Old 06-13-2003, 07:55 PM   #5341
Send a message via AIM to ZER01
I just acomplished creating a spool with the stock diff parts you get with a factory team tc3, it took about 30 minutes to make and that includes cleaning all the parts, if anyone is intrested post and I'll reply.
ZER01 is offline   Reply With Quote
Old 06-13-2003, 08:00 PM   #5342
Send a message via AIM to Johnnytc3
Thats what im using right now too, a stock diff without the balls, works pretty well
Johnnytc3 is offline   Reply With Quote
Old 06-13-2003, 08:02 PM   #5343
Is that it, just no diff balls, seems like the diff would need alot of shimming afterwards.
Old 06-13-2003, 08:04 PM   #5344
several more but not much
Old 06-14-2003, 05:36 AM   #5345
are you guys using the stock plastic outdrives? if so are you running stock or mod? i made one with the steel outdrives that im using on asphalt right now. i think i will still get the irs one though next time i run.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 06-14-2003, 08:53 AM   #5346
i am using steel ones leftover from my old tc3, i figured the plastic ones would break in a hard crash.
Old 06-14-2003, 01:49 PM   #5347
Actually I made my first spool out of the composites but after thinking about the spool and after seeing how some aluminums come out after a hard race or two, I think I'm gonna convert it to the steel outdrives. Mine is basically like Johnny's but I made diff rings out of the AE double-sided tape.
Old 06-14-2003, 02:55 PM   #5348
ya, lol i cant see the composites lasting very long as a spool setup in stock or mod, hell they dont last long as a diff!
where have all the regulars on this thread been? it looks like alot of them have switched to xray from what i have seen.
Old 06-15-2003, 09:18 PM   #5349
Tips, hints, suggestions on making the drivetrain on the TC3 extremely FREE?????
acloco is offline   Reply With Quote
Old 06-15-2003, 11:07 PM   #5350
Some tips which you may find usefull for freeing up the drive train
1. Sand the gaer boxso that the bearings are not pinched (ie. blueprinting)
2. Shim the drive train correctly so that there is no binding
3. Flush out the thick grease in the bearings and apply light bearing oil
4. Use high quality bearings
5. Remove inner seals of the bearings in the gear box
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 06-15-2003, 11:15 PM   #5351
Hey ITCHYNADS,
Can i ask why ppl remove the seals from the bearings in the trans case?
Old 06-16-2003, 12:02 AM   #5352
Depending on the bearings you use you may need to remove the seal so there is less friction.
Most seals tend to rub against the bearing cage causing friction. Most people just remove one seal on the side not exposed to dirt.
Originally posted by Johnnytc3
Hey ITCHYNADS,
Old 06-17-2003, 05:35 PM   #5353
MOTO's Avatar
Default Cyruls Car
Hello every one! just wanted some help in locating the carpet set-up of cyrul's tc3. Any one here knows where? thanks friiends!
MOTO is offline   Reply With Quote
Old 06-17-2003, 05:42 PM   #5354
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
itchynads,
What part of the transmission case are you shaving, the bearing wheel or somewhere else???
thanks
TigeRyan is offline   Reply With Quote
Old 06-17-2003, 06:31 PM   #5355
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Tigeryan,
You shave the bearing recesses in the diff cases.
As for bearings, if you don't mind maintaining your bearings every week you can go with no seals for the least friction.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
