Old 08-08-2003, 02:25 PM   #5731
Regional Moderator
Send a message via AIM to Mike F
Hmm, never thought about that but that may be the reason they are not having any problems with them. Like you said, IRS recommends the cushions, it must be because of that.
Mike F is offline   Reply With Quote
Old 08-08-2003, 02:27 PM   #5732
TC3MIKE's Avatar
Send a message via Yahoo to TC3MIKE
I guess I'll stick with the IRS diffs then. I might tighten them up alittle on the front.
TC3MIKE is offline   Reply With Quote
Old 08-08-2003, 09:06 PM   #5733
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default ONE WAY DIFF YOKOMO
HI GUYS,
I HAVE BEEN RECOMMENED IN THIS FORUM THAT THE TC3 YOKOMO ONE IS THE BEST AND STRONGEST.
PLEASE TELL ME, CLICK ON THE LINK AND TELL ME IS THIS IT, AS IT SAY ASSEMBLY, I AM AFRAID THAT I MIGHT HAVE TO GET MORE THAN ONE PART FOR IT, OR IS THIS THE ONLY PART I
Regards Bradwww.kthobbies.com/store/tc3_parts.htm
Xray T4 16 | Sanwa MX11 | Much More Fleta | HW 3.1 | LRP Batteries | Team Argo | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 08-08-2003, 09:24 PM   #5734
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The Yokomo 1 way should be one of the strongest avalible. The only assembly would be attaching the gear to the 1 way, and pushing the drive cups into it.
Old 08-08-2003, 10:21 PM   #5735
OHBRAD's Avatar
Default ONE WAYS
CAN ANYONE RECOMMEND WHERE I CAN BUY A TC3 YOKOMMO ONE FROM AROUND THE WORLD OR AUSTRALIA.
REGARDS BRAD
Old 08-08-2003, 11:14 PM   #5736
bubbles's Avatar
try hobbypeople.net , or towerhobbies.com, the only minus of having the yokomo hd oneway, is that it is kind of hard on the dogbones, snaping all but the shiney steel MIP cvd's, I would have liked the orignal ASSOCIATED one(they don't make it any more), but the yokomo hd dose not break.,,,,,,,,,,,,,,,,sorry I can't recomend something or someplace to get one in Austrailia, but i live in SOUTHERN CA, I would just go to SoCal to get my oneway or hobbypeople or ultimate hobbies
bubbles is offline   Reply With Quote
Old 08-08-2003, 11:28 PM   #5737
Fred Hubbard's Avatar
What are you doing that causes you to snap CVD's using the Yok oneway? We've never had a problem snapping them ...
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-09-2003, 12:13 AM   #5738
hi,
i heard associated were no longer making blue oneways, but had switched back to silver colouring again. firstly, is this true? and if it is, why is this a blue oneway with the new delrin gear??
http://www.carttonic.com/catalog/ind...54,10280,14149
i was thinking it might be another brand in associated packaging or something, but again the delrin gear makes me think it's not
thanks
Trippin Freddy is offline   Reply With Quote
Old 08-09-2003, 12:30 AM   #5739
bubbles's Avatar
well, when the dots jump in front of me while i was running the blue CVD's with the one way, I would stay on the gas,,,,,,,,and sence the shaft drive has no "cushion", I would snap the bones right off, this is from beginner experences with the TC3.
hey fred, who is this "YOU FLYING POO" that keeps talking smack on you?
oh trippin freddy, the "delrin" gear is a new set of gears for the gearbox of the TC3 from AE, and the oneway is accually an YOKOMO part for the TC3 apperentley imported by AE
I think
or I may be wrong
Old 08-09-2003, 01:02 AM   #5740
bubbles - well yeah at first i thought it might have been the yok one too, but as i said the delrin gears (and looking again it also has some associated grease and instructions) made me think not. but i guess they just added these while they were repackaging?
Old 08-09-2003, 01:12 AM   #5741
bubbles's Avatar
YOKOMO ONEWAY IMPORTED BY ASSOCIATED
big box FULL of just oneways, sent here(to Southern California) then packaged at AE
Old 08-09-2003, 01:54 AM   #5742
OHBRAD's Avatar
Default YOKOMMO ONE WAYS
SO WHAT ARE WE SAYING ARE THE ASSOCIATED ONE WAYS THE YOKOMMO ONES
Old 08-09-2003, 04:48 AM   #5743
OHBRAD's Avatar
Default PART NUMBER
DOES ANYONE NO THE PART NUMBER FOR THE TC3 YOKOMMO ONE WAY SSEMBLY
Old 08-09-2003, 05:49 AM   #5744
OHBRAD's Avatar
Default ONEWAY YOKOMO PART NUMBER
OK GUYS NOW I AM CONFUSED THe link down the bottom of this page
this link call it a assembly
I just came from the american yokomo site and it call s up
a) SP-3938-6 HD Front One-way TC3
B)SP-3939-6 TC3 One-Way Ring Gear
C)SP-3976P6 Bearings (TC3/NTC3 HD One-Way)
D)SP-3950C TC3 Clamp Wheel Hubs
E)SP-3950E TC3 EZ Whl Hubs
ARE THESE ALL THE COMPONENTS THAT MAKE UP THE ASSEMBLY AS PER THE LINK OR DO I ONLY NEED SAY A AND B, OR MAYBE JUST A FROM THE LIST ABOVE, VERY CONFUSED NOW????
PLEASE EMAIL ME pepis1@dodo.com.au
Old 08-09-2003, 06:39 AM   #5745
DaveW's Avatar
Speedtechrc.com has the YOK HD oneway. Its right at 50$ USD, and comes with the outdrive cups, the outdrive bearings (since the one-way is metric, your standard diff bearings will not be used) and YOK supplies the ones you need) the one-way hub and the bearings installed, the gear and mounting screws, and six black o rings to place in the outdrive cups to keep them in place. It has a small instruction sheet with it to tell you what to do... small, but effective. One thing it does not tell you is the need to maintain it from one race to another. After race day you need to thoroughly clean it with motor spray, using the outdrive cups to actuate the one-way bearings in the hub. Flush and let dry. Then you need to repack it with a durable grease... I personally use a synthetic wheel bearing grease... placing it on the edge of the hub where the needle bearings are... and work it into the bearing with the drive cup shaft. The synthetic thick grease will give you a durable one-way, as long as you rebuild it on a regular basis. (some people may disagree on my choice of lube because it is so thick, but at 50$ USD a pop, i would rather have a durable one-way than buying a new one every few months because of a trashed hub bearing) Hope this helps...
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
