Like Tree4Likes
Old 06-06-2003, 12:45 AM   #5266
Send a message via AIM to Johnnytc3
you can use any kind of polishing oil, even car polish, i actually used some leftover 800 wet/dry sandpaper from lapping my heatsink a while back, works well and works quickly.
Johnnytc3 is offline   Reply With Quote
Old 06-06-2003, 05:46 AM   #5267
hoj
If the car is new right from the box, normally there is lot of burr between C-hubs and A-arms. Also some burrs are normally located in hinge pin inner outputs on the A-arm. Remove them first.
hoj is offline   Reply With Quote
Old 06-06-2003, 07:40 AM   #5268
Location: Built By The Racers For The Racers. Corona CA
Default Re: Battery fitting
Thanks Hooked, that worked perfect. I also used the Trinity Bars, (they are flat) instead of Deans.
The batteries fit nice and snug now.
R/C HEAT is offline   Reply With Quote
Old 06-06-2003, 02:01 PM   #5269
Send a message via AIM to ZER01
Default Re: freeing up suspension
Originally posted by Charles
Hello, I am putting together a ft tc3. I noticed that the suspension was somewhat tight, the arms don't drop after I lift them up (shocks disconnected). What can I use to free up a arm and pin and ballcups? Thanx
Charles Stevens
Mine was the same and after a few practice laps the arms freed up. That and make sure you don't have a defective ballcup that binds on the ballstud. I've never had an AE ballcup bind up but I have had Losi and RPM ballcups bind on a ballstud. I've also had some defective titanium ballstuds from robinson racing do the same. You don't need to polish any ballstuds or hinge pins.
ZER01 is offline   Reply With Quote
Old 06-06-2003, 07:46 PM   #5270
Dingus's Avatar
Been a couple of years since my FT TC3 was new, but I remember a lot of masaging of the arms to get them to hang free.
Mostly sanding material where the arms and c-hubs meet. Ballcups will loosen after you pop them once or twice and the hinge pin polishing just seems like a waste of time.
Dingus is offline   Reply With Quote
Old 06-06-2003, 09:44 PM   #5271
mushu's Avatar
Proudwinner,
I actually had a bad AE ballstud on my last FTTC3 kit. It was the wrong diameter and was rough. No biggie because I had a spare, but it does happen. *shrug*
mushu is offline   Reply With Quote
Old 06-07-2003, 04:33 AM   #5272
can any one tell me if a 6 stick pack will fit into a tc3
acid_rain182 is offline   Reply With Quote
Old 06-07-2003, 04:36 AM   #5273
theisgroup's Avatar
yes, it will fit. just turn the battery strap over
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-07-2003, 05:31 AM   #5274
thanks for that
can any one tell me what the main parts that break on the electric tc3.
thanks
Old 06-07-2003, 06:04 AM   #5275
lem2's Avatar
Originally posted by acid_rain182
thanks for that
thanks
the front and rear arms, the suspension holders, but the breakage will be less as soon as you get acustomed to the car, get a BRP,RPM or a penguin bumper.
lem2 is offline   Reply With Quote
Old 06-07-2003, 06:10 AM   #5276
thanks for that
thanks
You'll mainly want to stock up on front arms and hinge pins. Get the BRP polished steel hinge pins they are slightly stronger than the stock AE pins. Spare front arms holders are nice to have around too.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 06-07-2003, 06:11 AM   #5277
thanks
are these the 2 parts you where talking about
http://www2.towerhobbies.com/cgi-bin...?&I=LXNZ76&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXNZ74&P=7
Old 06-08-2003, 07:29 PM   #5278
Get a RPM front bumper too. I haven't broken my front end once with it, you can get it from Tower too. I don't think he meant the suspension arm mounts, I think he meant the actual hinge pins. Hope this helps.
racerdx6 is offline   Reply With Quote
Old 06-09-2003, 04:06 PM   #5279
Registered User
Any one know who painted Barry Baker's body from the Reedy race?
B1015er is offline   Reply With Quote
Old 06-09-2003, 04:36 PM   #5280
howard hudson's Avatar
R/C Tech Charter Subscriber
here ya go
Congrats to Baker!
Car painted by CFX (Charlie Barnes)
page 18 on the reedy thread
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
