Old 06-23-2003, 10:37 AM   #5401
Finsy's Avatar
anyone running the Novak brushless noticed that no ballast is needed to be put on the right side of the chassis...man!this ESC is really heavy....running on IRS chassis with GP3300 and electronics are KO2143/KO301F/a fan for the esc/Novak SS/dummy transponder w/ IRS holder/no motor heatsink/motor clamp heatsink was also dremel off , i need like 25grams of weight on the battery side...this was done by the hanging of the car by the 2 screws with holes that's used for the battery strap....anyone else running the Novak care to input some balancing tips??
Finsy is offline   Reply With Quote
Old 06-23-2003, 11:15 AM   #5402
What grease do you TC3 drivers put on your gears to help breaking them in before you cover them in teflon lube? Rick
Rick Draper is offline   Reply With Quote
Old 06-23-2003, 02:57 PM   #5403
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
You hung the car by the battery strap post holes? That's way off-center.
Try just looping some line around the drive shaft at the front input cup and rear input cup. The shaft is dead center and you should have a better time of balancing. . .
unless you just put down the wrong screws. . . DOH!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-23-2003, 04:47 PM   #5404
Finsy's Avatar
LOL...i'm never good with words.....likewise with rc ....what i meant was i hang the car using the screws with holes that is screwed in on the extra hole on the center of the diff cover
Old 06-23-2003, 04:49 PM   #5405
Boomer's Avatar
yeah, I figured something like that - just couldn't resist!
The thing is that friggin heavy? wow
Old 06-23-2003, 04:56 PM   #5406
Finsy's Avatar
yes it is......with the size slightly larger than a servo and the huge heatsink ...i could say it's at least10times heavier than my Quantum Comp without putting it on a scale...without the fan and the dummy transponder I would not need any ballast on the battery side coz it is just slightly heavy on the motor side
Old 06-24-2003, 05:59 AM   #5407
lem2's Avatar
Default QUESTION
what chassis is this and who makes them, the upper deck looks killer!!!
any info???
http://www.rctech.net/forum/attachme...?postid=411646
Thanks!!
Lem
lem2 is offline   Reply With Quote
Old 06-24-2003, 08:52 AM   #5408
That looks like the Flap chassis kit. Speedtechrc.com will be selling it soon
DOTMAN is offline   Reply With Quote
Old 06-25-2003, 09:57 AM   #5409
rayhuang's Avatar
Hi Guys,
Just FYI-I will be having my machinest do one more small batch of my Milled Tc3 chassis. I am going to see if he can do between 5 to 7 of them. They shold be done NO sooner than two weeks from today, but not more than four weeks-or end of July.
As always-thanks for everyones patience. This is not meant to be a money making deal for me-its just about making a cool product that makes us faster!!!! Thats one big reason I dont keep them in stock. If I did-I am sure it would tie up tons of my cash and end-up losing me money!!! And I am not rolling in dough-if you catch my drift!!!
But I like trick stuff!! Someday I am going to build my own 4wd electric sedan!!! Fast, efficient, easy to drive, adjustable, durable, stiff, untweakable and LIGHT!!!!!!! Yeah-right!!!
Thanks again,
Ray
Old 06-25-2003, 05:02 PM   #5410
hey guys anyone tried the RDLogics aluminum die-cast trans cases they look kind of sweet and there only 20$
crono man is offline   Reply With Quote
Old 06-25-2003, 05:19 PM   #5411
Super Moderator
Grizzbob's Avatar
Ray, what's the consensus on exactly how much we should mill out of the chassis? I've thought about it, but I want to be sure not to remove too much material....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-25-2003, 05:26 PM   #5412
rayhuang's Avatar
grizzbob,
I take the battery box down 0.050" and move the batteries in 0.50". I open the motor opening 0.10" per side and make a big hole under the servo. I also drill two holes under each of the tranny cases. All the holes are for weight!!
I didnt take any out in the electronics area cause its a pain trying to get an ESC and receiver to stay in with a sliver of graphite. I also dont open the motor hole totally because the molded motor mount can and does warp-so I believe in leaving some meat there for the longevity of the chassis and alignment of the pinion and spur!!
Ray
Old 06-25-2003, 05:27 PM   #5413
rayhuang's Avatar
Old 06-25-2003, 06:29 PM   #5414
sup
sup's Avatar
anyone list down the page regarding rpm/brp bumpers (which is better)? hehe! kinda lazy looking for it. thanks in advance!
sup is offline   Reply With Quote
Old 06-26-2003, 12:00 AM   #5415
Arun's Avatar
I just finally put the graphite chassis on my tc3 for the first time, and I was wondering why the battery does not need to be isolated from the chassis's sides. Isn't graphite a conductive material? Does the "graphite composite" not conduct like regular graphite?
http://nexusracing.com
Arun is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
