Old 06-03-2003, 09:49 PM   #5221
Location: Built By The Racers For The Racers. Corona CA
Default Pic
Ya, please post a pic.
R/C HEAT is offline   Reply With Quote
Old 06-03-2003, 10:00 PM   #5222
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Originally posted by Finsy
Axiom5B - i try the changes that you sugested and will see if that helps....locally there's no color coded foams available only with shore rating....i'll try 37 front 35 rear the next time i hit the track...by the way would your suggestion be good on a one way or a spool
thanks
Try going to www.shopatron.com and click on Trinity and go to TRC foam tires and get sedan foam tires in 26 mm Plaid and Purple. Really good prices. Actually better yet go to www.kthobbies.com and get them from Kraig. And that would be with a diff, btw. Foams have a lot more traction so you can drive them much harder. Spool would work too, but oneway would have a ton of steering, probably too much.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-03-2003, 11:22 PM   #5223
Hooked's Avatar
Default Re: Pic
Here is pic one ... the inside of the chassis ... notice the tape is starting to wear ...
Hooked is offline   Reply With Quote
Old 06-03-2003, 11:24 PM   #5224
Hooked's Avatar
Here is pic two ... it is permanent sticky on one side ... I clean the chassis with Isopropal (denatured alcohol) so the sticky part of the foam stays stuck ...
Old 06-03-2003, 11:33 PM   #5225
Hooked's Avatar
Here is pic three ... the white line indicates the thickness of the chassis while the yellow line indicates the thickness of the foam ...
Old 06-04-2003, 07:11 AM   #5226
Finsy's Avatar
Pic of my ride:-
posted specially for "Hooked" ...
Finsy is offline   Reply With Quote
Old 06-04-2003, 07:49 AM   #5227
tc3 are sh't. tamiya 414 m 2 wcr and tb evo 2 ,3 are even better.on low grip tracks the best a tc3 can do is last in the b final!
trf man is offline   Reply With Quote
Old 06-04-2003, 07:55 AM   #5228
Finsy's Avatar
Old 06-04-2003, 08:00 AM   #5229
lem2's Avatar
This is a TC3 Thread. You are talking about the B main.
At the recently concluded Reedy Race TC3 was 1st (baker) and the Tamiya Kit was somewhere in the 4th (jun) and 18th place(the World Champ, Surikarn)
It was dominated basically by non-Tamiya kits, at a Tamiya Home Track!!
Anyways, still regardless of what kit - it is stillthe driver and Driver skills!!
lem2 is offline   Reply With Quote
Old 06-04-2003, 08:06 AM   #5230
shame tamiya werent using there world champ other wise he would have pissed over everything
Old 06-04-2003, 08:28 AM   #5231
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Out of curiosity - can you read?
The World Champion (Surikarn) was 18th place with his Tamiya on the Tamiya Home Track.
Go back to your Tamiya thread please. And have a nice day!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-04-2003, 08:31 AM   #5232
Finsy's Avatar
TRF - is this the car you mentioned
Old 06-04-2003, 08:35 AM   #5233
Finsy's Avatar
is this the car you're interested in knowing whether it will be imported to UK
Old 06-04-2003, 08:39 AM   #5234
Finsy's Avatar
fate of the car u interested in
Old 06-04-2003, 08:42 AM   #5235
lem2's Avatar
Default FINSY
Great Car!!!! (IRS-FTTC3)
Question sir: What is that thing you placed on the front brace that looks like it was connected to the C-hub?
Is that a torque Rod?? Could you discus or explain that Hot Mod you did. If its a secret--- please share it hehehehe!!
Thanks!!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
