Like Tree4Likes
Old 05-09-2003, 11:04 PM   #5056
No, I have never had any problems
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-09-2003, 11:08 PM   #5057
Hooked's Avatar
Thanks man ... I'm gonna give it a try ... I don't often have to pull the hingepins out, but when I do it typically needs to be done in a hurry ...
Hooked is offline   Reply With Quote
Old 05-09-2003, 11:17 PM   #5058
Just remove the material that goes behnd the diff case, but leave the material that comes in contact with the front of the case.... this protects the pin mounts and pins from impacts....
Old 05-10-2003, 07:13 AM   #5059
Hooked's Avatar
Thanks ... I'll do that.
Old 05-11-2003, 07:50 PM   #5060
Coxy's Avatar
R/C Tech Charter Subscriber
How much droop are you guys running front and rear for Carpet. Also how much droop are you running in general and what surface.
Coxy.
Coxy is offline   Reply With Quote
Old 05-12-2003, 03:50 AM   #5061
johnny55's Avatar
Send a message via AIM to johnny55
Slow on the sweeper
Hey I was racing this weekend at socal and my car seemed really slow on the sweeper. Im not sure if my car was slow or if it was just me. I just thought Id ask to see if someones experienced this yet with their TC3. I was running a one way for the first time. What should I check for sweeper action!!??
johnny55 is offline   Reply With Quote
Old 05-12-2003, 05:46 AM   #5062
What are the best rubber tires to use on outdoor asphalt?
HeavyD is offline   Reply With Quote
Old 05-12-2003, 05:53 AM   #5063
CRASH's Avatar
Trader Rating: 26 (100%+)
Post Coxy
For carpet racing I am running 6 front 4 rear for droop. I am basically running the factory setup for carpet. The car is planted extremely well.
Later
CRASH is offline   Reply With Quote
Old 05-12-2003, 07:08 AM   #5064
DaveW's Avatar
Ok guys... my Yok one-way for the TC3 and the bladder caps are on the way from SpeedtechRC. Is there any difference between the standard AE one-way of old.. compared to the new Yok one way... other than durability? Can or should i use a different lube in the bearings than the grease that is in them? Are there parts available from Yok for the one-way... or if there is failure... do i simply buy another? As far as the caps go... i know there is differing bound/rebound characteristics with bladders in shocks, and would like to know if anyone has experience building these for asphalt, and could give me some pointers. "Foam volume compensator" ...yes or no? My experience with bladders came and went with an old HPI pro of years ago. Since then i have used bleeding screws in the caps. So any help would be appreciated.
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 05-12-2003, 11:01 AM   #5065
CRASH's Avatar
Post DaveW
The Yokomo one-way is identical to the new Associated one. I have an old one-way by Associated and my lhs just got in the new Associated one-way and the Yokomo one-way. They are identical in everyway.
I have not tried my Yokomo bladder caps yet. Be interested in hearing your results.
Later
Old 05-12-2003, 12:23 PM   #5066
Hi all
Havent seen much of the AE guys like tphalen lately....might have been busy with their B4s
BTW what's the difference between the new oneways and the older ones
thanks
wiley is offline   Reply With Quote
Old 05-12-2003, 12:33 PM   #5067
Send a message via AIM to ZER01
- Dave
On the subject of the bladders, all I can tell you is they hold their rebound alot longer than the AE foam compensators. There's been cases where I hadn't changed my shock oil for like 15+/- races and the shocks with the yokomo bladders caps had exactly the same amount of rebound as they did when they were first built.
ZER01 is offline   Reply With Quote
Old 05-12-2003, 01:04 PM   #5068
I don't get much practice when there's a lot of rebound in my bladder..... keeps me running to the bathroom.....LOL
Old 05-12-2003, 01:18 PM   #5069
Sorry Impact, I meant the shocks hold their rebound alot longer.
Old 05-12-2003, 01:56 PM   #5070
LMAO
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
