Like Tree4Likes
Old 07-06-2003, 11:47 PM   #5476
a spool is basically a diff that can't move. you can buy them as solid axles, or make them with you existing diff (by locking the diff really really tightly, or pinning it so the hubs can't rotate, or whatever other method). the solid axle type i assume would last forever, not ahving any moving parts, not so sure about the 'home made' type. I haven't used one so i can't tell you the pros & cons, but i know they can be very very fast when used in the right circumstances
Trippin Freddy is offline   Reply With Quote
Old 07-07-2003, 12:01 AM   #5477
Send a message via AIM to Johnnytc3
the homemade steel ones will last almost forever, ive used this setup for months now and i cant even see any signs of wear, i am also using pin cushions on the cvd bones.
Johnnytc3 is offline   Reply With Quote
Old 07-07-2003, 12:17 AM   #5478
sup
sup's Avatar
so in what circumstances do you typically use a spool? is that the same as a locked diff? thanks in advance!
sup is offline   Reply With Quote
Old 07-07-2003, 11:17 AM   #5479
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
rdub202, the new one-way's have larger bearings in them. They look like Yokomo's H.D. unit. So with the bigger one-way piece the gear needs a larger center hole so it can slide over the one-way. Hope that made sense.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-07-2003, 11:18 AM   #5480
CRASH's Avatar
Trader Rating: 26 (100%+)
TC4 Rumor
Heard a rumor from my lhs that there is a TC4 in the works, scheduled for around September. Any truth to that? Heard it was going to have revised front and rear hubs as well as some other chassis changes.
Thanks,
CRASH is offline   Reply With Quote
Old 07-07-2003, 11:53 AM   #5481
I asked Cliff Lett of Associated about that at the Reedy Race. If he was being honest with me, don't expect to see a TC4 anytime soon. R&D is still going on, but you're more likely to see modified parts and hopups than a new kit
DOTMAN is offline   Reply With Quote
Old 07-07-2003, 12:42 PM   #5482
Mike D's Avatar
Send a message via Yahoo to Mike D
The TC3's were mostly bone stock at the onroad nats. Even Cyrul's car had stock parts on it.
Mike D is offline   Reply With Quote
Old 07-07-2003, 03:57 PM   #5483
Originally posted by Hooked
He's so fast, I have trouble hearing him
dork
barnacle is offline   Reply With Quote
Old 07-07-2003, 05:00 PM   #5484
Originally posted by dirtman
I read about a spool. What is that? What advantage is it? Does it last long?
Thanks,
Rob
I think that a spool would pretty much last for ever. I don't know how you would break one, unless you had a spool made out of some plastic or something and you broke the outdrive part of it. But when you install a spool you durability on some drive chain components will go down. I've heard people of breaking many more things with a spool or one way installed.
racerdx6 is offline   Reply With Quote
Old 07-07-2003, 11:02 PM   #5485
Hooked's Avatar
Originally posted by barnacle
dork
Hooked is offline   Reply With Quote
Old 07-08-2003, 12:56 PM   #5486
Registered User
Default IRS Graphite Chassis
Is IRS graphite chassis moved the batteries closer to the center? Or only Warpspeed Demon did that?
Aku-Man is offline   Reply With Quote
Old 07-08-2003, 04:58 PM   #5487
Aku-Man as far as I know, warpspeed is the only car that moved the batteries closer to the center, from my experience being a warpspeed demon owner, the car works!
HARLEY is offline   Reply With Quote
Old 07-08-2003, 05:22 PM   #5488
noline's Avatar
Hey Mike D, can you post your setup and gearing from the roar onroad nats I would greatly appreciate it .
noline is offline   Reply With Quote
Old 07-09-2003, 12:32 AM   #5489
Default Unobtainium shaft
I was thinking of adding Unobtainium shafts to my shocks. Will I notice a difference? I've been spoiled by my Tamiya TA04 TRF dampners (very smooth) and the TC3 aluminum shocks are just not at that level.
Thanks,
Robert
dirtman is offline   Reply With Quote
Old 07-09-2003, 06:43 AM   #5490
Mike D's Avatar
Front: .063 sway bar, 40wt, #2, red springs, tc3 front shock tower, shock mount out on tower/in on arm, camber link up and long, 4 caster, 1.5 camber, losi steering blocks, no bump shims, standard ackerman, F-0 block, 5mm ride height, 6 droop
Rear: .063 sway bar, 30wt, #2, silver springs, tc3 rear tower, shock mount middle on tower/out on arm, camber link up and short on tower - upper position on hub, long wheelbase, R-2-0 block, 1.5 camber, 5.5mm ride height, 4 droop
Protoform Alfa 2.0, Batteries forward, chassis cut to move bateries towards center, IRS spool in front and IRS aluminum diff in rear, IRS aluminum dogbones w/ pin cushions, Handout tires, SMC GP3300, 38/98 gear, MVP handout (767 and stock springs)
This was my best(fastest) setup for the heat of the day. I changed my setup for the cooler track temperatures on Saturday. Saturday's setup worked well in the first main but wasn't as good for the 2nd and 3rd main.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
