Old 07-27-2003, 11:19 PM   #5611
RAP66's Avatar
Default uneven suspension?????
I was giving my car the work over and noticed that the left side Arm doesnt sit at the same height as the right arm (my car is original with no droop screws, I have been updating my car as parts get damaged - very rare) Has any one noticed this on their car as well???
Rich Pedro
rap66@rcracing.com
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 07-27-2003, 11:29 PM   #5612
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Check how many internal limiting spacers are in your shocks. If its the same then check how long the shocks are, make sure one side doesn't have the shock end unscrewed mroe than the other.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-27-2003, 11:31 PM   #5613
RAP66's Avatar
Thanks Axiom...
I should have added that the shocks were off the car, just the arms with the linkages, matter of fact even with the linkages off their is a visible difference
Rich Pedro
rap66@rcracing.com
www.rcracing.com
Old 07-28-2003, 12:07 AM   #5614
Send a message via AIM to Johnnytc3
ive had that problem hardjoker, that was a couple years ago when i had a racer kit, it was the way the ball cups were screwed on the turnbuckles considering everything else was not binding, Try some RPM ball cups, that should solve your problem.
Johnnytc3 is offline   Reply With Quote
Old 07-28-2003, 12:12 AM   #5615
Dont get too worried about it though, the suspension arms dont ever drop down that low anyways with the shocks on. I would recomend getting the new arms with droop screws, it makes it so much easier and you dont have to get the new chassis.
Old 07-28-2003, 12:17 AM   #5616
RAP66's Avatar
OK... I wont worry about it much... I was concerned because my car(s) this is my stock setup, is starting to show an inconsistant left turn. Sometimes the car runs fine with no problem, and sometimes it hooks as if the suspension was gone, like loosing a shock or running the car 3wheel drive.
Rich Pedro
rap66@rcracing.com
www.rcracing.com
Old 07-28-2003, 04:30 PM   #5617
Check to make sure nothing is binding in the suspension. If its not that then i'd say you might have a twisted chassis...might be time for a new one. At least you can get droop screws
USVTA Member #211
Old 07-28-2003, 07:10 PM   #5618
Ian_da_bomb's Avatar
Send a message via AIM to Ian_da_bomb Send a message via Yahoo to Ian_da_bomb
Got Diff?
Please enlighten me on front Diff setups for the Tc3. I know of the one way, and i know of running it standard, and i know of locking it up. I would think that locking it up would create less on power steering and give you the feeling of having the rear end more stuck. It would also give you a bit more off throttle braking and better launch. What are other opinions on it? Ian
Ian_da_bomb is offline   Reply With Quote
Old 07-28-2003, 07:44 PM   #5619
Roger's Avatar
Default Torque Steer
I have an excessive amount of torque steer when I hit the throttle on my TC3. I bought the new chassis and arms, and the car is balanced. What would cause the car to steer to the left when I hit full throttle ??
Roger is offline   Reply With Quote
Old 07-28-2003, 07:51 PM   #5620
Have you checked the tweak? How old is the chassis? Do you remove the motor after every run?
James Nguyen is offline   Reply With Quote
Old 07-28-2003, 07:55 PM   #5621
Roger's Avatar
Chassis is new. There is no tweak and the car has no races on it....yet
Thx James. What do you think ? How's Billy and Tracy at Speedworld ? Tell them Roger Serafin said hello.
Old 07-28-2003, 07:57 PM   #5622
Roger do you run a one-way?
DOTMAN is offline   Reply With Quote
Old 07-28-2003, 07:58 PM   #5623
Billy and Tracy are great. Ill let them know. have you checked the camber/toe and all that?
Old 07-28-2003, 08:38 PM   #5624
Roger's Avatar
Yes, two one-ways. Diff and shaft. I was thinking about taking off the shaft one-way cause I think that may be the problem. I'll switch it out right now and i'll let you guys know.
James: camber is set a 2 degrees front and rear with 3 degrees of rear toe-in; - .5 on the front.
thx guys for helping me out
Old 07-28-2003, 08:58 PM   #5625
it could be the center one way, ive never ran it and dont know anyone who does. i only run the front one.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
