Old 08-12-2003, 02:23 PM   #5776
dasgruvn's Avatar
Originally posted by Trips
Try this for perfect TC3 shocks... First, soak the little foam compensators in shock oil before you install them. Don't just immerse them, hold them in the oil and squeeze em a few times each. Before you assemble the parts, go over each and every one of those plastic parts with an Xacto knife and make SURE there is NO mold flashing left over. It's better to remove a bit of the part than to leave ANY flash.
Once the shocks are assembled, fill the bodies with oil to the top. Work the pistons up and down a few times slowly to untrap any air underneath them. Add a bit more oil to each shock to get them to the top again. I like the oil to make a little "dome" sticking up past the top of the body.
Now put the shocks in a rack and go away for a while to let any remaining tiny air bubbles to slowly work their way up. After they've sat for a while, grab a shock, fill a cap with oil, and quickly screw the cap on to the body. Be careful to not cross thread the cap. Tighten the cap all the way hand tight and see if you can push the shaft all the way in. If you can, you didn't get enough oil in there. Remove the cap, add more oil to the body, refill the cap, and try again. If it won't go all the way, You're in good shape.
Loosen the cap one turn, push the shaft all the way in, count to three, then tighten the cap and let go of the shaft. Now check to see if you can push the shaft all the way in. You should be able to, and it should come back out most or all of the way on its own. Repeat for the other three shocks.
Trips
great advice!
dasgruvn is offline   Reply With Quote
Old 08-12-2003, 06:27 PM   #5777
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Originally posted by BBSpence
Hey Mike....i think you were pitted across from me a the Nats.
Hey, yeah, you are the guy with the sweet drivetrain right? Yeah, how's it going? I got picked up by AE, so I'm using your advice.
=MisFitz= NuKe is offline   Reply With Quote
Old 08-13-2003, 06:08 AM   #5778
BBSpence's Avatar
Trader Rating: 38 (100%+)
Heh, its pretty good Been kinda busy lately...have only raced once since the Nats. Congrats on the ride!
BBSpence is offline   Reply With Quote
Old 08-13-2003, 07:19 AM   #5779
rayhuang's Avatar
Thanks on the chassis. They are $85 shipped in the USA.
Old 08-13-2003, 07:27 AM   #5780
Fuzzy's Avatar
Ray,
Did you get my e-mail about the outdrives?
Fuzzy is offline   Reply With Quote
Old 08-13-2003, 08:02 AM   #5781
rayhuang's Avatar
Default IRS Lite Drives.
Dave-I sure did. I responded already. They are $30pr. (maybe a little less). YOu need the parts from the Steel Diffs to complete an IRS diff. YOu need the bearings, thrustwashers, etc.
Old 08-13-2003, 11:28 PM   #5782
Default Removing bearing seals
I just received a TC3 from someone who removed all the bearing seals. The car is noticably faster than stock.
Does anyone have suggestions on maintaining them? All bearings except the steering rack have the bearing seal removed.
Thanks,
Rob
dirtman is offline   Reply With Quote
Old 08-13-2003, 11:31 PM   #5783
Send a message via AIM to Johnnytc3
Dirtman, all you have to do is blast with motor spray and re-oil, they are easy to clean, but they do become dirty faster....
Johnnytc3 is offline   Reply With Quote
Old 08-14-2003, 10:10 AM   #5784
yeah, they are easy to clean, or you could find some seals for them, and all I ever do on my TCs is just take out the seals that arent exposed, keeps the bearings clean for a long time like normal, and increases efficiecy
Old 08-15-2003, 06:46 AM   #5785
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Looking to pick up a set pf spur and pinion gears for my Electris TC3, Any recommendations?
Any warnings?
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-15-2003, 07:41 AM   #5786
Ya, what do you guys run, 64 or 48 pitch?
Old 08-15-2003, 07:48 AM   #5787
Mike D's Avatar
Send a message via Yahoo to Mike D
If it isn't offroad, I don't see a need to use 48 pitch.
Mike D is offline   Reply With Quote
Old 08-15-2003, 08:46 AM   #5788
wheelmanST's Avatar
Send a message via AIM to wheelmanST
hey guys, thought i'd pop in here and show ya my killer speedo setup...im in the process of getting it ready for the rug. im using the mtroniks cube speedo, i like it so far. no problems yet. i ditched the huge factory cap for two smaller caps that are about equal to the novak cap on the gt7. i also got rid of the switch by shorting the switch tabs with a short length of wire. lemme know what you guys think.
wheelmanST is offline   Reply With Quote
Old 08-15-2003, 08:52 AM   #5789
wheelmanST's Avatar
two more
Old 08-15-2003, 08:53 AM   #5790
wheelmanST's Avatar
last one...i got everything to slip right under the shaft...and it will stay there, its not goin anywhere
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
