Old 05-28-2003, 01:00 PM   #5191
Originally posted by racerdx6
Wiley- Here's another idea I had to figure out your servo centering problem. One you TX reverse the steering servo. Than try steering left and right. The servo doesn't center after steering right, but it does center after steering left? If the transmitter were the problem, when you reversed the servo, the servo wouldn't center properly on the opposite side it didn't center before. So the servo would center after steering right, but not after steering left. Try this and see if it works. I have a feeling that your transmitter isn't working properly. You could also try the transmitter in a different car and see if it works than.
racerdx6 - i'll try this...i have been running a stock TC3 which i intend to convert to rally specs once i get my FTTC3 running...i will also try to change the steering parts from this stock TC3 to the FT as the stock one doesnt exhibit this issue
wiley is offline   Reply With Quote
Old 05-29-2003, 03:05 PM   #5192
Hooked's Avatar
The only difference between the FT and Racer kit steering rack is the bearings (FT) and bushings (racer) ... everything else is exactly the same.
Hooked is offline   Reply With Quote
Old 05-29-2003, 03:12 PM   #5193
Marines's Avatar
Send a message via AIM to Marines
Umm...i think u forgot about all the aluminum, and the graphite chassis
Marines is offline   Reply With Quote
Old 05-29-2003, 03:20 PM   #5194
Send a message via AIM to Johnnytc3
he is just talking about the steering rack..... i think
Johnnytc3 is offline   Reply With Quote
Old 05-29-2003, 03:50 PM   #5195
Hooked's Avatar
Key words above ... steering rack ...
Old 05-29-2003, 07:26 PM   #5196
Marines's Avatar
oooo yeah...my bad guys
Old 05-30-2003, 02:17 PM   #5197
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Did you guys know there is an editable version of the TC3 setup sheet here- http://www.msra-racing.com/features/setupsheets.htm
It's in Acrobat and looks just like the regular one, but you input your setings and then print it!!! Just like the pros- lol
BigDogRacing is offline   Reply With Quote
Old 05-30-2003, 03:01 PM   #5198
Hooked's Avatar
Sweet ... thanks man ...
Old 06-01-2003, 05:04 AM   #5199
don't mind me just checking my gif.
Art Jensen is offline   Reply With Quote
Old 06-02-2003, 11:03 AM   #5200
Default White plastic ring gears and pinion gears
Has anyone used the white plastic ring gears and pinion gears? I can't get them to fit in the differential housing. Anyone else having the same problem. Are there new diff housing for the white gears?
Brant is offline   Reply With Quote
Old 06-02-2003, 06:48 PM   #5201
Hi all, new user here. Got a question, I've been using the Novak SS system for several weeks now. I've been having a hard time trying to get rid of an off power push. My setup has gotten a little off the beaten path, but it is driveable.
Just wondering what some of you have done to over come this. I feel like anyone with the SS in a TC3 would have the same problem.
chance is offline   Reply With Quote
Old 06-02-2003, 07:40 PM   #5202
Arun's Avatar
If your battery is in the rear position, the easiest way to get rid of the off power push is to move it forward. Otherwise, I would mess with my suspension in order for the car to throw more weight toward the front of the car when I let off the throttle.
Arun is offline   Reply With Quote
Old 06-02-2003, 07:52 PM   #5203
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Default Re: White plastic ring gears and pinion gears
I have heard of 1 person who had the same problem as you are having. The only thing that we could come up with is that his car had the original gear box pieces. If you have the new ones that are the same as the NTC3 then I am not sure exactly what the problem is. Where does it rub, the gear itself? Curious minds want to know.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-02-2003, 09:17 PM   #5204
Finsy's Avatar
I have an IRS chassis FTTC3 and need some help in setting up the kit. The car seems to hookup during off power and spin out during on power.If I practically slows the car it doesnt hookup. I was thinking of putting in heavier weight oil as it seems that weight transfer from front/rear is very fast.Does putting heavier oil slow the weight transfer?If so what is a good weight to start off with?I have from 30-70wt oil in my pit box.
My setup:-
Aspalt medium to high traction
Front
35 shore GRP foam
30wt oil
red spring
1.5deg camber
4deg caster/no kickup
0deg toe-out
camber links long(inner/upper)
balldiff/steel diff halves
aluminium CVD/pin cushion
5mm ride height
droop 6 on Assoc. gauge
Rear
35 shore GRP foam
30wt oil
blue spring
1.5deg camber
3deg toe in
balldiff/plastic diff halves
composite bones
battery upfront
5.5mm ride height
droop 4 on Assoc. gauge
Once I get the car running right I already have a locked diff and also a one way to try which is better for my local track.If anything is missing from my setup please do let me know so that you guys can help me better
Finsy is offline   Reply With Quote
Old 06-02-2003, 09:19 PM   #5205
Send a message via ICQ to Tsubasa Sakai
Hi guys,I just got a TC3.Can someone shows me what is the best way to solder the battery connector?Seem the normal 3x2 saddle pack with vertical connector doesn't fit any all.
Thanks.
Tsubasa Sakai is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
