Like Tree4Likes
Old 08-25-2001, 10:13 AM   #46
mystererc's Avatar
If you don't have a ride height gauge, what is a good way to set ride height? Mine seems too low, but I wanted to check it and see for sure before I change it.
mystererc is offline   Reply With Quote
Old 08-25-2001, 10:41 AM   #47
Peter Busch's Avatar
R/C Tech Charter Subscriber
If you have a ruler try to find something that is close to 5mm thick and use that as a guage.
Peter Busch is offline   Reply With Quote
Old 08-27-2001, 01:28 PM   #48
Corse-R's Avatar
Um...
Only for curiosity, what kind of aftermarket parts you're using in your car?
I basically use an FT TC3 with some IRS parts and of course, the awesome plastic diffs.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-27-2001, 02:37 PM   #49
I run the aluminum front steering hubs and rear hinge pin blocks, not sure what the official name is for them. I might get the rear hub carriers but probably not.
Old 08-27-2001, 02:40 PM   #50
Corse-R's Avatar
Nice to see that the 'old folks of rctouring are coming here...
Cheers,
Corse-R
Old 08-28-2001, 07:58 AM   #51
Is there any way to decrease the toe-in in the rear to almost 0, or even just 1deg? I know you can go from the stock 3deg to 2deg via the optional hinge pin mounts (which I've done), but I've always liked to run only about 1deg rear toe-in. High speed stability is never an issue with me.
Fireball is offline   Reply With Quote
Old 08-28-2001, 08:45 AM   #52
linger's Avatar
Fireball,
Yes, you can decrease rear toe to 0 deg. You can install the front arm mounts (f-0 or f-2) in place of the rear arm mount and you will have 0 deg rear toe.
OR, you can buy 3rd party arm mounts from GPM: www.hobbyetc.com.
linger is offline   Reply With Quote
Old 08-28-2001, 10:30 PM   #53
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Glad I found this place. I had no idea that rctouring went down.
thank god for Trinity.
Does anyone have the web address for WSA Take Off Tires?
thanks....
wolfeman09 is offline   Reply With Quote
Old 08-29-2001, 07:51 AM   #54
TPhalen's Avatar
linger....as in ling????
TPhalen is offline   Reply With Quote
Old 08-29-2001, 08:00 AM   #55
tfrahm's Avatar
Send a message via AIM to tfrahm
Smile
I just wanted to say HI! and THANKS for a new forum to replace the RCTouring site...
I race TC3's on the local HobbyTown parking lot (Stock class) and I have an old TC3 that I converted into a Rally version for the local club's offroad track. I love the TC3! Still the best Sedan on the market from what I've seen...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 08-29-2001, 08:42 AM   #56
linger's Avatar
Tphalen - yes, linger as in ling!
Tphalen as in Tony???
Old 08-29-2001, 08:46 AM   #57
TPhalen's Avatar
hahhha, what's up Ling???
Funny who you see here!!!
Old 08-29-2001, 08:55 AM   #58
Default TC3 suspension
Want to know what a stiffer set up will do on a carpet track. Currently run 60wt oil all around, purple springs in front; copper in rear. Heard that we might get more corner speed, less body roll by going stiffer. I'm concerned about how this might affect steering and rear end traction. Any tips? Thanks.
coolrcdad is offline   Reply With Quote
Old 08-29-2001, 09:11 AM   #59
linger's Avatar
wolfe... take off tires are distributed by shumacher www.racing-cars.com
However, I couldn't find the tires anywhere on their site. Speedtechrc probably has a better description of the take-off tires.
Tphalen - were you using a 1-way at the Hitec race?
Old 08-29-2001, 09:37 AM   #60
TPhalen's Avatar
Ya, I ran the one-way. Probably could have made the car a little better but, unfortunately, only had 1/2 a battery of practice before they closed the track....
Guess we should have gone up there the night before!!!! Oh well...
That's ok...did fine anyway....except for my brain fart on the last lap!!! DOH!!!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
