Old 07-31-2003, 08:12 PM   #5641
Fred Hubbard's Avatar
I know it won't fall down too far, but TTT anyway...WOW
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-02-2003, 07:50 AM   #5642
ttt
audiQuatro is offline   Reply With Quote
Old 08-02-2003, 09:02 AM   #5643
Roger's Avatar
Originally posted by Advil
Roger, Looks like 3 races in August.
Aug16/Practice Aug17/Race: make up for July race.
Aug23/Practice Aug24/Race: Normal August race.
Aug30/Practice Aug31/Race: First Annual Road Course Shootout.
Let me know what Electric class you will be running in(stock/mod). That way I know what class to have my hacking body on for......LOL
Art
Kewl. Thankyou Ninong Art I will probably just race nitro.
Roger is offline   Reply With Quote
Old 08-02-2003, 12:12 PM   #5644
I took my whole tc3 apart, rebuilt everything that needed it (differentials, shocks, ect.) and dremeled the battary slot and motor hole, and put the whole thing back together in one day , I felt very proud of my self. It takes a long time to dremel the battary slot, but I really like the way it handles with it. And I used a piece of an old stock TC3 foam bumper to keep the battaries still. But I don't have a digital camera to take any pictures of it . But it is a very good modification.
I also tried racing with the Alfa 2.0, and that is the best bodie I have ever used. I love it.
racerdx6 is offline   Reply With Quote
Old 08-02-2003, 06:06 PM   #5645
JSJ Racing's Avatar
Send a message via AIM to JSJ Racing
Default Rear chattering
What would cause the rear end of my tc3 to chatter in a corner?
I am running 1 degree camber, 30wt, number 2 piston, silver springs, sorex 36's, and my shock is in the middle top and outer on the a-arm.
Any thoughts?
JSJ Racing is offline   Reply With Quote
Old 08-02-2003, 06:07 PM   #5646
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
What is your droop setting?
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 08-02-2003, 06:13 PM   #5647
JSJ Racing's Avatar
I new I would leave something out droop 4 and camber link up and in.
Old 08-02-2003, 06:38 PM   #5648
rc-racer's Avatar
I wish I had that problem...I can't keep the rear end behind me, loose as heck!
rc-racer is offline   Reply With Quote
Old 08-02-2003, 06:45 PM   #5649
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
it could be the center one way, ive never ran it and dont know anyone who does. i only run the front one.
I run one. I love it. But both one ways rog??? jees u like ur steering lol.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 08-02-2003, 08:24 PM   #5650
rc-racer this is for you, try these droop settings on your car:
4 front & 6 rear
These settings will do two things for you. First, with a setting of 6 in the rear the car will transfer less entering the corner which will keep more weight over the rear, which will either cause your car to understeer into the corner or not. Secondly, a setting of 4 in the front will limit the amout of on-power steering the car has by limiting front-end transfer exiting the corner, which in turn will give the car more on-power rear traction while exiting the corner.
Old 08-02-2003, 10:27 PM   #5651
Default Re: Rear chattering
Any thoughts?
Are you running on carpet? Try thicker oil, sounds like you have to much traction.
barnacle is offline   Reply With Quote
Old 08-03-2003, 12:19 AM   #5652
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default ONE DIFF
HI Guys,
I was told last night that there are a number of one way diffs for the TC3, CAN SOMEONE RECOMMEND WHIS IS THE BETTER ONE TO GET, AND WHY THEY RECOMMEND THAT TO THE REST OF THEM.
Raced again last night and i believe the TC3 is getting faster with every run, has anyone had this same experience, i finally broke the 25 second at our track.
Can anyone also tell me. i was told last night about the number of shims in the gear box, can anyone recommend how many i should have in there, someone suggested none, others say some ???? confused
Xray T4 17 | Sanwa MX11 | HW 3.1 | Zombie Batteries | Team Mugen | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 08-03-2003, 01:59 AM   #5653
Ian_da_bomb's Avatar
Send a message via AIM to Ian_da_bomb Send a message via Yahoo to Ian_da_bomb
Thumbs up Too much Chatter in the background?
I think that the 4F and 6R droop setting is right on the money. But getting chatter with 36s? Yeesh! Must be running on velcro! heheeh. Maybe its a simple problem such as inserts being off or a tire being off the rim a bit? Also, I think that 30 Wt oil might be a bit thin. I am running 65F and 55R for my carpet setup and I usually run above 50 no matter what. I could be wrong but you might as well try somethin! Good luck!
Shimming and such
One of the huge things with a tc3 (I heard) was getting your diff cases set so that they didnt tweak and cause the bearings to run a little less free. I rebuilt my diff's with new outdrives last night and didnt use any shims but it was a good .010" to .015" play side to side. I just dont want it to bind. I think you just dont want the gear to bind as the diff moves right and left - I would just space accordingly. I cant see using more than one on both sides. Sorry for the vague answer. Good luck to you too! Ian
Ian_da_bomb is offline   Reply With Quote
Old 08-03-2003, 04:47 AM   #5654
JSJ Racing's Avatar
Default Chattering
I am running on asphalt...
Old 08-03-2003, 06:14 AM   #5655
lem2's Avatar
Default Re: ONE DIFF
Originally posted by OHBRAD
HI Guys,
Get the ones Made by YOKOMO for the TC3, its stronger and has bigger bearings and the outdrives are not brittle like the AE ones.
There is also one made by Tech Racing for the TC3
Or try using a spool.
Peace and happy racing!!!
lem2 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
