Old 06-17-2003, 08:34 PM   #5356
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Anyone care to share the best way to go about it, I am sure I could experiment, but 3-4 diff cases later I might have figured it out
TigeRyan is offline   Reply With Quote
Old 06-17-2003, 11:12 PM   #5357
Here's how I did it. First you have to remove the differential cases from the car. Than you put a bearing in one half and turn the case upside down, if the bearing falls out than your set, but if it stays in, than your not so set. So than just take a little bit of material out with a hobby knife or some sand paper, and try again. Do this for all of the differential halfs. Be careful not to remove too much material or there will be play, which you don't want.
racerdx6 is offline   Reply With Quote
Old 06-17-2003, 11:26 PM   #5358
Yeh that was what I did...the two center shaft support bearing slots are the hardest to sand
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 06-17-2003, 11:36 PM   #5359
those are kinda tricky.............
Old 06-18-2003, 10:07 AM   #5360
yodace's Avatar
I was wondering if someone could explain the best method on how to install rear/front mounts with out tweak the mount?
yodace is offline   Reply With Quote
Old 06-19-2003, 07:18 AM   #5361
Default Ackermann settings effect
Hi all,
Does anyone try the shims on the steering rack to change the ackermann settings? does it make big differences on driving feelings? Does it make the car twichy on high speed turns? Tell me your stories on that. Thanks
DanDan is offline   Reply With Quote
Old 06-19-2003, 08:11 AM   #5362
Dan- I think it's supposed to make the steering more aggressive. I've never tried it personally though, but that's just what I got from reading the back of my manual.
Old 06-19-2003, 10:37 AM   #5363
Default chassis mods
Hey everyone can anybody tell me a site that explains tc3 chassis mods. Like moving the battery slots over and making a chassis stiffener. Thanks
tc3xlr8er is offline   Reply With Quote
Old 06-19-2003, 12:45 PM   #5364
Arun's Avatar
Default Re: chassis mods
Go here
http://www.ultimewebtechnologie.net/...ciated_tc3.htm
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-19-2003, 12:50 PM   #5365
Registered User
Hi, I'm getting TC3 FT and I heard that TC3 is a weak car. Parts are easy to break, even with irs or hardcore hopup parts. Is that true?
Aku-Man is offline   Reply With Quote
Old 06-19-2003, 01:01 PM   #5366
All cars break parts if you hit something hard enough. When I first started racing my TC3 I broke parts, but I hit everything. I have to say that except for a bad glitch that sent me into a board I haven't had to replace a single part on my TC3 in over a year and a half due to breakage. I've only had to replace a couple of distorted body mounts and some worn out aluminum parts. I think the car is very durable. I still have my share of racing incidences, but my TC3s always drive away. They've been a lot more durable than some of the other cars I've driven.
DOTMAN is offline   Reply With Quote
Old 06-19-2003, 01:02 PM   #5367
CRASH's Avatar
Trader Rating: 26 (100%+)
Cool FTTC3 Weak, No Way!
I have a FTTC3 and I heard the same things when I got mine. I tend to hit things hard when I do hit things and have yet to break this car. It is a lot more durable then my XXX-s is, that is for sure.
Later
CRASH is offline   Reply With Quote
Old 06-19-2003, 01:12 PM   #5368
Registered User
True.
Old 06-19-2003, 01:12 PM   #5369
Registered User
Where can I get carbon fiber upper deck for TC3?
Old 06-19-2003, 02:48 PM   #5370
Go to the Warpspeed Thread and leave a message for Mr. Warpspeed or just email him directly Warpspeedracing@aol.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
