Old 05-06-2003, 02:19 PM   #5011
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I believe yokomo makes the oneways for the cars now, TC3 and NTC3.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-06-2003, 02:21 PM   #5012
rc-zombies's Avatar
Default Re: TC3 One-way
Originally posted by seamus0g
Anyone know what happened to the ae one-way for the TC3? I can't find any info about it on the Ass site, and it doesn't show up searching on Horizon and Tower. Has it been discontinued? I found a part number searching on Google, 3938, but such a part number doesn't show up on the ae parts list or any of the online catalogs. What's the deal? Thx.
Try the Yokomo TC3 one-way it's alot more durable...
Old 05-06-2003, 03:02 PM   #5013
seamus0g's Avatar
Thanks for the info guys. Also I just was informed by my LHS that Ass changed part # to 3978... which might be the Yoko in an AE package a la the NTC3 HD oneway... but who knows.
seamus0g is offline   Reply With Quote
Old 05-06-2003, 05:05 PM   #5014
Stevie's Avatar
HI EVERY ONE-
Ive just got myself a FT TC3-i got it pre-built-but when i hold it & put the power on it vibrates like hell.?.
Is there any waY i can fix this.??.
also the main shaft has 3/4mm paly,is this normal
Please help
steve
Stevie is offline   Reply With Quote
Old 05-06-2003, 08:51 PM   #5015
Send a message via AIM to AssociatedRacer
I believe it has, because they are making a new H.D. one or something, and also you can buy the Yokomo Heavy Duty one.
Check on www.speedtechrc.com they have it
AssociatedRacer is offline   Reply With Quote
Old 05-07-2003, 12:32 AM   #5016
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The vibration could be a few things the most common one is your tires are probably out of balance. Just like a real car, unbalanced wheels can cause vibrations. I use an airplane propeller balancer to do mine. They don't have to be perfect but when you glue up tires, there usually is a spot with too much glue or the tired and or wheel them selves will have a heavy spot. Just try to counter the heavy spot with some lead tape. It works nicely.
Jon Kerr is offline   Reply With Quote
Old 05-07-2003, 04:15 AM   #5017
rcdougie's Avatar
I believe the new part number for the one way is 3978 and stormer has them.
rcdougie is offline   Reply With Quote
Old 05-07-2003, 06:42 AM   #5018
Stevie's Avatar
the tyres & wheels have not been used-& it vibrates when i hold it in my hands.?.
The car is also brand new..
thanx for the surgestion
regard's
stevie
Old 05-07-2003, 06:45 AM   #5019
AGR#7's Avatar
Default Selling everything - just to let you all know!
On eBay..........
http://cgi.ebay.com/ws/eBayISAPI.dll...gory=2565&rd=1
Feel free to contact me. Thanks!!!
AGR#7 is offline   Reply With Quote
Old 05-07-2003, 03:40 PM   #5020
driftmaster's Avatar
Originally posted by Stevie
HI EVERY ONE-
Please help
steve
Hey Stevie,
Put a drop or two of oil in the Diff out drives wher the dog bones
go in. They bind up sometimes and cause the vibrations.
driftmaster is offline   Reply With Quote
Old 05-07-2003, 05:05 PM   #5021
Hooked's Avatar
Slowly apply power while holding the car ... does the vibration increase proportionately to the drivetrain rpm? or does it start to vibrate all at once?
Is there any noticable runout in any of the visible parts? For instance, the spur gear or input shaft cups being out of true ...
Remove the drive shaft and apply power ... this will help to eliminate the drive shaft and the front dif as the problem ...
Let us know how these suggestions turn out.
Hooked is offline   Reply With Quote
Old 05-07-2003, 07:32 PM   #5022
noline's Avatar
Can any one help me. My car when I make left turns the car wants to spin out but when I make right turns It is ok. I check and recheck the tweak went over the whole car I even bought a new chassis and it still does the same thing I checked the rear toe in and it is fine any help would be greatly appreciated
noline is offline   Reply With Quote
Old 05-07-2003, 07:34 PM   #5023
Send a message via AIM to Johnnytc3
mine does the same darn thing... i gave up on it ...
Johnnytc3 is offline   Reply With Quote
Old 05-07-2003, 07:39 PM   #5024
Hooked's Avatar
That's odd that your car would turn left sharper than right ... given that the tweak is compensated for of course ...
The TC3 has more steering throw to the right than the left by design, but that does not explain what you are experiencing ...
Have you checked your radio steering end-points? If the end-point settings are messed up you could be physically moving the servo farther left than right.
Old 05-07-2003, 07:42 PM   #5025
Hooked's Avatar
Do you have access to a set-up board? You could have front suspension asymmetry ...
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
