Like Tree4Likes
Old 06-28-2003, 09:55 AM   #5431
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
racer-yes i am trying to get them off after they have been installed. i am trying to change my set up fo rhte first time and need to get them off in order to adjust caber and such. and i looked on the losi site and didnt find a "ball cup wrench" does it go by another name or do they not have it on the site or did i not look enough? someone help cuz i wanna get one of them!! thx racer
-Ry
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 06-30-2003, 11:09 AM   #5432
Default Gear question
What gear do I need to use for a 19t motor on a TC3? Why do all the gearing charts for Associated cars/buggies only have stock, then 16t and below? I was under the impression that 19t were fairly popular... Yes, I'm a newbie, and its pretty frustrating to get a motor only to find no info whatsoever in the manual or their website (which has a ton of info, except for that) on how to gear it...
-David
dizzy is offline   Reply With Quote
Old 06-30-2003, 12:00 PM   #5433
I was running a 24t pinion at my track. But it will vary for your track.
rdub- try to find someone with a losi and ask them if they still need their ball cup wrench. All it is, is a little piece of metal it doesn't have a handle and all those nice things. If you don't have dremel or rotory tool go to your local hobby shop and see if they will grind out a flat head screw driver to make a ball cup tool. Or mabey someone at your track will be able to do that.
racerdx6 is offline   Reply With Quote
Old 06-30-2003, 02:29 PM   #5434
Thanks, I'll probably be running at Socal most. Does anyone know why Associated excudes 19t motors from all of their gear charts? Just curious...
-David
Old 06-30-2003, 02:53 PM   #5435
rdub202's Avatar
racer would a tool like either of these work and if so how?
Old 06-30-2003, 06:46 PM   #5436
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Hey Guys,
Been struggling to gain a little more on power steering entering corners, last race I made the following changes throughout practice...
1. Went from 0 degree caster to 4 degrees (made a difference but not enough)
2. Went stiffer in the rear on the springs (again added a bit more but still not were I want it)
3. Went from 1.5 degree Toe-out to 1 degree Toe-In, this was a disaster, made the car undriveable under breaking for a tight corner...
My question is, should I adjust something else to correct the handling, because once I started figuring the car out I had the amount of turnin I wanted, but the car was on a fine edge from controlled to spinning out...
Any suggestions would be greatly appreciated, right now I am thinking about going to 0 Toe and seeing how that works next race...
Later!
TigeRyan
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 06-30-2003, 06:59 PM   #5437
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Have you tried running less toe in the rear? You could try longer wheelbase too.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-30-2003, 07:13 PM   #5438
I think the tool on the bottom would be perfect. Even better than my Losi ball stud wrench. All you have to do is inlarge the slot a little bit, it looks like it's too narrow to work, so try widening it a bit. It should probably also be a little deeper into the tool. So just enlarge the tool a little bit at a time deeper and wider. After you inlarge it a little bit test it on your car and see if it works. Just slide the tool under the ball cup and between the shock tower or the C-hub or where ever the ball cup is located. But make sure that the slot on the tool goes around the little part of the bottom on the ball on the ball stud. Than all you have to do is lift up that off the ball cup comes. If you don't have a dremel tell me and I'll see if I have any other ideas.
Old 06-30-2003, 07:25 PM   #5439
Are you just trying to pop the ball cup off the ball stud?
If yes, then just take a pliers and grip the flats of the ball cup. Rotate the cup and it will just pop off the ball stud.
If no, then I'm confused of what you wish to do.
It seems as if you are trying to make a lever to slip under the cup to pry it off. Am I correct? Just use the pliers and rotate it off.
AreCee is offline   Reply With Quote
Old 06-30-2003, 08:35 PM   #5440
TigerRyan...need a little more info.
Did you change the droop in front? increase the droop first..then try it (increase the amount on the droop gauge).
acloco is offline   Reply With Quote
Old 06-30-2003, 08:40 PM   #5441
TigeRyan's Avatar
I have not messed with droop yet, I am at 5 on both the front and rear, I've personally never found a reason to run uneven droop, but I am always up for suggestions
Old 06-30-2003, 08:42 PM   #5442
Droop won't really do much for you in terms of on-power steering. Droop is a corner exit and entry adjustment. Try less rear toe, i bet that'll work.
USVTA Member #211
Old 06-30-2003, 10:31 PM   #5443
Fred Hubbard's Avatar
You are off just a little, limiting droop in the front will yield more on-power steering. Less rear toe will allow the car to rotate more, not quite the same effect as less front droop, but close.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 07-01-2003, 12:16 AM   #5444
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Droop establishes the point at which the suspension stops moving (drooping, as it were) and more or less makes the car turn. It's kinda the limiter for movement prior to the turn.
The more droop, the more movement in the suspension prior to serious turn in. The less, the quicker the turn action begins.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-01-2003, 01:04 AM   #5445
RAP66's Avatar
I put the rear shock tower on the front.... similar to baker's but now I have almos no suspension travel... so I cut the cups & sprint retainers.. and got some back..
HOW exactly do you setup with the rear shock tower?
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
