Old 12-05-2001, 09:39 PM   #496
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
TP > Can you answer the questions I asked you?
thanks....
wolfeman09 is offline   Reply With Quote
Old 12-06-2001, 07:29 AM   #497
TPhalen's Avatar
R/C Tech Charter Subscriber
Sorry Matt....
Ok, use the black grease that comes in the kit.
The Red Grease (sorry, don't know the part number, but the label writing is red) is used to lube the bearings IN the one way. Use this grease only for this purpose....
And the Losi Grease is used only for lubing the gears externally. It's not completely necessary (as Corse-R mentioned) but it does help keep the gears super quiet...
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 12-06-2001, 07:39 AM   #498
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
I think the red label grease is thicker than normal diff grease and used for the AE pan car diffs.
Airwide is offline   Reply With Quote
Old 12-06-2001, 01:55 PM   #499
wonderboy's Avatar
Okay Tony, I have 2 shims in the front and back now and the whole car is quiet. Thanks again for the warning about with no shims. I won't run it that way.
Also who designed the screws that mount on top of the swaybars? They are a little small and the bars pop out when the suspension compresses. I just cut some small round pieces out of a sheet of stiff lexan and stuck them under the screws to give them more area to grab on too. I guess this is alright to do??
wonderboy is offline   Reply With Quote
Old 12-06-2001, 02:41 PM   #500
TPhalen's Avatar
As long as it doesn't bind the sway bar. Remove the links on the end of the sway bar and the bar should flop up and down without any resistance.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 12-06-2001, 02:51 PM   #501
Yokomo Fan's Avatar
That happens to my rear sway bar, it pops out, but i just used c-clips, but some people suggest o-rings, but i find that the c-clips fits in neatly, and i can't see how o-rings can fit in as the bulkheads would be in the way!
Hey guys any tips for keeping the foam bumper where it should be, when crashes happen the bumper pops up, i think that ae should make a bumper brace for the tc3 like they did with the mr4-tc, xxx-s, and the tc3 nitro.
Yokomo Fan is offline   Reply With Quote
Old 12-06-2001, 03:52 PM   #502
wolfeman09's Avatar
TP > Thanks!!!! Is there a way to check what part number the red lettering grease is? IF not, then i will use the one in the kit.
Yokomo Fan > just use the round plastic disks that come when you purchase the body posts, then drill a small hole in the post and put a body clip through it. This will keep the bumper down.
And TP can answer this, will the new TC3 Nitro bumber holder fit on the Electric TC3?
Old 12-06-2001, 07:43 PM   #503
over gear's Avatar
Trader Rating: 15 (100%+)
I use HPI Pro2 front body post on my TC3. it has lots of holes! and same price as the TC3 body post...
over gear is online now   Reply With Quote
Old 12-06-2001, 08:02 PM   #504
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Good advice over-gear. I do the same, and I also use those cool adjustable HPI caps too. If you cut the post to the exact right size, you can adjust the caps to work on all the good bodies; stratus, vectra opel, accord, etc. It reallt makes the body posts look clean by not having them stick up higher than one hole.
BigDogRacing is offline   Reply With Quote
Old 12-07-2001, 08:09 AM   #505
TPhalen's Avatar
The new front bumper holder will only work if you replace the TOP of the front gear case, the lower bumper, and I think something else under the front of the car...basically, it's not a simple swap.
The red grease you might be able to find the part number on AE's site.
Re: Sway bars. To hold them in better, use the small washers that you would use to space the rear hubs forward/back. Cut one of the spacers so that it has a flat edge and it will fit on the side of the sway bar that is REALLY close to the gear case (you'll see what I mean when you try to install these).
I like the idea of the o-ring....but you'll probably still have the same problem as you would with the washer.
A REALLY trick method is to use motor shims....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 12-07-2001, 08:57 AM   #506
wolfeman09's Avatar
TP > Thanks.....
I have used the HPI ones in the past as well and they do include more holes in the post. Either way will work. The AE's ones come with the little plastic washer and i dont the HPI's do.
The plastic is real soft and making a hole is very easy.
Old 12-07-2001, 09:06 AM   #507
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Part # for the Red Label grease is 6636 I believe. I used to work at a hobby shop and I retain part #'s for years for some reason.
Jack Smash is offline   Reply With Quote
Old 12-07-2001, 11:12 AM   #508
Yokomo Fan's Avatar
Thanks for all the advice guys!
I'll try and get a AE or Hpi body post set!
Old 12-07-2001, 12:53 PM   #509
Send a message via AIM to Type S
can some one give me a good setup for ozite carpet?
also i just bought some nuclear power sanyo 3000's
360sec, 1.15 and 360 1.11
Type S is offline   Reply With Quote
Old 12-07-2001, 01:51 PM   #510
TPhalen's Avatar
Type S: Check my site under R/C Tuning/Racer Setups
I think I have a few carpet setups there...
Tony Phalen
RCDriver.com
CompetitionX.com
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
