Old 07-13-2003, 01:17 PM   #5506
That shooter graphite main shaft looks very nice . I think I might get one of those for my TC3, where can you get them at? I have a composit shaft in my tc3 and they don't make the graphite shaft anymore, I think the graphite shaft would be more twist-resistant because it's stiffer.
racerdx6 is offline   Reply With Quote
Old 07-13-2003, 01:28 PM   #5507
Registered User
I got my at http://www.precisionrc.com/
Aku-Man is offline   Reply With Quote
Old 07-13-2003, 06:05 PM   #5508
tc3 racer sc's Avatar
Default how to install a fan on ur motor and what thread it on
hi guys i like to know what i need to do install fans on my motor to keep them kool, and can i run it off a reciever pck also and what thread it listed on also i ran in the nats it was an experience to see the top guys and also congrat to mike d. from maryland i race wth u at the durham track and ur god and dwn to earth guy thxs for coming dwn look forward racing wth u agin thxs reggie
tc3 racer sc is offline   Reply With Quote
Old 07-13-2003, 10:37 PM   #5509
xxxtracer32's Avatar
hi guys i havent raced on road in a long time, i was wondering if there is a website that has set ups ( aside from ae's own web site) basicaly im looking for a starting point for socal-something that will get me in the ball park. thanks in advance.
xxxtracer32 is offline   Reply With Quote
Old 07-13-2003, 10:44 PM   #5510
PizzaDude's Avatar
lots of setups for all cars.
http://www.rczone.net/
PizzaDude is offline   Reply With Quote
Old 07-14-2003, 10:58 AM   #5511
Send a message via AIM to munrath
Default Re: how to install a fan on ur motor and what thread it on
Reggie,
I installed a fan just the other week. When asking Mike Reedy at the NATS about it, he suggested a 5 volt fan. I found one in a Port Replicator (used for laptops) I then wired it to the 3rd channel on the receiver. Some were using small receiver packs to power the fans. The fan size is 40X40X10mm
You can do a search for laptop fans on the Internet I'm sure something will come up if you have trouble finding the 5 volt fan at your local electronics shop.
Hope this helps,
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 07-14-2003, 01:38 PM   #5512
Default High Front Roll Center and Low Rear Roll Center
Currently both my front and rear links are angled down which makes the front and rear roll centers high. The fast guys at the local track angle the front link down and the rear link up. This would give you a high roll center in front and a low roll center in back. What I believe this is going to do is give me more turn in entering a corner, a slight push in the center of the corner, and good grip exiting the corner. Any comments?
Brant is offline   Reply With Quote
Old 07-14-2003, 10:28 PM   #5513
Default thx mark
hey mark thxs for the advice i do hve a port replicator off my old lap top i tke a look at it thxs
Old 07-15-2003, 07:53 AM   #5514
Post
Hi!
a question from a n00b ...I hope it fits here
I made the Motor opening as big as possible...now I'm afraid that the chassis gets tweak.As the area around the Motor is "sensible" (the problem when the Motor-srew is tightened too much), I think that now the chassis tweaks when the motor is accelrating...could that be or is the chassis stiffen enough?! ...can you please tell me more about that .Sorry for my bad English and thx for the answears!
Best regards,caiba
Caiba is offline   Reply With Quote
Old 07-15-2003, 10:06 AM   #5515
mistercrash's Avatar
R/C Tech Charter Subscriber
I fixed the tweak problem on my TC3 by making a stiffening brace that I epoxied behind the motor compartment. Pics of the brace below. I still unscrew the bracket that holds the motor after every run to releave the stress on the chassis.
stiffening brace
stiffening brace installed
mistercrash is offline   Reply With Quote
Old 07-15-2003, 10:28 AM   #5516
but are there problems with the tweak too when the chassis is not prepared?
Old 07-15-2003, 12:03 PM   #5517
From what I've read in many forums, the TC3 chassis gets tweaked when the bracket holding the motor is screwed in too tight. Don't over tighten the motor bracket and unscrew it after every run to releave the stress and your chassis should be fine.
Old 07-15-2003, 12:12 PM   #5518
...ok...but as I cut off the chassis under the motor...makes it any difference to the tweak as when it is not cut...?!?
Old 07-15-2003, 12:17 PM   #5519
I'm not sure I can answer that. Only you can define if your chassis has more tweak than before.
Old 07-15-2003, 12:39 PM   #5520
the problem is that I modified it before I had my first driving with the TC3....
any other suggestions?!?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
