Old 05-24-2003, 07:16 AM   #5161
Originally posted by TigeRyan
I have one other thought similiar to the last gent....
Make sure you have replaced any ball cups in the steering linkage with RPM ball cups they are thicker and may run on the chassis and catch and they will require a slight tap to get past that point, and depending on the angle it could only happen going one direction....
Just another thought...
HTH
RPM are used on all ends except for the servo to the center rack turnbuckle
and also no protusion from the ball stud on the rack
i'm pretty much stumped by this problem....
wiley is offline   Reply With Quote
Old 05-24-2003, 08:05 AM   #5162
lem2's Avatar
Default wiley
okay, are you using the same reciever for your cars?
maybe there is something wrong with the reciever on your TC3.
Looking at my car right now, since I am rebuilding it also.
It's like a "twilight zone!" with what ur going thru. heheheh
lem2 is offline   Reply With Quote
Old 05-24-2003, 08:27 AM   #5163
Default Re: wiley
different rx....i'll try to change to another receiver...will let u know the outcome...car is in pieces right now
Old 05-24-2003, 11:08 AM   #5164
If you want the best ball cups on the market....and I HAVE tried them all.....use the Schumacher ball cups. NO SLOP! Super strong (look at the abuse the Schuie's get)....
I use the Schumacher ball cups with titanium ball studs....perfect setup. These are also thin at the top of the cup....so they will NOT rub on the inside of the rims..etc..etc.
acloco is offline   Reply With Quote
Old 05-24-2003, 01:42 PM   #5165
FREAKAH's Avatar
We used to use Schumacher ball cups too back in '95-'96 for our offroad cars until our LHS stopped stocking Schumacher cars and parts.
Those ball cups are hard to pop on BUT theyr'e equally hard to pop off too.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-25-2003, 04:02 PM   #5166
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
is there an easy way to remove the drive shaft on my tc3? or do i have do go into the gearboxes and do all that jazz?
-RyaN-
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 05-25-2003, 04:08 PM   #5167
the easiest way is to unscrew the lower shock mounts then open the diff case enough to take out the front input shaft and you can then get the shaft out.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 05-25-2003, 04:12 PM   #5168
rdub202's Avatar
Thumbs up
aight thx
Old 05-25-2003, 08:26 PM   #5169
Default FT TC3 Front lower arm breakage (version2)
Hi to all,
need help. I have had my FT TC3 for about 2 months and in this time i have broken 3 Front lower arm (version 2). It happens every time my car hits the side kerb. even when off throttle (i am using 15 turn). I am curious why i keep breaking the arm so easily when it is graphite. I noticed that it breaks at the area when the suspension arm is screwed into the lower arm.
Have any of you had this problem?
Can i solve it with a stronger and bigger bumper?
Also, will after market arms be better? How about the normal arms (non graphite) be compared to the graphite ones?
Cheers
ASWK-TC3 is offline   Reply With Quote
Old 05-25-2003, 08:35 PM   #5170
Send a message via AIM to Johnnytc3
graphite will break easier, get your self a rpm bumper, it will help prevent you from breaking so many arms.
Johnnytc3 is offline   Reply With Quote
Old 05-25-2003, 08:55 PM   #5171
Hooked's Avatar
Default Re: FT TC3 Front lower arm breakage (version2)
Originally posted by ASWK-TC3
Hi to all,
... I noticed that it breaks at the area when the suspension arm is screwed into the lower arm.
Do you mean where the shock is bolted to the front arm?
Hooked is offline   Reply With Quote
Old 05-25-2003, 09:00 PM   #5172
Default Front Lower Arm (version 2)
Hi,
you are right. SOrry about the typo error, i meant where the suspension is bolted to the lower arm.
Cheers
Old 05-25-2003, 09:06 PM   #5173
Hooked's Avatar
In general, the stock plastic parts will be more forgiving since they flex more before they break ... however the graphite ones are more rigid and in turn will snap easier than plastic ...
Old 05-25-2003, 09:11 PM   #5174
Hooked's Avatar
Default Re: Front Lower Arm (version 2)
Hi,
Cheers
No worries on the typo ... I was just confused on the wording ... "shock" vs. "suspension" ... The car's suspension is made up of many parts, including the shock, the arm, etc. ...
just wanted to clarify what you were referring to ...
Old 05-25-2003, 09:25 PM   #5175
lem2's Avatar
Default Re: Re: wiley
whats up?? did the reciever fixed the problem
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
