Old 05-07-2003, 06:45 PM   #5026
chicky03's Avatar
Send a message via AIM to chicky03
This may sound stupid but I have seen people do it before. Check to make sure you do not have a plaid on one of the rears instead of a purple. It will make your car silly loose.
Paul
chicky03 is offline   Reply With Quote
Old 05-07-2003, 06:52 PM   #5027
Send a message via AIM to Johnnytc3
chicky huh? could you explain that to me again im kinda retarded.
thanks
johnny
Johnnytc3 is offline   Reply With Quote
Old 05-07-2003, 07:47 PM   #5028
Hooked's Avatar
Chicky was referring to the fact that you may have different hardness (shore rating) of tires on each side of the rear of the car ... something to check ...
Hooked is offline   Reply With Quote
Old 05-07-2003, 07:48 PM   #5029
oh i never run foams , we run rubbers ... im pretty sure they are all the same
Old 05-07-2003, 07:52 PM   #5030
Hooked's Avatar
Any news yet Johnny on your radio settings or suspension set-up?
Old 05-07-2003, 07:56 PM   #5031
i have a ko mars r that i switched to defualts and even when i turned the left balance all teh way down it still does it. and i had someone untweak my car but for some reason when i go straight and try to turn left it would just wipeout but on teh right it would turn soo good , good thing my sweeper turns right. lol
johnny
Old 05-07-2003, 08:02 PM   #5032
Hooked's Avatar
I don't mean to insult the guy that helped you with the tweak on your car ... but does he know what he is doing?
Old 05-07-2003, 08:03 PM   #5033
hehe no prob, he is actually a sponsored driver , so im thinking he did it right. im just not sure what else to check.
Old 05-07-2003, 08:05 PM   #5034
Hooked's Avatar
A bearing locked up on one side of the car would have an effect on the steering ...
Old 05-07-2003, 08:07 PM   #5035
sup
sup's Avatar
guys, would just want to ask what pinion gear should i use for a GM3 motor? thanks!
sup is offline   Reply With Quote
Old 05-07-2003, 08:14 PM   #5036
Hooked's Avatar
I don't have any experience with a Green Machine 3 ...
But ... for someone to respond to this, more info is needed ...
-type of car (I assume it's a TC3)
-48 or 64 pitch
-type of track (i.e. long and flowing ... tight infield ... long or short main straight ... etc.)
-driving style (i.e. lots of stopping and starting from hitting boards ... free flowing through corners ... etc.)
I could probably think of more variables ... but I'm sure you get the idea.
Old 05-07-2003, 08:15 PM   #5037
Hooked's Avatar
I forgot to add ...
-Spur size (# of teeth)
Old 05-07-2003, 08:39 PM   #5038
sup
sup's Avatar
will be using a 64pitch/72 teeth spur gear. will be playing at 2 tracks.. one is carpet, tight.. the other is asphalt and track is flowing (i think..)
Old 05-07-2003, 08:40 PM   #5039
i think you mean 48pitch ?
Old 05-07-2003, 08:44 PM   #5040
sup
sup's Avatar
oops.. its a 48 pitch spur gear, not 64..
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
