Like Tree4Likes
Old 09-02-2003, 12:37 AM   #5971
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
anyone know have a link to where i can get see and purchase the Crest chassis???
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 09-02-2003, 12:40 AM   #5972
Manfredo's Avatar
Arrow machined chassis
Hereīs another pic of the chassis.
The features:
.) batteries moved closer to the center !
.) enlarged motor opening -> better cooling !
.) weight saving: ~30g !
.) finest CNC-Quality !
Interested ? -> mail to [email protected]
Manfredo is offline   Reply With Quote
Old 09-02-2003, 01:58 AM   #5973
RBLove's Avatar
Trader Rating: 72 (100%+)
Manfredo,
Please post a pic of the top of the car. Does the chassis come deburred, polished and ready to go? Or is there a little clean up work involved?
Thanks for posting! Looks awesome.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 09-02-2003, 02:12 AM   #5974
Manfredo's Avatar
I will post a pic from the top of the car tomorrow.
The chassis comes copletely cleaned and ready to go.
Old 09-02-2003, 05:40 AM   #5975
lem2's Avatar
here is the website!!!
http://www.raijin.com/crest/tc3/index.htm
just use alta vista world translate!!!
The conversion kit is 29,00yen for the motor left position
and 24,000yen for the standard motor position!!!
around US$240-263 for the left motor mount and US$190-218 for the standard motor position
whoaaah!!!! out of my league!!!!
You can also see the 2 spped conversion for the TC3 around US$300++!!!!
peace and happy racing!!!
lem2 is offline   Reply With Quote
Old 09-02-2003, 05:53 AM   #5976
Manfredo's Avatar
Can someone tell me how to get -(minus)2° Kickup on the front end of the electric tc3 ?
I donīt see a need for this setting but want to know how to do since it is mentioned in the tc3 setup sheet.
thanx in advance !
Old 09-02-2003, 09:57 AM   #5977
Send a message via AIM to ZER01
Manfredo, I haven't run -2 degree kickup or 2 degree anti-dive on the tc3 but I'm pretty sure they are shimming the inner front block up while using the 0 degree outer block. Try shimming the "F" block up .030~.060" and use the F-0 outer block.
ZER01 is offline   Reply With Quote
Old 09-02-2003, 10:20 AM   #5978
Manfredo's Avatar
I donīt think that Associated would have included a setting like this in their official setup sheet.
Maybe one have to use the inner rear block on the inner front psoition ???
Hopefully someone knows the answer...
Old 09-02-2003, 10:35 AM   #5979
D_Ames's Avatar
Send a message via AIM to D_Ames
If i'm not mistaken, Associated used to make an antidive (-2) front mount but they discontinued it because it wasn't used at all.
I don't think you ever need antidive. Maybe I'm wrong
D_Ames is offline   Reply With Quote
Old 09-02-2003, 12:28 PM   #5980
bubbles's Avatar
if im not mistaking, if you used antidive, or two degrees of negative kickup, wouldnt it just wear out the outter part on the front of the tires?
you could always run f+0/F with 2 degree caster blocks on oppisite sides,
or run f+2/F with 4 degree caster blocks on oppisite sides,
or just shim up the inner front block
besides the only time i would think that this would EVER be useful is maybe in drag racing
and it says this in the manual?
i know that they(ae) have 0, 2, 4 caster blocks, with two options for suspension blocks F+2/F and F+0
and david, i dont remember if they did make those blocks
bubbles is offline   Reply With Quote
Old 09-02-2003, 12:30 PM   #5981
bubbles's Avatar
the negitave 2 degree's
Old 09-02-2003, 01:34 PM   #5982
TurnNBurn's Avatar
Hi Guys,
I did a search in this thread and I couldn't find an answer to what I wanted to know, so I thought I'd go ahead and ask. BTW, someone posted a few weeks ago asking if anyone besides Yokomo and IRS made a spool for the TC3 - Dragon R/C makes one, as a matter a fact, believe that Mark Pavidis has used it from time to time... Anyway, back to my question?
Can anyone give me quick pointers on when a one-way or spool should be used? I've never tried using one (actually, I don't have either yet), so I'd like to know what situations I should be thinking about using one or the other vs. a diff... Thanks!
TurnNBurn is offline   Reply With Quote
Old 09-02-2003, 02:35 PM   #5983
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Hey manfredo, what are the dimentions of the depth you set the program to cut out of the bottom?
Thanks,
Mike
=MisFitz= NuKe is offline   Reply With Quote
Old 09-02-2003, 10:11 PM   #5984
That will give you 0 degree kickup/anti-dive with -2 degree caster blocks totalling your caster to -2 degrees-NOT GOOD!
This will still give you -2 degrees of total caster but with 2 degrees of kickup-still not good.
Best way to do it is by either finding those old arm blocks by Associated, have some custom made on a CNC machine or shim the inner arm mount up and use the F-0 outer arm mount. Also, if you do plan on using anti-dive, make sure you don't use the 0 degree caster blocks as this will create....negative caster.
Old 09-02-2003, 10:46 PM   #5985
Originally posted by TurnNBurn
Hi Guys, Can anyone give me quick pointers on when a one-way or spool should be used? I've never tried using one (actually, I don't have either yet), so I'd like to know what situations I should be thinking about using one or the other vs. a diff... Thanks!
By all means use a spool when tracks DO NOT allow the use of one-ways.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
