Old 06-09-2003, 05:18 PM   #5281
Registered User
Does he have a webite?
Thanks!
B1015er is offline   Reply With Quote
Old 06-09-2003, 05:29 PM   #5282
goto socal.rcracing.com
DOTMAN is offline   Reply With Quote
Old 06-09-2003, 06:08 PM   #5283
Registered User
Gotcha, thanks!
Old 06-10-2003, 12:17 AM   #5284
Send a message via AIM to Johnnytc3
hey guys,
just wondering what some of you guys/gals are doing to make your tc3 whisper quiet
johnny
Johnnytc3 is offline   Reply With Quote
Old 06-10-2003, 06:00 AM   #5285
Adjust the gear mesh properly to eliminate the whine. Check that all the bearings spin freely. Clean it. However, it will never be as quiet as a good belt driven car.
AreCee is offline   Reply With Quote
Old 06-10-2003, 08:51 AM   #5286
That's not true. I know a few guys at SoCal who have TC3s that don't make any noise. They won't tell me what they did though. I use a special pinion gear and I use white lightning on my diff gears. That and shimming made my car very quiet and smooth.
Old 06-10-2003, 11:13 AM   #5287
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Do you have the new white delrin gears? Those free up the drivetrain a lot and make it really quiet too.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-10-2003, 12:00 PM   #5288
Are you referring to the new Associated off-white gears? I hear they are more durable but they're not delrin
Old 06-10-2003, 12:25 PM   #5289
Yes i am, i heard they were delrin. They do make the drivetrain much quieter and more free.
USVTA Member #211
Old 06-10-2003, 01:22 PM   #5290
I'll have to try them. I asked on the Associated web site if they were delrin and the person that responded said they were not and sounded a little irritated by my question. I guess he had answered it one too many times before.
Old 06-10-2003, 01:37 PM   #5291
Oh, I believe i heard they were delrin from a local team driver..maybe i'm wrong.
USVTA Member #211
Old 06-10-2003, 01:40 PM   #5292
Yeah they don't look like delrin...that's for sure. Delrin is usually bright white but these are more of a dull yellow
Old 06-10-2003, 02:02 PM   #5293
I don't really care what they're made out of, they are better.
USVTA Member #211
Old 06-10-2003, 03:23 PM   #5294
Arun's Avatar
It is not hard to make a tc3 quiet. All you need is, first of all, a new pinion and spur. That should take care of most of it. Then, routine maintenance on the r&p gears (ie. cleaning each tooth thouroughly) Then clean all the bearings and re-lube them with a light bearing oil.
Also, if not using the bearing spacers, make sure the wheels are not overtightened.
One common problem is worn cvds and outdrives, they can make a TON of noise.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-10-2003, 04:43 PM   #5295
Yes proficar, you are right the spur as it wears starts to make more noise, as the spur wears you can flip it and get twice the life.
What do you put in the diff case or do you run it dry?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
