correct side of the differential? If so, don't worry about it and run the car, they will loosen up.
ZER01 is offline   Reply With Quote
Old 09-13-2003, 06:43 PM   #6127
rinkrat99's Avatar
The diffs and the shafts were assembled correctly. The gear teeth side of the diff bearing fits nicely but the opposite bearing needs a snap to fit into the case. I think the SNAP is causing the bearing to put pressure on the diff outdrive hub causing the rubbing
Old 09-13-2003, 07:06 PM   #6128
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
try running no shims on the outdrive bearings
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-13-2003, 07:16 PM   #6129
K i got a TC3 but i got a problem.. i think its my pinion and spur. it makes a clicking sound whether i roll it on the ground, or actually use it. should i just take it to my LHS with a charged battery to have them check it out? thats what im going to do, i just wanna hear from you first
god dam why does every RC forum have vB.. i dont have $180 god dam dollars lol
Hockey07 is offline   Reply With Quote
Old 09-13-2003, 07:26 PM   #6130
stormperson's Avatar
Send a message via AIM to stormperson
hockey- most likely one of those gears is gone and needs to be replaced because it either got a stone in it, or most likely the mess was improperly set.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 09-13-2003, 08:46 PM   #6131
well bringing it into my lhs to get fixed shouldnt be a problem then.. some of them working there know their RC, so lol
on to the vB topic again.. anyone have a spare $180? :-p lol jk
Old 09-13-2003, 11:20 PM   #6132
am i missing something
Old 09-14-2003, 01:02 AM   #6133
Me+RC=$$$'s Avatar
Send a message via AIM to Me+RC=$$$ Send a message via Yahoo to Me+RC=$$$
Don't feel alone MisFitz
Me+RC=$$$ is offline   Reply With Quote
Old 09-14-2003, 07:25 AM   #6134
yes you are, your missing my $180 to buy a vB lol you dont even know what a vB is
Old 09-14-2003, 07:26 AM   #6135
berger's Avatar
R/C Tech Charter Subscriber
Visual Basic
berger is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
