Old 08-20-2003, 08:48 PM   #5851
Why does the right rear of the chassis bend up.
Heat?
Tight motor screws?
Bad material?
Nevada is offline   Reply With Quote
Old 08-20-2003, 09:05 PM   #5852
Send a message via AIM to ZER01
My chassis is .5mm's lower on the left side when measuring with a ride height gauge, the reason for this is there's more weight on the left side of the car than there is on the right, just think, you have a whole battery pack sitting on the left side and just a motor, servo and esc on the right(use Ko receiver-weighs nothing). On the subject of the motor screw, 2.5 turns is enough-shouldn't warp the chassis.
ZER01 is offline   Reply With Quote
Old 08-20-2003, 09:06 PM   #5853
lee82gx's Avatar
nevada:
ur attachment doesnt help us answer your confusing question
lee82gx is offline   Reply With Quote
Old 08-20-2003, 09:22 PM   #5854
lee82gx, Sorry about the attachment.
What I'm saying is that the chassis bends upward in the right rear corner. I use a heat gun to bend it back down. After every race day it bends back up. Why?
Old 08-20-2003, 09:30 PM   #5855
I've never seen that nevada unless of course, you have milled out the chassis where it looks like swiss cheese, you're motor is getting way too hot(>200 degrees) and you are tightening down your motor screw bolt down more than 2.5 turns, you do have a spring on the outer motor screw bolt don't you? Other than that all I can think of is that the car has taken a terrible crash and has bent the chassis, this happens to me sometimes with the rear hubs-they will actually bend out to about +2 degrees toe-out and not break. Did you buy the car used?
Old 08-20-2003, 09:42 PM   #5856
proudwinner, The chassis is brand new. Its not milled and didn't drill any holes in it. This happens to every TC3 chassis I have had.
The car works great when the chassis is flat. When its bent the car is a handfull.
Everyone needs to look at their chassis and see if its bent up on the right rear corner.
Old 08-20-2003, 09:49 PM   #5857
Alright, let me get it out of my car bag and I'll post a pic, I sure hope it isn't bent. Like I said, I notice a ride height problem but I haven't noticed a warped chassis.
Old 08-20-2003, 09:54 PM   #5858
John its from the clamping force on the motor and the heat the motor creates. I know there is something you can do about it. you have to strengthen the rear right corner of the webbing. that should fix it. or get a warpspeed chassis.
James Nguyen is offline   Reply With Quote
Old 08-20-2003, 10:04 PM   #5859
TC3 Assembly Tips, Factory Team Kit
Here is something that might help the tweaking problem with the graphite chassis.
Old 08-20-2003, 10:09 PM   #5860
I don't notice it on mine and a pic is below, I'll post a better pic in a minute, batteries died out on me.
Old 08-20-2003, 10:13 PM   #5861
put the straight edge right under the motor cam.
Old 08-20-2003, 10:15 PM   #5862
Heat?
Tight motor screws?
Bad material?
Define rear. Near the very back of the chassis by the rear bumper or right behind the motor screws?
Old 08-20-2003, 10:16 PM   #5863
Will do James, waiting on batteries for my camera.
Old 08-20-2003, 10:17 PM   #5864
right under the motor cam/screws for the clamp. if its warped it will bulge out because when the motor gets hot the cam kinda melts into the chassis for lack of a better description. it will cause the chassis to develop a tweak.
Old 08-20-2003, 10:30 PM   #5865
Proudwinner, under the rear suspension mount(near the bumper). The best way to check it is by using a droop gauge. Make sure that both sides are even. Check droop at very end of the a-arm on the back side. set it at 5mm. Then place your chassis on a flat board. Using a ride height gauge check the same point of the rear a-arm. If the left is 5mm and the right is 5.5mm then your chassis is bent.
At the end of racedays my chassis is bent about 1mm.
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
