Old 12-16-2001, 02:27 PM   #571
johnbull's Avatar
Hi guys. Greetings from Malta.
TC3 rules....again!
Round 11 of National Championships for Mod T/C.
1st Hayden TC3 - Novak - Orion
2nd Alan HPI - LRP
3rd Josh TC3 Novak - Corally
Round 12
1st Josh
2nd Hayden
3rd Julian TC3 - Novak - Corally
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 12-16-2001, 07:52 PM   #572
Send a message via ICQ to ALFRED
HEY GUYS, IS ANYONE WILLING TO TRADE HIS FTTC3 FOR A PRO3? EMAIL ME FOR MORE INFO. THANKS!
ALFRED is offline   Reply With Quote
Old 12-17-2001, 07:17 AM   #573
TPhalen's Avatar
R/C Tech Charter Subscriber
hahahaha, Good luck Alfred!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 12-17-2001, 09:09 AM   #574
D_Ames's Avatar
Send a message via AIM to D_Ames
LOL Tony!!!!!!!
D_Ames is offline   Reply With Quote
Old 12-17-2001, 10:05 AM   #575
let me go find my crack and then i will get back to you.
Modena AL is offline   Reply With Quote
Old 12-17-2001, 11:01 AM   #576
Send a message via AIM to Dabeejrc
Default TC3 setup
Does anybody have a good baseline asphalt setup for this car?
Dabeejrc is offline   Reply With Quote
Old 12-17-2001, 11:18 AM   #577
Silver springs in the front, Green in the rear. -1 chamber all around, just a little toe out in the front. Ride height at least 6mm. Keep the rest of the stock setting.
thats what everyone in memphis uses. We race on low traction, bumpy asphalt.
Old 12-17-2001, 12:05 PM   #578
Corse-R's Avatar
Default Re: TC3 setup
Yes:
For those winter days (ambient temps between 5 - 15 C) and prepared asphalt with good traction:
- Front:
50wt oil, biggest hole piston (I never know if is #1 or #3, the one with biggest holes).
Gold spring.
Center hole upper mount position.
F-0 front plate (0 degree kick-up).
2 degree caster blocks.
1.5 camber.
Stock position of upper arm.
- Rear:
50wt oil, #2 piston
Blue spring.
R 2-0 rear plate (2 degree toe-in 0 kick up).
1 camber
Depending on track temp you can go for a ProLine 1095 with stock blue foam inserts (rear) and Yokomo ZR037-S (front) with some tyre additive (red dot works best) or maybe ProLine 1095 S3 compound with Yokomo ZR037-S inserts (this tyre setup for a little higher track temp, use with tyre heaters).
For more ambient temp (let's say about 15-25C).
- Swap the 50wt oil for 60wt oils.
- Swap the Gold/Blue Springs for Red/Silver or Red/Blue.
Beware, with this setup your car will be very quick, but your rear tends to break a little loose, to correct, reduce the camber to 0 or put a little harder insert rear.
Hope this helps, for me is fine.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-17-2001, 06:57 PM   #579
Cosmo's Avatar
Here's what I run on low traction surfaces (sealed asphalt, polished concrete, etc...)
front:
blue springs
#1 piston
40wt oil
-1 deg. camber
0 toe in/out
ride height 6-7mm
no droop setting (as much as possible)
no sway bar
rear:
green springs
#1 piston
30wt oil
-1 deg. camber
3 deg. toe in
ride height 6-7mm
no sway bar
-I usually run either pink or gray foams or Pro Line yellow cap tires
-I set the car up using the stock caster and kick up settings, as I have found that it doesn't make that much difference to me
-I set the car up with soft suspension and high ride height, that way in the corners, the car will roll. That transfers weight to the outside tires helping them to hook up. I have been running this setup for a couple of years and it seems to work really well for me
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 12-18-2001, 01:07 PM   #580
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Tony > Revelation this Saturday? I'll bring the generator
wolfeman09 is offline   Reply With Quote
Old 12-18-2001, 02:06 PM   #581
TPhalen's Avatar
Nope...sorry. I was just informed that a place my girl and I were looking at was approved....we're gonna try to get some stuff in this weekend...
Tony Phalen
RCDriver.com
CompetitionX.com
Old 12-21-2001, 07:04 AM   #582
juantrinidad's Avatar
set up for asphalt permanent track: traction medium
front red spring
no. 2 piston
associated 40 wt oil
sorex 36 or 32 with medium insert depending on temp
4 limiters in front
6mm ride height
rear blue spring
no. 2 piston
40 wt oil
sorex 36 or 32 (between 23 to 28 dg centigrade ambient temp)
2 limiters
6 mm ride height
rgds JT
juantrinidad is offline   Reply With Quote
Old 12-22-2001, 08:11 PM   #583
Send a message via AIM to Type S
are the brp kingpins better than the stock Associated kingpins, i just bought a set of the stock ones and installed them (the kingpins in the front were bent badly).
also is there a derlin spur gear mount for the tc3, cause the stock one makes my spur wobble (rrp spur).
tia
also are teh eagle racing foams any good?
check out my dyno results for my gm3 greem machine 3 dyno results (good info)
Type S is offline   Reply With Quote
Old 12-22-2001, 10:03 PM   #584
I just got my 5 sets of BRP hinge pins that I ordered a month ago
Old 12-22-2001, 10:49 PM   #585
Corse-R's Avatar
Use the spur gear mount from Trinity. I'm not friend of buying Big Ernie's stuff but this piece is very good.
Cheers,
Corse-R
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
