Like Tree4Likes
Old 05-07-2003, 08:45 PM   #5041
Hooked's Avatar
64 pitch 72 teeth would be about the size of a dime ... exagerated a bit but it would be tiny ...
Hooked is offline   Reply With Quote
Old 05-07-2003, 08:53 PM   #5042
Hooked's Avatar
Standard config (48-72) ... what sizes do you already have?
Looking at Trinity's website ... the GM3 is a high RPM motor, but is probably a little sluggish off the line since it is intended for long flowing tracks ...
I would probably start with a 22 or 23 on the tight track and go with a 24 to 26 (start with the 24 and feel how it performs) on the more open track ... but keep in mind that I have no experience with the GM3 ... this is where I would start off if I was trying to find the right gearing for myself ...
Old 05-08-2003, 12:41 AM   #5043
seamus0g's Avatar
Default TC3 One-way
FYI:
Just got my hands on the latest AE TC3 one-way (new part # 3978) and the good news is it's the Yoko-based hub (w/the larger ring gear support), and comes with the new yellow ring gear. Mystery solved. Thanks for the info guys.
seamus0g is offline   Reply With Quote
Old 05-08-2003, 12:48 AM   #5044
seamus0g's Avatar
Originally posted by Johnnytc3
hehe no prob, he is actually a sponsored driver , so im thinking he did it right. im just not sure what else to check.
If your car works turning one direction, but "wipeout" the other direction then you have a pretty obvious mechanical/setup problem. All the suggestions presented here are possible causes. It's not rocket science. Take your car back to the "sponsored driver" and let him drive it. I'm sure he'll be able to instantly tell you what's wrong. Problem solved. If the "sponsored driver" can not figure it out then you should consult a shaman.
Old 05-08-2003, 12:53 AM   #5045
Send a message via AIM to Johnnytc3
if it was so obvious, i think i woulda figured it out by now... thanks for the help btw
Johnnytc3 is offline   Reply With Quote
Old 05-08-2003, 02:09 AM   #5046
hi
what is the diameter for the stock FTTC3 roll bar(sorry i got no caliper to measure)...i saw that BRP has optional swaybars with .55 / .62 / .78
and also i cant remember where i read about it but there was some mod done to either front or rear inner hinge pin holder for easy access...anyone read or done this before??
is the rear toe-in mod done using the front suspension arms/hub/steering knuckles better than using the losi hubs for ease of toe-in adjustment...i was thinking of doing the mod so that i would just need to keep stock for the front end parts
thanks for reading
happy racing
wiley is offline   Reply With Quote
Old 05-08-2003, 02:33 AM   #5047
seamus0g's Avatar
The FT TC3 comes with .060 sway bars.
Old 05-08-2003, 02:44 AM   #5048
thanks mate!!
Old 05-08-2003, 05:24 AM   #5049
JohnnyTC3- odds are 5-1 that if you pill apart the left front steering knuckle you have a detonated bearing, or busted cvd..... remmber you have to tear both apart!! But you will find something wrong!!
But first do a simple test... hold the car in the air and give it throttle, then release the throttle so that the wheels roll to a stop. take note of whic wheel stops first (probably left front....... remotely possible -- right rear) Next check for these things.......
1- Axle shim not on outside of axle before the roll pin.
2- bearing detonated (my bet)
3- CVD damaged
OHH yeah also check for---
4- bent hingepin (inner and outer)
5- busted plastic parts (arms,c-hub,steering knuclke, ect.....
6- Diff outdrive bearings
7- over tghtened wheel nut......
Some of this stuff may sound stubid and obvious, but don't be an "ohh it can't be that or I woulda noticed that).... check them!!!! When you car doesn't act right and there are 2 cause... and only 2!!!!!
1- faulty set-up (you seem to have eleminated that)
2- Mechanical failure.... there can't be anything else.......
BTW: I always start with mechanical failure because I don't end up finding a bsted bearing and having a car that is all out of whack..........
IF all else fails then maybe you got a ZOOLANDER ........ (can't turn left properly....LOL )
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-08-2003, 06:29 PM   #5050
Hooked's Avatar
TTT
Old 05-09-2003, 09:37 PM   #5051
Hooked's Avatar
40 Hours without a post on the TC3 thread ... WOW
That is not including my TTT post ...
Old 05-09-2003, 09:53 PM   #5052
Originally posted by wiley
hi
thanks for reading
happy racing
anyone has ant answers to this??
thanks
Old 05-09-2003, 09:53 PM   #5053
impact player,
i stripped down my car last nite to the brim, took out all the bearings, checked the binding on every suspension arm, droop was ok, rebuilt all shocks, check and tightened every cvd, and carriers... every thing seem ok but some of my bearings were kinda gritty. I race tomorrow so ill know if the bearings were what messed my car.
Old 05-09-2003, 10:04 PM   #5054
thanks
Yes, If you take the front and rear bumpers off of the car and remove the material that goes around the diff cases, now the bumpers and pin mounts can be removed with 2 screws while allowing the diff cases to be left attached.....
Old 05-09-2003, 10:53 PM   #5055
Hooked's Avatar
Does this mod weaken the bumber mount to a degree that has any effect in collisions?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
