Old 09-06-2003, 02:07 PM   #6031
Send a message via AIM to Firehawk02
PizzaDude
thanks
Firehawk02 is offline   Reply With Quote
Old 09-06-2003, 07:21 PM   #6032
lee82gx's Avatar
Originally posted by Firehawk02
Do u have to solder the connections from the esc to the batteries and the motor?
If you dont will you lose performance?
I thought nitro was hard!!!
Are there any like step by step instructions on soldering the batteries, motor esc..etc?
Any pics would help a bunch!!!!!
do u need instructions on soldering or just how to do it for RC?
u wont really need to solder everything together,using good connectors like corally pplugs or deans plugs are good enough.
if ur not sure,copy and experienced racer's layout.
practice on something else if u're not good at soldering yet.
lee82gx is offline   Reply With Quote
Old 09-06-2003, 08:21 PM   #6033
I had an old tc3 foam front bumper laying around when I milled my chassis and I just used that and some servo tape to keep my battaries from sliding around. Works great and I've had no problems so far. If you really want to use glue, you can use shoe goo. That stuff works for everything .
racerdx6 is offline   Reply With Quote
Old 09-06-2003, 10:00 PM   #6034
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Talking
lol
=MisFitz= NuKe is offline   Reply With Quote
Old 09-06-2003, 11:02 PM   #6035
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default TYRE QUESTION
Hi guys,
Question: We have a state comp coming up in October, the weather at this time of the year is around the 30 degree mark, i am wondering on what sort of shore rating should i be looking for for foam tyres on a bitumen track.
Xray T4 16 | Sanwa MX11 | Much More Fleta | HW 3.1 | LRP Batteries | Team Argo | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 09-06-2003, 11:27 PM   #6036
Hey man, first of all, 30 celcius right?, also what is a bitumen track? also what is the MK2 conversion you have? do you have a picture of the car?,
um i forgot the conversion from C to F, lol,
Anyways, with foam, the really nice thing is temperature doesnt really affect it much, so....
Old 09-07-2003, 05:19 PM   #6037
Post ball cups ?
Does anyone have any sugestions on what ball cups to use on the tc3? The stock ones seem to be a little cheap and the rpm ball cups seem to be to big.
Chino is offline   Reply With Quote
Old 09-07-2003, 05:39 PM   #6038
Send a message via AIM to Johnnytc3
RPM ball cups should work fine, you just need to shorthen 4 cups that connect to the steering rack and steering blocks.
Johnnytc3 is offline   Reply With Quote
Old 09-07-2003, 05:59 PM   #6039
Default Re: ball cups ?
RPM are the best I have found and they make them in blue There are two different lengths of ballcups, make sure to get the short version and only the steer link to servo needs to be cut, at least that was the case on my car.
Fasttrak is offline   Reply With Quote
Old 09-07-2003, 06:12 PM   #6040
Post Another question
Thanks for the reply guys. I have another question, how do yuo suggest I shim the tranny of my car? Should I follow the kit insructions or just leave all shims out?-
Old 09-07-2003, 06:43 PM   #6041
i would suggest you experiment with your car. try building them from the specs then try building them with out. every tranny case is different you will just need to fine tune the shimming to your cases specifically.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 09-07-2003, 06:50 PM   #6042
bubbles's Avatar
i just use the stock shiming
then if the gears are binding, use the polish method
i think that drivetrain is all about the berrings
bubbles is offline   Reply With Quote
Old 09-07-2003, 06:53 PM   #6043
bubbles's Avatar
i run b4 ballcups on one of my TC3's, they look cleaner after all the removing and replacing of them
btw, by b4, i just mean any offroad ae ballcup, they work for each car from ae
Old 09-07-2003, 07:02 PM   #6044
bubbles's Avatar
Default Re: TYRE QUESTION
Originally posted by OHBRAD
Hi guys,
30 degrees would be below freezing, so i am assuming that you are talking about celcious, which is 86 degrees F, so this is the answer for what the conversion from c to f
Old 09-07-2003, 07:10 PM   #6045
Yes, I too am running the "B4" ball cups, you have to shorten one, and you can leave one long, works well. Also, I cleaned out my bearings, took the inside seal off of all of the bearings except for the ones on the shaft and it is rediculously smooth, now when i blow the grease out of the 4 on the shaft, it will be very free.
Also, sand down the teeth on the two gears, to "dull" the top of the tooth, like a pre-break-in
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
