Old 07-28-2003, 09:45 PM   #5626
Roger's Avatar
I took out the center one-way and its better. It has a little torque steer but not much. Im also using an old futuba 9101 servo which is equvalent to an airtronics 737. Im thinking that the servo is bad cause I always have to adjust the steering trim to get the car centered. Im gonna put a digital KO 2144 in there and lets see what happens.
Roger is offline   Reply With Quote
Old 07-29-2003, 12:25 AM   #5627
Servo Saver?
Ahh running in DC Tuesday night made you want to run electrics again?
Sydewynder is offline   Reply With Quote
Old 07-29-2003, 12:19 PM   #5628
Ian_da_bomb's Avatar
Send a message via AIM to Ian_da_bomb Send a message via Yahoo to Ian_da_bomb
Arrow 2 way?
Why would you ever need 2 one way's? I would think the one on the drive shaft would actually help more since its not causing the drive shaft to move when you let off the throttle? Anywho... in any case - I think 2 is a bit overkill.... Lets get back to Diffs
Ian_da_bomb is offline   Reply With Quote
Old 07-29-2003, 02:03 PM   #5629
Trader Rating: 17 (100%+)
There was a guy in Salinas that used to use a one way in the front and in the rear. He was very fast in the corners but.... no brakes!!!
Roger, are your ride heights the same, left vs. right?
Art
Advil is offline   Reply With Quote
Old 07-29-2003, 02:10 PM   #5630
Rich,
The last time my car was doing that it was one of the front CVDs. It seems that the plastic ones can break just enought to let one side of the drive pin out (by the hub). Take a close look. It only acted weird in tight corners (full steering throw).
Art
Old 07-29-2003, 02:17 PM   #5631
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: 2 way?
We tried it on mine and it felt quite a bit like the Yok with the dual one-ways but "snappier"
Unfortunately it took so much bite off the rear that it was nearly undriveable.
However, it was kinda fun with only the shaft-one-way installed, regular diffs in front and rear.
Never tried it with solid front, mid one-way and rear diff, though.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-29-2003, 03:17 PM   #5632
linger's Avatar
Default Re: Tweaked or Not?
Originally posted by nitromike
I have a question about tweak. With my tc3, droop set same, car balanced side to side, shock length set the same with calipers, no binding in the control arms or ball joints: I put the car on my tweak station and it sits perfect, but if I take my finger and push down on the center of the gear case, the rear compresses equally. With the front wheels on the beam with the level, when I compress it, one side goes down farther than the other. When I let go, it returns to perfect level. I tried switching shock/ spring assy from side to side, now other side goes down more, same as when on other side. I tried another set of springs and does the same. Can this be adjusted out with preload spacers, or should I look at something else? Thanks for any help.
Nitromike,
My guess is that the shocks were not built equally. Remove the shocks and the shock springs and compress them. They should rebound at the same rate.
linger is offline   Reply With Quote
Old 07-29-2003, 06:35 PM   #5633
Roger's Avatar
Art
Art: Yes, ride heights are the same. Well, I balanced the car and shimed up afew areas up front. I got the car used and the shocks were totally jacked up. So, I rebuilt the shocks and now they are silky smooth. Now, the car doesn't have any torque steer. I also changed the whole steering rack. Art, when is your next race at Salinas ? York, Mashiga, and myself are racing at your next race.
Old 07-29-2003, 08:25 PM   #5634
[/QUOTE]
Nitromike,
Linger, I think that was my problem. I went back and checked and the shock that was acting up had a little too much oil and wouldn't compress as far as the other. I reoiled and got them the same, does better now. Thanks.
nitromike is offline   Reply With Quote
Old 07-29-2003, 10:40 PM   #5635
rc_bam226's Avatar
Hey Roger what did you do to the rack? I am very curious...
rc_bam226 is offline   Reply With Quote
Old 07-29-2003, 11:23 PM   #5636
melnyk's Avatar
Are you running foam tires check to make sure all your tires are the same size in diameter.
melnyk is offline   Reply With Quote
Old 07-30-2003, 01:01 AM   #5637
Roger's Avatar
Nothing really, just swapped out the old and in with the new. Good to hear from ya again. Hey, let's practice on Monday ( August 4 ( monday ) on carpet at HobbyWorld. Rich and I should be there from 11-?
Old 07-30-2003, 03:42 AM   #5638
What? No come back Rog? I see it's gonna be like dat. Alright then I'll just chill wid linger.
Old 07-30-2003, 08:28 AM   #5639
Roger, Looks like 3 races in August.
Aug16/Practice Aug17/Race: make up for July race.
Aug23/Practice Aug24/Race: Normal August race.
Aug30/Practice Aug31/Race: First Annual Road Course Shootout.
Let me know what Electric class you will be running in(stock/mod). That way I know what class to have my hacking body on for......LOL
Art
Old 07-30-2003, 05:49 PM   #5640
SpeedTech's Avatar
Hi Guys,
Just want to let you guys know we received more Tobee Craft TC3 hop-ups in stock. Also, check out the new super car bodies we are bringing in from Cheveronmodel Japan
New Cheveronmodel Super Car style bodies are in stock
Thanks for reading
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
